* Makefile.am, configure.ac, common/cpright.texi, common/rtems.texi.in,
cpu_supplement/.cvsignore, started/Makefile.am, started/binaries.t,
started/buildc.t, started/buildrt.t, started/intro.t,
started/nextstep.t, started/nt.t, started/require.t,
started/sample.t, started/started.texi, started/version.texi: Major
update which includes removal of references to specific tool versions
and patches.
* started/tversions.texi.in: Removed.
BINUTILS_RPMREL = 0.20101211.0.
GCC_RPMREL = 0.20101211.0.
Remove fedora 12.
* loopback/init.c: Loop back interface will be initialized now during
normal initialization via rtems_bsdnet_initialize_network().
* libnetworking/loop.h, libnetworking/net/if_loop.c,
libnetworking/rtems/rtems_glue.c, libmisc/dummy/dummy-networking.c:
Initialize loop back interface during normal initialization via
* make/custom/rtl22xx_t.cfg: Now compiles.
* configure.ac: Add initial small set of POSIX Timing Tests.
* README: Add initial small set of POSIX Timing Tests.
* .cvsignore, ChangeLog, Makefile.am, README, configure.ac,
psxtmtests_plan.csv, psxtmmutex02/.cvsignore,
psxtmmutex02/Makefile.am, psxtmmutex02/init.c,
psxtmmutex02/psxtmmutex02.doc, psxtmthread01/.cvsignore,
psxtmthread01/Makefile.am, psxtmthread01/init.c,
psxtmthread01/psxtmthread01.doc, psxtmthread03/.cvsignore,
psxtmthread03/Makefile.am, psxtmthread03/init.c,
psxtmthread03/psxtmthread03.doc: New files.
* configure.ac, posix/src/signal_2.c: sighandler_t is defined
conditionally in some versions of newlib and unconditionally in
others. Make sure we always compile.
* bsp_specs, start/start.S, startup/linkcmds: Use linker command base
file.
* bsp_specs, start/start.S, startup/linkcmds.csb337,
startup/linkcmds.csb637: Use linker command base file.
* startup/linkcmds: Use linker command base file.
* start/start.S, startup/linkcmds: Use linker command base file.
* startup/linkcmds, start/start.S: Use linker command base file.
* startup/bspgetworkarea.c: Removed file.
* Makefile.am, bsp_specs, start/start.S, startup/bspstart.c,
libnds/include/nds/jtypes.h, libnds/source/arm9/gurumeditation.c,
libnds/source/common/interruptDispatcher.S,
libnds/source/common/interrupts.c, startup/linkcmds: Use linker
command base file.
* startup/linkcmds.lpc2362, startup/linkcmds.lpc23xx_tli800,
startup/linkcmds.lpc24xx_ea, startup/linkcmds.lpc24xx_ncs_ram,
startup/linkcmds.lpc24xx_ncs_rom_ext,
startup/linkcmds.lpc24xx_ncs_rom_int: Update due to linker command
file changes.
* startup/linkcmds.lpc32xx_mzx, startup/linkcmds.lpc32xx_mzx_stage_1,
startup/linkcmds.lpc32xx_mzx_stage_2,
startup/linkcmds.lpc32xx_phycore: Update due to linker command file
changes.
* shared/startup/linkcmds.base: Split up fast region.
* include/lcd.h, misc/lcd.c: New files.
* misc/io.c, include/io.h: Documentation, bug fixes, more
configurations.
* include/lpc24xx.h: Added DAC and I2S.
* Makefile.am, bsp_specs, preinstall.am, startup/bspstarthooks.c,
file changes.
* include/lpc32xx.h: Added I2S module.
startup/linkcmds.lpc32xx, startup/linkcmds.lpc32xx_mzx,
changes.
* preinstall.am, shared/lpc/include/lpc-i2s.h,
shared/startup/linkcmds.armv4, shared/startup/linkcmds.armv7: New
files.
* Makefile.am: Added header and linker command files intended to be
used by every ARM BSP.
* shared/startup/linkcmds.base: Support for EABI and ARM ELF standard.
* shared/include/linker-symbols.h: Update due to linker command file
changes.
* shared/start/start.S, shared/include/start.h: Renamed entry symbol
from start to _start to avoid namespace conflicts. Update due to
linker command file changes.
* configure.ac: Check for complex.h.
Add AM_CONDITIONAL(HAS_COMPLEX) to allow building with outdated
toolchains.
* complex/Makefile.am: Apply HAS_COMPLEX.
* mpc55xx/edma/edma.c: Use rtems_chain_first() and do not directly
access the structure.
* Makefile.am: Add complex, math subdirs.
* configure.ac: Add complex, math subdirs.
* complex/Makefile.am, complex/init.c, complex/docomplex.c,
complex/docomplexf.c, complex/complex.scn, complex/docomplex.in,
complex/complex.doc, complex/docomplexl.c: New.
* math/Makefile.am, math/init.c, math/domath.c,
math/domathf.c, math/math.scn, math/domath.in,
math/math.doc, math/domathl.c: New.
* libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Revert
previous commit due to too many broken linker command files. The
HAVE_INITFINI_ARRAY is defined for nearly all targets by Newlib, but
only few linker command files respect this.
* libcsupport/src/newlibc_exit.c, score/src/threadhandler.c: Added
support for .preinit_array, .init_array and .fini_array sections.
* spchain/init.c: Added test case.
* tm26/task1.c, tm27/task1.c: Update for API changes.
* sapi/include/confdefs.h, score/include/rtems/score/scheduler.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl,
score/src/schedulerpriority.c,
score/src/schedulerprioritythreadschedulerallocate.c,
score/src/schedulerprioritythreadschedulerfree.c,
score/src/schedulerprioritythreadschedulerupdate.c,
score/src/schedulerpriorityyield.c: Added attribute unused. Renamed
types and fields to follow the Score naming conventions.
* score/include/rtems/score/scheduler.h,
score/include/rtems/score/schedulerpriority.h: Whitespace removal.
Moved C++ extern directive.
* spchain/init.c, spchain/spchain.scn: More test cases.
PR 1711/cpukit
* score/inline/rtems/score/chain.inl, score/src/chain.c: New functions
_Chain_Immutable_head(), _Chain_Immutable_tail(),
_Chain_Immutable_first(), and _Chain_Immutable_last(). The
Chain_Control is now a union to avoid casts. The function
_Chain_Is_empty() takes now a const pointer parameter.
* libfs/src/dosfs/fat_file.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_getchild.c,
posix/src/killinfo.c, score/inline/rtems/score/schedulerpriority.inl,
score/inline/rtems/score/watchdog.inl, score/src/apiext.c,
score/src/chain.c, score/src/coremsgflushsupp.c,
score/src/coremsginsert.c, score/src/objectshrinkinformation.c,
score/src/schedulerpriorityyield.c,
score/src/threadqdequeuepriority.c,
score/src/threadqenqueuepriority.c,
score/src/threadqextractpriority.c, score/src/threadqfirstfifo.c,
score/src/threadqfirstpriority.c, score/src/threadyieldprocessor.c,
score/src/userextthreadbegin.c, score/src/userextthreadcreate.c,
score/src/userextthreaddelete.c, score/src/userextthreadrestart.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c,
score/src/watchdogreportchain.c: Avoid chain API violations.
PR 1647/cpukit
* tm26/task1.c, tm27/task1.c: Update documentation to reflect
refactoring of SuperCore to add Scheduler Handler.
PR 1647/cpukit
* spsize/size.c: Update documentation to reflect refactoring of
PR 1647/cpukit
* user/conf.t, user/schedule.t: Update documentation to reflect
refactoring of SuperCore to add Scheduler and ability for user to
configure a scheduler.
PR 1647/cpukit
* posix/src/nanosleep.c, posix/src/sched_yield.c,
rtems/src/taskwakeafter.c, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/src/exinit.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/thread.inl, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadclose.c, score/src/threadinitialize.c,
score/src/threadready.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c: Refactor scheduler out of thread
handler to facilitate alternate scheduler implementations.
* score/src/threadyieldprocessor.c: Removed.
* score/src/schedulerprioritythreadschedulerupdate.c,
score/src/schedulerpriorityblock.c, score/src/scheduler.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriority.c, score/src/schedulerpriorityyield.c,
score/include/rtems/score/schedulerpriority.h,
score/inline/rtems/score/schedulerpriority.inl: New files.
