* Makefile.am: Add tools to SUBDIRS.
* configure.ac: Add RTEMS_CONFIG_BUILD_SUBDIRS(tools).
* ChangeLog: New.
* .cvsignore: New.
* configure.ac: New.
* runtest: Removed.
* runtest.in: New (Copied from runtest).
Use @RTEMS_BSP@ instead of simsh4.
* ide/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* aclocal/bsp-arg-enable.m4, aclocal/bsp-configure.m4,
aclocal/bspopts.m4, aclocal/canonicalize-tools.m4,
aclocal/check-bsp-cache.m4, aclocal/check-cxx.m4,
aclocal/check-itron.m4, aclocal/check-multiprocessing.m4,
aclocal/check-networking.m4, aclocal/check-newlib.m4,
aclocal/check-posix.m4, aclocal/check-rdbg.m4,
aclocal/check-tool.m4, aclocal/env-rtemsbsp.m4,
aclocal/gcc-isystem.m4, aclocal/gcc-pipe.m4,
aclocal/gcc-specs.m4, aclocal/i386-gas-code16.m4,
aclocal/path-perl.m4, aclocal/ppc.m4,
aclocal/prog-cc.m4, aclocal/prog-ccas.m4,
aclocal/prog-cxx.m4, aclocal/prog-gnat.m4,
aclocal/rtems-debug.m4, aclocal/rtems-flags.m4,
aclocal/rtems-test-no-pause.m4, aclocal/target.m4:
Remove (Unused).
* automake/leaf.am, automake/force-preinstall.am:
Remove (Unused).
* network/cs8900.c: Correct copyright statements.
* mpc8260/clock/clock.c: Correct copyright statements.
* clock/ckinit.c, console/mcfuart.c, timer/timer.c, timer/timerisr.S:
* include/bsp.h: Correct copyright statements.
* console/console.c: Correct copyright statements.
* clock/p_clock.c, network/if_hdlcsubr.h: Correct copyright statements.
* console/console.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5206e.c: Correct copyright
statements.
* mptests/mp01/config.h, mptests/mp01/mp01.adb,
mptests/mp01/mptest.adb, mptests/mp01/mptest.ads,
mptests/mp02/mptest.adb, mptests/mp02/mptest.ads,
mptests/mp03/mptest.adb, mptests/mp03/mptest.ads,
mptests/mp04/mptest.adb, mptests/mp04/mptest.ads,
mptests/mp05/mptest.adb, mptests/mp05/mptest.ads,
mptests/mp06/mptest.adb, mptests/mp06/mptest.ads,
mptests/mp07/mptest.adb, mptests/mp07/mptest.ads,
mptests/mp08/mptest.adb, mptests/mp08/mptest.ads,
mptests/mp09/mptest.adb, mptests/mp09/mptest.ads,
mptests/mp10/mptest.adb, mptests/mp10/mptest.ads,
mptests/mp11/mptest.adb, mptests/mp11/mptest.ads,
mptests/mp12/mptest.adb, mptests/mp12/mptest.ads,
mptests/mp13/mptest.adb, mptests/mp13/mptest.ads,
mptests/mp14/mptest.adb, mptests/mp14/mptest.ads,
samples/base_mp/mptest.adb, samples/base_mp/mptest.ads,
samples/base_sp/base_sp.adb, samples/base_sp/config.h,
samples/base_sp/sptest.adb, samples/base_sp/sptest.ads,
samples/hello/config.h, samples/hello/hello.adb,
samples/hello/sptest.adb, samples/hello/sptest.ads,
samples/ticker/config.h, samples/ticker/sptest.adb,
samples/ticker/sptest.ads, samples/ticker/ticker.adb,
sptests/sp01/config.h, sptests/sp01/sp01.adb,
sptests/sp01/sptest.adb, sptests/sp01/sptest.ads,
sptests/sp02/config.h, sptests/sp02/sp02.adb,
sptests/sp02/sptest.adb, sptests/sp02/sptest.ads,
sptests/sp03/config.h, sptests/sp03/sp03.adb,
sptests/sp03/sptest.adb, sptests/sp03/sptest.ads,
sptests/sp04/config.h, sptests/sp04/sp04.adb,
sptests/sp04/sptest.adb, sptests/sp04/sptest.ads,
sptests/sp05/config.h, sptests/sp05/sp05.adb,
sptests/sp05/sptest.adb, sptests/sp05/sptest.ads,
sptests/sp06/config.h, sptests/sp06/sp06.adb,
sptests/sp06/sptest.adb, sptests/sp06/sptest.ads,
sptests/sp07/config.h, sptests/sp07/sp07.adb,
sptests/sp07/sptest.adb, sptests/sp07/sptest.ads,
sptests/sp08/config.h, sptests/sp08/sp08.adb,
sptests/sp08/sptest.adb, sptests/sp08/sptest.ads,
sptests/sp09/config.h, sptests/sp09/sp09.adb,
sptests/sp09/sptest.adb, sptests/sp09/sptest.ads,
sptests/sp11/config.h, sptests/sp11/sp11.adb,
sptests/sp11/sptest.adb, sptests/sp11/sptest.ads,
sptests/sp12/config.h, sptests/sp12/sp12.adb,
sptests/sp12/sptest.adb, sptests/sp12/sptest.ads,
sptests/sp13/config.h, sptests/sp13/sp13.adb,
sptests/sp13/sptest.adb, sptests/sp13/sptest.ads,
sptests/sp14/config.h, sptests/sp14/sp14.adb,
sptests/sp14/sptest.adb, sptests/sp14/sptest.ads,
sptests/sp15/config.h, sptests/sp15/sp15.adb,
sptests/sp15/sptest.adb, sptests/sp15/sptest.ads,
sptests/sp16/config.h, sptests/sp16/sp16.adb,
sptests/sp16/sptest.adb, sptests/sp16/sptest.ads,
sptests/sp17/config.h, sptests/sp17/sp17.adb,
sptests/sp17/sptest.adb, sptests/sp17/sptest.ads,
sptests/sp19/config.h, sptests/sp19/sp19.adb,
sptests/sp19/sptest.ads, sptests/sp20/config.h,
sptests/sp20/sp20.adb, sptests/sp20/sptest.adb,
sptests/sp20/sptest.ads, sptests/sp21/config.h,
sptests/sp21/sp21.adb, sptests/sp21/sptest.adb,
sptests/sp21/sptest.ads, sptests/sp22/config.h,
sptests/sp22/sp22.adb, sptests/sp22/sptest.adb,
sptests/sp22/sptest.ads, sptests/sp23/config.h,
sptests/sp23/sp23.adb, sptests/sp23/sptest.adb,
sptests/sp23/sptest.ads, sptests/sp24/config.h,
sptests/sp24/sp24.adb, sptests/sp24/sptest.adb,
sptests/sp24/sptest.ads, sptests/sp25/config.h,
sptests/sp25/sp25.adb, sptests/sp25/sptest.adb,
sptests/sp25/sptest.ads, sptests/spsize/spsize.adb,
sptests/spsize/sptest.adb, sptests/spsize/sptest.ads,
support/address_io.adb, support/address_io.ads, support/float_io.ads,
support/fp.inc, support/integer.inc,
support/rtems_calling_overhead.ads, support/status_io.ads,
support/test_support.adb, support/test_support.ads,
support/time_test_support.adb, support/time_test_support.ads,
support/timer_driver.adb, support/timer_driver.ads,
support/unsigned32_io.ads, tmtests/tm01/config.h,
tmtests/tm01/tm01.adb, tmtests/tm01/tmtest.adb,
tmtests/tm01/tmtest.ads, tmtests/tm02/config.h,
tmtests/tm02/tm02.adb, tmtests/tm02/tmtest.adb,
tmtests/tm02/tmtest.ads, tmtests/tm03/config.h,
tmtests/tm03/tm03.adb, tmtests/tm03/tmtest.adb,
tmtests/tm03/tmtest.ads, tmtests/tm04/config.h,
tmtests/tm04/tm04.adb, tmtests/tm04/tmtest.adb,
tmtests/tm04/tmtest.ads, tmtests/tm05/config.h,
tmtests/tm05/tm05.adb, tmtests/tm05/tmtest.adb,
tmtests/tm05/tmtest.ads, tmtests/tm06/config.h,
tmtests/tm06/tm06.adb, tmtests/tm06/tmtest.adb,
tmtests/tm06/tmtest.ads, tmtests/tm07/config.h,
tmtests/tm07/tm07.adb, tmtests/tm07/tmtest.adb,
tmtests/tm07/tmtest.ads, tmtests/tm08/config.h,
tmtests/tm08/tm08.adb, tmtests/tm08/tmtest.adb,
tmtests/tm08/tmtest.ads, tmtests/tm09/config.h,
tmtests/tm09/tm09.adb, tmtests/tm09/tmtest.adb,
tmtests/tm09/tmtest.ads, tmtests/tm10/config.h,
tmtests/tm10/tm10.adb, tmtests/tm10/tmtest.adb,
tmtests/tm10/tmtest.ads, tmtests/tm11/config.h,
tmtests/tm11/tm11.adb, tmtests/tm11/tmtest.adb,
tmtests/tm11/tmtest.ads, tmtests/tm12/config.h,
tmtests/tm12/tm12.adb, tmtests/tm12/tmtest.adb,
tmtests/tm12/tmtest.ads, tmtests/tm13/config.h,
tmtests/tm13/tm13.adb, tmtests/tm13/tmtest.adb,
tmtests/tm13/tmtest.ads, tmtests/tm14/config.h,
tmtests/tm14/tm14.adb, tmtests/tm14/tmtest.adb,
tmtests/tm14/tmtest.ads, tmtests/tm15/config.h,
tmtests/tm15/tm15.adb, tmtests/tm15/tmtest.adb,
tmtests/tm15/tmtest.ads, tmtests/tm16/config.h,
tmtests/tm16/tm16.adb, tmtests/tm16/tmtest.adb,
tmtests/tm16/tmtest.ads, tmtests/tm17/config.h,
tmtests/tm17/tm17.adb, tmtests/tm17/tmtest.adb,
tmtests/tm17/tmtest.ads, tmtests/tm18/config.h,
tmtests/tm18/tm18.adb, tmtests/tm18/tmtest.adb,
tmtests/tm18/tmtest.ads, tmtests/tm19/config.h,
tmtests/tm19/tm19.adb, tmtests/tm19/tmtest.adb,
tmtests/tm19/tmtest.ads, tmtests/tm20/config.h,
tmtests/tm20/tm20.adb, tmtests/tm20/tmtest.adb,
tmtests/tm20/tmtest.ads, tmtests/tm21/config.h,
tmtests/tm21/tm21.adb, tmtests/tm21/tmtest.adb,
tmtests/tm21/tmtest.ads, tmtests/tm22/config.h,
tmtests/tm22/tm22.adb, tmtests/tm22/tmtest.adb,
tmtests/tm22/tmtest.ads, tmtests/tm23/config.h,
tmtests/tm23/tm23.adb, tmtests/tm23/tmtest.adb,
tmtests/tm23/tmtest.ads, tmtests/tm24/config.h,
tmtests/tm24/tm24.adb, tmtests/tm24/tmtest.adb,
tmtests/tm24/tmtest.ads, tmtests/tm25/config.h,
tmtests/tm25/tm25.adb, tmtests/tm25/tmtest.adb,
tmtests/tm25/tmtest.ads, tmtests/tm28/config.h,
tmtests/tm28/tm28.adb, tmtests/tm28/tmtest.adb,
tmtests/tm28/tmtest.ads, tmtests/tm29/config.h,
tmtests/tm29/tm29.adb, tmtests/tm29/tmtest.adb,
tmtests/tm29/tmtest.ads, tmtests/tmck/config.h,
tmtests/tmck/tmck.adb, tmtests/tmck/tmtest.adb,
tmtests/tmck/tmtest.ads, tmtests/tmoverhd/config.h,
tmtests/tmoverhd/dummy_rtems.adb, tmtests/tmoverhd/dummy_rtems.ads,
tmtests/tmoverhd/tmoverhd.adb, tmtests/tmoverhd/tmtest.adb,
tmtests/tmoverhd/tmtest.ads: Correct copyright statements.
* custom/mvme167.cfg: Remove PRINTK_MINOR, CONSOLE_MINOR (move to
the BSP's configure-script).
Remove BSP_CPPFLAGS (Obsolete).
* console/Makefile.am: Remove BSP_CPPFLAGS.
* configure.ac: Add BSPOPTS PRINTK_MINOR and CONSOLE_MINOR.
* console/Makefile.am: Don't include @RTEMS_BSP@.cfg
* ide/Makefile.am: Don't include @RTEMS_BPS@.cfg.
* Makefile.am,
mptests/Makefile.am,
mptests/mp01/Makefile.am, mptests/mp01/node1/Makefile.am,
mptests/mp01/node2/Makefile.am,
samples/Makefile.am, samples/base_mp/Makefile.am,
samples/base_mp/node1/Makefile.am, samples/base_mp/node2/Makefile.am,
samples/base_sp/Makefile.am, samples/hello/Makefile.am,
samples/ticker/Makefile.am,
sptests/Makefile.am,
sptests/sp01/Makefile.am, sptests/sp02/Makefile.am,
sptests/sp03/Makefile.am, sptests/sp04/Makefile.am,
sptests/sp05/Makefile.am, sptests/sp06/Makefile.am,
sptests/sp07/Makefile.am, sptests/sp08/Makefile.am,
sptests/sp09/Makefile.am, sptests/sp11/Makefile.am,
sptests/sp12/Makefile.am, sptests/sp13/Makefile.am,
sptests/sp14/Makefile.am, sptests/sp15/Makefile.am,
sptests/sp16/Makefile.am, sptests/sp17/Makefile.am,
sptests/sp19/Makefile.am, sptests/sp20/Makefile.am,
sptests/sp21/Makefile.am, sptests/sp22/Makefile.am,
sptests/sp23/Makefile.am, sptests/sp24/Makefile.am,
sptests/sp25/Makefile.am, sptests/spsize/Makefile.am,
support/Makefile.am,
tmtests/Makefile.am,
tmtests/tm01/Makefile.am, tmtests/tm02/Makefile.am,
tmtests/tm03/Makefile.am, tmtests/tm04/Makefile.am,
tmtests/tm05/Makefile.am, tmtests/tm06/Makefile.am,
tmtests/tm07/Makefile.am, tmtests/tm08/Makefile.am,
tmtests/tm09/Makefile.am, tmtests/tm10/Makefile.am,
tmtests/tm11/Makefile.am, tmtests/tm12/Makefile.am,
tmtests/tm13/Makefile.am, tmtests/tm14/Makefile.am,
tmtests/tm15/Makefile.am, tmtests/tm16/Makefile.am,
tmtests/tm17/Makefile.am, tmtests/tm18/Makefile.am,
tmtests/tm19/Makefile.am, tmtests/tm20/Makefile.am,
tmtests/tm21/Makefile.am, tmtests/tm22/Makefile.am,
tmtests/tm23/Makefile.am, tmtests/tm24/Makefile.am,
tmtests/tm25/Makefile.am, tmtests/tm28/Makefile.am,
tmtests/tm29/Makefile.am, tmtests/tmck/Makefile.am,
tmtests/tmoverhd/Makefile.am:
Pick up am-fragments from ../tests/automake.
* aclocal/prog-gnat.m4: New (copied from ../../../aclocal).
* Makefile.am: ACLOCAL_AMFLAGS = -I aclocal -I ../tests/aclocal.
Don't include */automake/lib.am (Unused).
PR 458/tests
* sp30/task1.c: Correct indexing problem.
* aclocal/check-itron.m4: New.
* aclocal/enable-inlines.m4: New.
* Makefile.am: Add -I aclocal to ACLOCAL_AMFLAGS.
* aclocal/check-itron.m4: Remove.
* aclocal/enable-inlines.m4: Remove.
* aclocal/rtems-debug.m4: Remove.
* aclocal/enable-rtems-debug.m4: New (Split out from rtems-debug.m4).
* aclocal/check-rtems-debug.m4: New (Split out from rtems-debug.m4).
PR 449/rtems:
* src/getegid.c: New (Copied from ../posix/src).
* src/geteuid.c: New (Copied from ../posix/src).
* src/getgid.c: New (Copied from ../posix/src).
* src/getgroups.c: New (Copied from ../posix/src).
* src/getlogin.c: New (Copied from ../posix/src).
* src/getpgrp.c: New (Copied from ../posix/src).
* src/getpid.c: New (Copied from ../posix/src).
* src/getppid.c: New (Copied from ../posix/src).
* src/getuid.c: New (Copied from ../posix/src).
* src/setpgid.c: New (Copied from ../posix/src).
* src/setsid.c: New (Copied from ../posix/src).
* src/no_posix: Remove getpid and _getpid_r.
PR 449/rtems:
* src/getegid.c: Remove (Moved to ../libcsupport/src).
* src/geteuid.c: Remove (Moved to ../libcsupport/src).
* src/getgid.c: Remove (Moved to ../libcsupport/src).
* src/getgroups.c: Remove (Moved to ../libcsupport/src).
* src/getlogin.c: Remove (Moved to ../libcsupport/src).
* src/getpgrp.c: Remove (Moved to ../libcsupport/src).
* src/getpid.c: Remove (Moved to ../libcsupport/src).
* src/getppid.c: Remove (Moved to ../libcsupport/src).
* src/getuid.c: Remove (Moved to ../libcsupport/src).
* src/setpgid.c: Remove (Moved to ../libcsupport/src).
* src/setsid.c: Remove (Moved to ../libcsupport/src).
* automake/local.am: Remove "debug".
* aclocal/bsp-alias.m4: New (Copied from ../../aclocal).
* aclocal/bsp-arg-enable.m4: New (Copied from ../../aclocal).
* aclocal/bsp-configure.m4: New (Copied from ../../aclocal).
* aclocal/bspopts.m4: New (Copied from ../../aclocal).
* aclocal/canonical-host.m4: New (Copied from ../../aclocal).
* aclocal/canonicalize-tools.m4: New (Copied from ../../aclocal).
* aclocal/canonical-target-name.m4: New (Copied from ../../aclocal).
* aclocal/check-cpu.m4: New (Copied from ../../aclocal).
* aclocal/check-custom-bsp.m4: New (Copied from ../../aclocal).
* aclocal/check-cxx.m4: New (Copied from ../../aclocal).
* aclocal/check-itron.m4: New (Copied from ../../aclocal).
* aclocal/check-multiprocessing.m4: New (Copied from ../../aclocal).
* aclocal/check-networking.m4: New (Copied from ../../aclocal).
* aclocal/check-posix.m4: New (Copied from ../../aclocal).
* aclocal/check-rdbg.m4: New (Copied from ../../aclocal).
* aclocal/check-tool.m4: New (Copied from ../../aclocal).
* aclocal/config-subdirs.m4: New (Copied from ../../aclocal).
* aclocal/enable-bare.m4: New (Copied from ../../aclocal).
* aclocal/enable-cxx.m4: New (Copied from ../../aclocal).
* aclocal/enable-inlines.m4: New (Copied from ../../aclocal).
* aclocal/enable-itron.m4: New (Copied from ../../aclocal).
* aclocal/enable-multiprocessing.m4: New (Copied from ../../aclocal).
* aclocal/enable-networking.m4: New (Copied from ../../aclocal).
* aclocal/enable-posix.m4: New (Copied from ../../aclocal).
* aclocal/enable-rdbg.m4: New (Copied from ../../aclocal).
* aclocal/enable-rtemsbsp.m4: New (Copied from ../../aclocal).
* aclocal/env-rtemsbsp.m4: New (Copied from ../../aclocal).
* aclocal/gcc-isystem.m4: New (Copied from ../../aclocal).
* aclocal/gcc-pipe.m4: New (Copied from ../../aclocal).
* aclocal/gcc-specs.m4: New (Copied from ../../aclocal).
* aclocal/i386-gas-code16.m4: New (Copied from ../../aclocal).
* aclocal/multilib.m4: New (Copied from ../../aclocal).
* aclocal/path-ksh.m4: New (Copied from ../../aclocal).
* aclocal/path-perl.m4: New (Copied from ../../aclocal).
* aclocal/ppc.m4: New (Copied from ../../aclocal).
* aclocal/prog-ccas.m4: New (Copied from ../../aclocal).
* aclocal/prog-cc.m4: New (Copied from ../../aclocal).
* aclocal/prog-cxx.m4: New (Copied from ../../aclocal).
* aclocal/project-root.m4: New (Copied from ../../aclocal).
* aclocal/quoting.m4: New (Copied from ../../aclocal).
* aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../aclocal).
* aclocal/rtems-flags.m4: New (Copied from ../../aclocal).
* aclocal/rtems-top.m4: New (Copied from ../../aclocal).
* aclocal/target.m4: New (Copied from ../../aclocal).
* aclocal/tool-paths.m4: New (Copied from ../../aclocal).
* aclocal/version.m4: New (Copied from ../../aclocal).
* aclocal/bsp-alias.m4: New (Copied from ../../../aclocal).
* aclocal/canonical-host.m4: New (Copied from ../../../aclocal).
* aclocal/canonicalize-tools.m4: New (Copied from ../../../aclocal).
* aclocal/canonical-target-name.m4: New (Copied from ../../../aclocal).
* aclocal/check-cpu.m4: New (Copied from ../../../aclocal).
* aclocal/check-custom-bsp.m4: New (Copied from ../../../aclocal).
* aclocal/check-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/check-itron.m4: New (Copied from ../../../aclocal).
* aclocal/check-multiprocessing.m4: New (Copied from ../../../aclocal).
* aclocal/check-networking.m4: New (Copied from ../../../aclocal).
* aclocal/check-posix.m4: New (Copied from ../../../aclocal).
* aclocal/check-tool.m4: New (Copied from ../../../aclocal).
* aclocal/config-subdirs.m4: New (Copied from ../../../aclocal).
* aclocal/enable-bare.m4: New (Copied from ../../../aclocal).
* aclocal/enable-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/enable-itron.m4: New (Copied from ../../../aclocal).
* aclocal/enable-multiprocessing.m4: New (Copied from ../../../aclocal).
* aclocal/enable-networking.m4: New (Copied from ../../../aclocal).
* aclocal/enable-posix.m4: New (Copied from ../../../aclocal).
* aclocal/enable-rtemsbsp.m4: New (Copied from ../../../aclocal).
* aclocal/enable-tests.m4: New (Copied from ../../../aclocal).
* aclocal/env-rtemsbsp.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-isystem.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-pipe.m4: New (Copied from ../../../aclocal).
* aclocal/gcc-specs.m4: New (Copied from ../../../aclocal).
* aclocal/multilib.m4: New (Copied from ../../../aclocal).
* aclocal/path-ksh.m4: New (Copied from ../../../aclocal).
* aclocal/prog-cc.m4: New (Copied from ../../../aclocal).
* aclocal/prog-cxx.m4: New (Copied from ../../../aclocal).
* aclocal/project-root.m4: New (Copied from ../../../aclocal).
* aclocal/quoting.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-cpu-subdirs.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-flags.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-test-no-pause.m4: New (Copied from ../../../aclocal).
* aclocal/rtems-top.m4: New (Copied from ../../../aclocal).
* aclocal/target.m4: New (Copied from ../../../aclocal).
* aclocal/tool-paths.m4: New (Copied from ../../../aclocal).
* aclocal/version.m4: New (Copied from ../../../aclocal).
* automake/local.am, automake/host.am: Remove "debug".
* configure.ac: Remove stray comments.
tm01/Makefile.am: Reflect having moved automake.
tm02/Makefile.am: Reflect having moved automake.
tm03/Makefile.am: Reflect having moved automake.
tm04/Makefile.am: Reflect having moved automake.
tm05/Makefile.am: Reflect having moved automake.
tm06/Makefile.am: Reflect having moved automake.
tm07/Makefile.am: Reflect having moved automake.
tm08/Makefile.am: Reflect having moved automake.
tm09/Makefile.am: Reflect having moved automake.
tm10/Makefile.am: Reflect having moved automake.
tm11/Makefile.am: Reflect having moved automake.
tm12/Makefile.am: Reflect having moved automake.
tm13/Makefile.am: Reflect having moved automake.
tm14/Makefile.am: Reflect having moved automake.
tm15/Makefile.am: Reflect having moved automake.
tm16/Makefile.am: Reflect having moved automake.
tm17/Makefile.am: Reflect having moved automake.
tm18/Makefile.am: Reflect having moved automake.
tm19/Makefile.am: Reflect having moved automake.
tm20/Makefile.am: Reflect having moved automake.
tm21/Makefile.am: Reflect having moved automake.
tm22/Makefile.am: Reflect having moved automake.
tm23/Makefile.am: Reflect having moved automake.
tm24/Makefile.am: Reflect having moved automake.
tm25/Makefile.am: Reflect having moved automake.
tm26/Makefile.am: Reflect having moved automake.
tm27/Makefile.am: Reflect having moved automake.
tm28/Makefile.am: Reflect having moved automake.
tm29/Makefile.am: Reflect having moved automake.
tmck/Makefile.am: Reflect having moved automake.
tmoverhd/Makefile.am: Reflect having moved automake.
tmitronsem01/Makefile.am: Reflect having moved automake.
sp01/Makefile.am: Reflect having moved automake.
sp02/Makefile.am: Reflect having moved automake.
sp03/Makefile.am: Reflect having moved automake.
sp04/Makefile.am: Reflect having moved automake.
sp05/Makefile.am: Reflect having moved automake.
sp06/Makefile.am: Reflect having moved automake.
sp07/Makefile.am: Reflect having moved automake.
sp08/Makefile.am: Reflect having moved automake.
sp09/Makefile.am: Reflect having moved automake.
sp11/Makefile.am: Reflect having moved automake.
sp12/Makefile.am: Reflect having moved automake.
sp13/Makefile.am: Reflect having moved automake.
sp14/Makefile.am: Reflect having moved automake.
sp15/Makefile.am: Reflect having moved automake.
sp16/Makefile.am: Reflect having moved automake.
sp17/Makefile.am: Reflect having moved automake.
sp19/Makefile.am: Reflect having moved automake.
sp20/Makefile.am: Reflect having moved automake.
sp21/Makefile.am: Reflect having moved automake.
sp22/Makefile.am: Reflect having moved automake.
sp23/Makefile.am: Reflect having moved automake.
sp24/Makefile.am: Reflect having moved automake.
sp25/Makefile.am: Reflect having moved automake.
sp26/Makefile.am: Reflect having moved automake.
sp27/Makefile.am: Reflect having moved automake.
sp28/Makefile.am: Reflect having moved automake.
sp29/Makefile.am: Reflect having moved automake.
sp30/Makefile.am: Reflect having moved automake.
sp31/Makefile.am: Reflect having moved automake.
sp32/Makefile.am: Reflect having moved automake.
spfatal/Makefile.am: Reflect having moved automake.
spsize/Makefile.am: Reflect having moved automake.
base_mp/Makefile.am: Reflect having moved automake.
base_mp/node1/Makefile.am: Reflect having moved automake.
base_mp/node2/Makefile.am: Reflect having moved automake.
base_sp/Makefile.am: Reflect having moved automake.
cdtest/Makefile.am: Reflect having moved automake.
fileio/Makefile.am: Reflect having moved automake.
hello/Makefile.am: Reflect having moved automake.
loopback/Makefile.am: Reflect having moved automake.
minimum/Makefile.am: Reflect having moved automake.
paranoia/Makefile.am: Reflect having moved automake.
pppd/Makefile.am: Reflect having moved automake.
ticker/Makefile.am: Reflect having moved automake.
unlimited/Makefile.am: Reflect having moved automake.
psx01/Makefile.am: Reflect having moved automake.
psx02/Makefile.am: Reflect having moved automake.
psx03/Makefile.am: Reflect having moved automake.
psx04/Makefile.am: Reflect having moved automake.
psx05/Makefile.am: Reflect having moved automake.
psx06/Makefile.am: Reflect having moved automake.
psx07/Makefile.am: Reflect having moved automake.
psx08/Makefile.am: Reflect having moved automake.
psx09/Makefile.am: Reflect having moved automake.
psx10/Makefile.am: Reflect having moved automake.
psx11/Makefile.am: Reflect having moved automake.
psx12/Makefile.am: Reflect having moved automake.
psx13/Makefile.am: Reflect having moved automake.
psxcancel/Makefile.am: Reflect having moved automake.
psxchroot01/Makefile.am: Reflect having moved automake.
psxfile01/Makefile.am: Reflect having moved automake.
psxhdrs/Makefile.am: Reflect having moved automake.
psxmount/Makefile.am: Reflect having moved automake.
psxmsgq01/Makefile.am: Reflect having moved automake.
psxreaddir/Makefile.am: Reflect having moved automake.
psxsem01/Makefile.am: Reflect having moved automake.
psxstat/Makefile.am: Reflect having moved automake.
psxtime/Makefile.am: Reflect having moved automake.
psxtimer/Makefile.am: Reflect having moved automake.
mp01/Makefile.am: Reflect having moved automake.
mp01/node1/Makefile.am: Reflect having moved automake.
mp01/node2/Makefile.am: Reflect having moved automake.
mp02/Makefile.am: Reflect having moved automake.
mp02/node1/Makefile.am: Reflect having moved automake.
mp02/node2/Makefile.am: Reflect having moved automake.
mp03/Makefile.am: Reflect having moved automake.
mp03/node1/Makefile.am: Reflect having moved automake.
mp03/node2/Makefile.am: Reflect having moved automake.
mp04/Makefile.am: Reflect having moved automake.
mp04/node1/Makefile.am: Reflect having moved automake.
mp04/node2/Makefile.am: Reflect having moved automake.
mp05/Makefile.am: Reflect having moved automake.
mp05/node1/Makefile.am: Reflect having moved automake.
mp05/node2/Makefile.am: Reflect having moved automake.
mp06/Makefile.am: Reflect having moved automake.
mp06/node1/Makefile.am: Reflect having moved automake.
mp06/node2/Makefile.am: Reflect having moved automake.
mp07/Makefile.am: Reflect having moved automake.
mp07/node1/Makefile.am: Reflect having moved automake.
mp07/node2/Makefile.am: Reflect having moved automake.
mp08/Makefile.am: Reflect having moved automake.
mp08/node1/Makefile.am: Reflect having moved automake.
mp08/node2/Makefile.am: Reflect having moved automake.
mp09/Makefile.am: Reflect having moved automake.
mp09/node1/Makefile.am: Reflect having moved automake.
mp09/node2/Makefile.am: Reflect having moved automake.
mp10/Makefile.am: Reflect having moved automake.
mp10/node1/Makefile.am: Reflect having moved automake.
mp10/node2/Makefile.am: Reflect having moved automake.
mp11/Makefile.am: Reflect having moved automake.
mp11/node1/Makefile.am: Reflect having moved automake.
mp11/node2/Makefile.am: Reflect having moved automake.
mp12/Makefile.am: Reflect having moved automake.
mp12/node1/Makefile.am: Reflect having moved automake.
mp12/node2/Makefile.am: Reflect having moved automake.
mp13/Makefile.am: Reflect having moved automake.
mp13/node1/Makefile.am: Reflect having moved automake.
mp13/node2/Makefile.am: Reflect having moved automake.
mp14/Makefile.am: Reflect having moved automake.
mp14/node1/Makefile.am: Reflect having moved automake.
mp14/node2/Makefile.am: Reflect having moved automake.
cpuuse/Makefile.am: Reflect having moved automake.
malloctest/Makefile.am: Reflect having moved automake.
monitor/Makefile.am: Reflect having moved automake.
putenvtest/Makefile.am: Reflect having moved automake.
rtems++/Makefile.am: Reflect having moved automake.
rtmonuse/Makefile.am: Reflect having moved automake.
stackchk/Makefile.am: Reflect having moved automake.
termios/Makefile.am: Reflect having moved automake.
itronhello/Makefile.am: Reflect having moved automake.
itronmbf01/Makefile.am: Reflect having moved automake.
itronmbox01/Makefile.am: Reflect having moved automake.
itrontask01/Makefile.am: Reflect having moved automake.
itrontask02/Makefile.am: Reflect having moved automake.
itrontask03/Makefile.am: Reflect having moved automake.
itrontask04/Makefile.am: Reflect having moved automake.
itrontime01/Makefile.am: Reflect having moved automake.
* automake/compile.am, automake/host.am, automake/leaf.am
automake/local.am, automake/subdirs.am: New (copied from
../../../automake).
tools/Makefile.am: Reflect having moved automake.
lib/Makefile.am: Reflect having moved automake.
support/Makefile.am: Reflect having moved automake.
debug_ada/Makefile.am: Reflect having moved automake.
debug_c/Makefile.am: Reflect having moved automake.
dos_sup/Makefile.am: Reflect having moved automake.
network_ada/Makefile.am: Reflect having moved automake.
network_ada/adasockets/Makefile.am: Reflect having moved automake.
network_ada/listener/Makefile.am: Reflect having moved automake.
network_ada/tcprelay/Makefile.am: Reflect having moved automake.
ts_1325_ada/Makefile.am: Reflect having moved automake.
