* | doc/user Object Id Figures: Correct rotation and border | Joel Sherrill | 2013-02-26 | 4 | -42536/+8462 |
| | | | | | | | | | The 16 bit Object Id image was incorrectly rotated in the manual. Both the 16 and 32 Object Id bit images had thin borders on the table and the bottom line was not visible in the PDF. I tinkered with the original drawings to add a bit more space around the tables and manually converted the PNG to EPS using Gimp to ensure a controlled and high quality conversion. | ||||
* | doc/user/semaphore_attributes.eps: Correct rotation | Joel Sherrill | 2013-02-26 | 1 | -106459/+3742 |
* | doc/c_user: Fix Lines that were too long | Joel Sherrill | 2013-02-26 | 2 | -9/+9 |
* | doc: Use More Readable Names for Generated Nodes | Joel Sherrill | 2013-02-26 | 2 | -3/+7 |
| | | | | | | | | Per a discussion with the GNU Texinfo maintainer Patrice Dumas, change to generating HTML files per a standard for stable URL names and easier cross manual referencing. http://lists.gnu.org/archive/html/help-texinfo/2013-02/msg00002.html | ||||
* | doc: Support texi2any and texi2html | Joel Sherrill | 2013-02-26 | 5 | -19/+80 |
| | | | | | | | | | | | This was tested with texi2html-1.82-5.1.el6.noarch and a locally built texinfo 5.0. These are completely different implementations and require different invocations. The Makefile dependencies appear to work but are likely not perfect at this point. The key point is that the autoconf probe detects which to use and responds accordingly with preference given to texi2any. | ||||
* | doc: Update to build info format with texinfo 4.13 and 5.0 | Joel Sherrill | 2013-02-26 | 16 | -224/+231 |
| | | | | | Texinfo 5.0 is a complete reimplementation and has stricter interpretations of the texinfo language. | ||||
* | Add missing @item. | Ralf Corsépius | 2013-02-26 | 1 | -1/+1 |
* | Add missing @items. | Ralf Corsépius | 2013-02-26 | 1 | -3/+3 |
* | bsp/mpc55xx: Add register type definition | Sebastian Huber | 2013-02-25 | 1 | -1/+1 |
* | Fix typo. | Ralf Corsépius | 2013-02-25 | 2 | -2/+2 |
* | add __ARM_ARCH_6ZK__ to cpukit/score/cpu/arm/rtems/score/arm.h | Cudmore, Alan P. (GSFC-5820) | 2013-02-25 | 1 | -0/+4 |
* | libblock: Do resource allocation in one place | Sebastian Huber | 2013-02-21 | 3 | -148/+153 |
| | | | | | | | All resource allocations take place in rtems_bdbuf_init() now. After rtems_bdbuf_init() no fatal errors can happen due to configuration errors or resource limits. This makes it easier to detect configuration errors for users. | ||||
* | bsp/gen5200: New ATA driver | Sebastian Huber | 2013-02-20 | 10 | -45/+1566 |
| | | | | This is a replacement for the ATA task. The performance is much better. | ||||
* | bsp/gen5200: Add and use mpc5200_fatal() | Sebastian Huber | 2013-02-20 | 6 | -10/+27 |
* | bsp/mpc55xx: Fix prototype | Sebastian Huber | 2013-02-20 | 2 | -2/+2 |
* | dosfs: Fix file length update | Sebastian Huber | 2013-02-20 | 1 | -2/+3 |
* | fstests/fsrdwr: Add test case | Sebastian Huber | 2013-02-20 | 3 | -1/+59 |
* | fstests/fsrdwr: Fix warning | Sebastian Huber | 2013-02-20 | 1 | -1/+1 |
* | fstests: Prevent compiler optimizations | Sebastian Huber | 2013-02-15 | 1 | -1/+4 |
* | dosfs: Start scan with a valid data cluster | Sebastian Huber | 2013-02-15 | 1 | -26/+16 |
| | | | | | Simpify the loop. Set last cluster to an undefined value in case no free cluster exists. | ||||
* | dosfs: Fix file extend | Sebastian Huber | 2013-02-15 | 1 | -23/+24 |
| | | | | | | Only append a valid cluster chain (cluster added > 0), otherwise we overwrite the root directory cluster (cluster 0) of a FAT12 or FAT16 with arbitrary data. | ||||
* | dosfs: Ensure valid data cluster count | Sebastian Huber | 2013-02-15 | 1 | -1/+6 |
* | Introduce AM_CONDITIONAL ATOMIC. | Ralf Corsépius | 2013-02-14 | 7 | -14/+28 |
* | Introduce AM_CONDITIONAL ATOMIC, cpuopt RTEMS_ATOMIC. | Ralf Corsépius | 2013-02-14 | 1 | -0/+4 |
* | Conditionally install atomic-headers. | Ralf Corsépius | 2013-02-14 | 4 | -2/+8 |
* | Add RTEMS_CHECK_ATOMIC, RTEMS_CPUOPT([RTEMS_ATOMIC]), AM_CONDITIONAL ATOMIC. | Ralf Corsépius | 2013-02-14 | 1 | -0/+7 |
* | New. | Ralf Corsépius | 2013-02-14 | 1 | -0/+13 |
* | Include <stdint.h> | Ralf Corsépius | 2013-02-14 | 1 | -0/+2 |
* | ftpd: Go back to the root directory | Sebastian Huber | 2013-02-13 | 1 | -0/+8 |
* | make: Add default flags | Sebastian Huber | 2013-02-13 | 1 | -7/+4 |
* | make: Add CPPFLAGS | Sebastian Huber | 2013-02-13 | 1 | -0/+2 |
* | make: Remove -Wno-unused flag for debug variant | Sebastian Huber | 2013-02-13 | 1 | -1/+1 |
* | make: Remove -g flags | Sebastian Huber | 2013-02-13 | 1 | -3/+3 |
| | | | | The -g flag is set by the BSP. | ||||
* | make: Remove -qrtems_debug flag usage | Sebastian Huber | 2013-02-13 | 3 | -8/+4 |
* | bsps/powerpc: Remove unused files | Sebastian Huber | 2013-02-13 | 2 | -46/+0 |
* | score: use new alignment routine in object extend information. | Gedare Bloom | 2013-02-12 | 1 | -12/+16 |
* | score: New routines to align addresses up or down. | Gedare Bloom | 2013-02-12 | 1 | -0/+44 |
* | sptests/spfatal11: Update due to API changes | Sebastian Huber | 2013-02-12 | 2 | -5/+22 |
* | sapi: PR1911: Add CONFIGURE_DISABLE_BSP_SETTINGS | Sebastian Huber | 2013-02-12 | 3 | -0/+79 |
* | score: Add and use rtems_assert_context | Sebastian Huber | 2013-02-12 | 5 | -7/+52 |
* | bsp/lpc32xx: Add BSP_USB_OTG_TRANSCEIVER_VBUS | Sebastian Huber | 2013-02-12 | 1 | -0/+3 |
* | sparc64: revert linkcmds to 4 MB ram size | Gedare Bloom | 2013-02-11 | 1 | -2/+2 |
* | PR1560: _Objects_Extend_information improper alignment | Gedare Bloom | 2013-02-11 | 1 | -5/+18 |
| | | | | | | _Objects_Extend_information uses a sizeof(uint32_t) offset that leads to improper alignment in case the CPU (actually, heap) alignment is 8 or higher. The problem is solved by adding enough padding to align the sub-tables. | ||||
* | bsp/lpc24xx: Move UART probes to separate files | Sebastian Huber | 2013-02-11 | 6 | -53/+130 |
* | libchip/serial: Make NS16550 handler public | Sebastian Huber | 2013-02-11 | 5 | -18/+29 |
| | | | | This allows derived drivers to use these functions. | ||||
* | libchip/serial: Add const qualifier | Sebastian Huber | 2013-02-11 | 38 | -64/+64 |
* | libchip/serial: Fix warnings | Sebastian Huber | 2013-02-11 | 2 | -2/+13 |
* | libchip/serial: Fix warnings | Sebastian Huber | 2013-02-11 | 1 | -2/+1 |
* | libchip/serial: Fix warnings | Sebastian Huber | 2013-02-11 | 2 | -6/+9 |
* | bsp/erc32: Fix warnings | Sebastian Huber | 2013-02-11 | 1 | -2/+2 |
