* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 20 | -545/+72 |
| | | | | * Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2006-01-11 | 6 | -0/+364 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 34 | -68/+85 |
| | | | | | * configure.ac: Remove explicit ampolish3 support (now in RTEMS_BSP_CONFIGURE). | ||||
* | Cosmetics. | Ralf Corsepius | 2006-01-11 | 3 | -4/+1 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 2 | -4/+16 |
| | | | | | * aclocal/bsp-configure.m4: Add ampolish3. New header guards. | ||||
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@freenet.de> | Ralf Corsepius | 2006-01-11 | 2 | -7/+4 |
| | | | | * bspstart.am: Remove. | ||||
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 1 | -0/+4 |
| | | | | * libcsupport/src/error.c: include and use inttypes.h. | ||||
* | include and use inttypes.h. | Ralf Corsepius | 2006-01-10 | 1 | -2/+2 |
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 33 | -900/+139 |
| | | | | | * configure.ac: Add ampolish3 support. * Makefile.am: Add preinstall.am. | ||||
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 9 | -246/+33 |
* | New. | Ralf Corsepius | 2006-01-10 | 14 | -0/+1240 |
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 9 | -151/+33 |
* | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-10 | 2 | -0/+5 |
| | | | | * shared/start.S: Add include of bspopts.h so SIS quirks will trigger. | ||||
* | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-10 | 2 | -9/+14 |
| | | | | | * startup/linkcmds: Merge from 4.6 branch. Now the copy_data loop works. | ||||
* | New. | Ralf Corsepius | 2006-01-10 | 3 | -0/+178 |
* | Regenerate. | Ralf Corsepius | 2006-01-10 | 5 | -25/+25 |
* | 2006-10-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 2 | -100/+110 |
| | | | | * ampolish3.im: Update. | ||||
| | | | | * aclocal/bsp-alias.m4: Add sis as alias of erc32. | ||||
* | 2006-01-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-10 | 2 | -0/+11 |
| | | | | * configure.ac: Add configuration for ENABLE_SIS_QUIRKS. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-10 | 1 | -5/+6 |
* | 2006-01-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-09 | 3 | -1/+14 |
| | | | | | | PR 858/bsps * Makefile.am: Added vme_am_defs.h; * vme/vmeconfig.c: Added appropriate include files. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-09 | 1 | -5/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-09 | 1 | -34/+39 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 2 | -6/+5 |
| | | | | * Makefile.am: Don't include subdirs.am. Cleanup. | ||||
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 16 | -8/+32 |
| | | | | * Makefile.am: Don't include subdirs.am. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-09 | 1 | -0/+8 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 3 | -17/+18 |
| | | | | | * libchip/network/open_eth.c, libchip/network/open_eth.h: Merger from rtems-4-6-branch. | ||||
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 6 | -4/+2305 |
| | | | | | | | | * libchip/network/smc91111.c libchip/network/smc91111config.h libchip/network/smc91111exp.h libchip/network/smc91111.h: New. Merger from rtems-4-6-branch. * libchip/Makefile.am: Reflect adding smc91111*. | ||||
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 3 | -6/+12 |
| | | | | | | | * aclocal/bsp-alias.m4: Remove brs5l. Remove leon2. Alias leon1 to leon2. Add sis. * aclocal/check_bsps.m4: Remove brs5l. Remove leon. Add leon2. Add sis to erc32 family. | ||||
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 1 | -0/+5 |
| | | | | | * custom/leon1.cfg, custom/leon2.cfg, custom/leon3.cfg, sis.cfg: Merger from rtems-4-6-branch. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2006-01-09 | 4 | -9/+52 |
* | Regenerate. | Ralf Corsepius | 2006-01-09 | 1 | -2/+0 |
* | Remove. Sync with rtems-4-6-branch. | Ralf Corsepius | 2006-01-09 | 28 | -3531/+0 |
* | Backport from rtems-4-6-branch | Ralf Corsepius | 2006-01-09 | 1 | -7/+58 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 1 | -0/+4 |
| | | | | * shared/start.S: Backport from rtems-4-6-branch. | ||||
* | Cosmetics. | Ralf Corsepius | 2006-01-09 | 1 | -7/+7 |
* | Regenerate. | Ralf Corsepius | 2006-01-09 | 1 | -0/+4 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 1 | -0/+10 |
| | | | | | | | | | | | * leon_smc91111/leon_smc91111.c, README, timer/timer.c, startup/ithread.S, startup/setvec.c, startup/spurious.c, startup/linkcmds, startup/bspstart.c, console/console.c, console/debugputs.c, console/consolereserveresources.c, bsp_specs, amba/amba.c, gnatsupp/gnatsupp.c, include/coverhd.h, include/tm27.h, include/leon.h, include/bsp.h, include/amba.h, Makefile.am, configure.ac, times, leon_open_eth/leon_open_eth.c clock/ckinit.c: Backport from rtems-4-6-branch. | ||||
* | Backport from rtems-4-6-branch. | Ralf Corsepius | 2006-01-09 | 26 | -0/+2968 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 1 | -0/+9 |
| | | | | | | | | | | * leon_smc91111/leon_smc91111.c, README, timer/timer.c, startup/setvec.c, startup/spurious.c, startup/linkcmds, console/console.c, console/debugputs.c, console/consolereserveresources.c, bsp_specs, gnatsupp/gnatsupp.c, include/coverhd.h, include/tm27.h, include/leon.h, include/bsp.h, Makefile.am, configure.ac, times, leon_open_eth/leon_open_eth.c, clock/ckinit.c: Backport from rtems-4-6-branch. | ||||
* | Backport from rtems-4-6-branch. | Ralf Corsepius | 2006-01-09 | 30 | -0/+3428 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 2 | -0/+8 |
| | | | | | * Makefile.am, runtest.in, configure.ac: Backport from rtems-4-6-branch. | ||||
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 2 | -14/+19 |
| | | | | * libnetworking/rtems/rtems_mii_ioctl.h: Fix formatting. | ||||
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 2 | -2/+6 |
| | | | | * network/network.c: Remove warnings. | ||||
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 2 | -0/+6 |
| | | | | * acinclude.m4: Add gen5200 to list of BSPs. | ||||
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 3 | -0/+17 |
| | | | | | * Makefile.am, vme/vmeconfig.c: VME code now compiles but is untested. Jennifer will have to test this. | ||||
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 2 | -3/+8 |
| | | | | | * optman/sapi/no-io.c: Change rtems_io_register_name to take a const char *. | ||||
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 3 | -6/+11 |
| | | | | | * libcsupport/src/unixlibc.c, libfs/src/imfs/ioman.c: Change rtems_io_register_name to take a const char *. | ||||
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 3 | -2/+7 |
| | | | | | * sapi/include/rtems/io.h, sapi/src/io.c: Change rtems_io_register_name to take a const char *. | ||||
* | 2006-01-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-01-08 | 2 | -1/+5 |
| | | | | * user/io.t: Change rtems_io_register_name to take a const char *. |
