* startup/bspstart.c: Add capability for bootcard.c BSP Initialization
Framework to ask the BSP where it has memory for the RTEMS Workspace
and C Program Heap. These collectively are referred to as work area.
If the BSP supports this, then it does not have to include code to
split the available memory between the two areas. This reduces the
amount of code in the BSP specific bspstart.c file. Additionally, the
shared framework can initialize the C Library, call
rtems_debug_enable(), and dirty the work area memory. Until most/all
BSPs support this new capability, if the BSP supports this, it should
call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac.
When the transition is complete, this autoconf macro can be removed.
* configure.ac, startup/bspstart.c: Add capability for bootcard.c BSP
Initialization Framework to ask the BSP where it has memory for the
RTEMS Workspace and C Program Heap. These collectively are referred
to as work area. If the BSP supports this, then it does not have to
include code to split the available memory between the two areas.
This reduces the amount of code in the BSP specific bspstart.c file.
Additionally, the shared framework can initialize the C Library, call
* shared/startup/pretaskinghook.c: Add capability for bootcard.c BSP
* Makefile.am, configure.ac, startup/bspstart.c: Add capability for
bootcard.c BSP Initialization Framework to ask the BSP where it has
memory for the RTEMS Workspace and C Program Heap. These collectively
are referred to as work area. If the BSP supports this, then it does
not have to include code to split the available memory between the
two areas. This reduces the amount of code in the BSP specific
bspstart.c file. Additionally, the shared framework can initialize
the C Library, call rtems_debug_enable(), and dirty the work area
memory. Until most/all BSPs support this new capability, if the BSP
supports this, it should call
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When
* startup/bspstart.c, startup/bspstart.c.nocache: Add capability for
* shared/bspstart.c, shared/start.S: Add capability for bootcard.c BSP
* Makefile.am, configure.ac: Add capability for bootcard.c BSP
* csb336/startup/bspstart.c, csb337/startup/bspstart.c,
edb7312/startup/bspstart.c, gba/startup/bspstart.c,
gp32/startup/bspstart.c, rtl22xx/startup/bspstart.c: Add capability
for bootcard.c BSP Initialization Framework to ask the BSP where it
has memory for the RTEMS Workspace and C Program Heap. These
collectively are referred to as work area. If the BSP supports this,
then it does not have to include code to split the available memory
between the two areas. This reduces the amount of code in the BSP
specific bspstart.c file. Additionally, the shared framework can
initialize the C Library, call rtems_debug_enable(), and dirty the
work area memory. Until most/all BSPs support this new capability, if
the BSP supports this, it should call
* shared/m68kpretaskinghook.c: Add capability for bootcard.c BSP
Additionally, the shared framework can dirty the work area memory.
Until most/all BSPs support this new capability, if the BSP supports
this, it should call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from
its configure.ac. When the transition is complete, this autoconf
* shared/m68kbspgetworkarea.c: New file.
bspstart.c file. Additionally, the shared framework can dirty the
* new-exceptions/bspsupport/ppc_exc_bspsupp.h: added
comment about the semantics of the return value of
ppc_exc_handler_t.
* new-exceptions/bspsupport/irq.c: moved malloc/free
outside of irq-protected critical section.
* Makefile.am: Rework to avoid .rel files.
* user/conf.t: Fix text on CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER.
* libi2c/libi2c.h: Fix typo.
* pppd/example/system.h: Fix path in example -- NOT COMPILED WITH
CPUKIT.
* user/conf.t: Fix typo on
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
* tmoverhd/dumrtems.h: Refactored and renamed initialization routines
to rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* spfatal/fatal.c, spfatal06/testcase.h, spfatal07/testcase.h,
spfatal08/testcase.h, spfatal09/testcase.h, spfatal10/testcase.h:
Refactored and renamed initialization routines to
BSPs.
* bootcard.c: Refactored and renamed initialization routines to
BSPs.
* startup/bspstart.c: Refactored and renamed initialization routines to
BSPs.
* console/console.c, startup/bspstart.c: Refactored and renamed
initialization routines to rtems_initialize_data_structures,
rtems_initialize_before_drivers, rtems_initialize_device_drivers, and
BSPs.
* shared/bspstart.c: Refactored and renamed initialization routines to
BSPs.
* shared/startup/bspstart.c: Refactored and renamed initialization
BSPs.
* Makefile.am, startup/bspstart.c: Refactored and renamed
BSPs.
* startup/bspstart.c, startup/bspstart.c.nocache: Refactored and
renamed initialization routines to rtems_initialize_data_structures,
BSPs.
* sapi/include/rtems/init.h, sapi/src/exinit.c: Refactored and renamed
BSPs.
* network/tsec.c: removed memory input/output operands
which caused problems with gcc-4.3.0 (see
http://gcc.gnu.org/ml/gcc/2008-03/msg00976.html)
* sp32/init.c: Formatting.
PR 649/bsps
* clock/ckinit.c, console/console.c: Add missing structure element.
PR 649/bsps
* libchip/ide/ata.c: Give up if the interface does not become ready.
* console/console-io.c: Typo.
* console/config.c: Fix typo.
* clock/ckinit.c: Add nanoseconds clock tick granularity support.
* .cvsignore: New file.
* rtems.adb, rtems.ads: Fix prototype.
* sapi/src/exinit.c, score/src/threadstartmultitasking.c: Improve
comments.
* Makefile.am: Use shared bsp_predriver_hook.
* s3c24xx/clock/clockdrv.c: Use
rtems_configuration_get_microseconds_per_tick() rather than obsolete
BSP_Configuration reference.
* Makefile.am: Add smdk2410.
* acinclude.m4: Add smdk2410. Update gp32 to use shared code.
* include/bsp.h: Grammar.
