* tm01/Makefile.am, tm01/task1.c, tm02/Makefile.am, tm02/task1.c,
tm03/Makefile.am, tm03/task1.c, tm04/Makefile.am, tm04/task1.c,
tm05/Makefile.am, tm05/task1.c, tm06/Makefile.am, tm06/task1.c,
tm07/Makefile.am, tm07/task1.c, tm08/Makefile.am, tm08/task1.c,
tm09/Makefile.am, tm09/task1.c, tm10/Makefile.am, tm10/task1.c,
tm11/Makefile.am, tm11/task1.c, tm12/Makefile.am, tm12/task1.c,
tm13/Makefile.am, tm13/task1.c, tm14/Makefile.am, tm14/task1.c,
tm15/Makefile.am, tm15/task1.c, tm16/Makefile.am, tm16/task1.c,
tm17/Makefile.am, tm17/task1.c, tm18/Makefile.am, tm18/task1.c,
tm19/Makefile.am, tm19/task1.c, tm20/Makefile.am, tm20/task1.c,
tm21/Makefile.am, tm21/task1.c, tm22/Makefile.am, tm22/task1.c,
tm23/Makefile.am, tm23/task1.c, tm24/Makefile.am, tm24/task1.c,
tm25/Makefile.am, tm25/task1.c, tm26/Makefile.am, tm26/task1.c,
tm27/Makefile.am, tm27/task1.c, tm28/Makefile.am, tm28/task1.c,
tm29/Makefile.am, tm29/task1.c, tmck/Makefile.am, tmck/task1.c,
tmoverhd/Makefile.am, tmoverhd/testtask.c: Eliminate empty function
from every benchmark timer driver. Fix spelling.
* arm/at91rm9200/timer/timer.c, arm/lpc22xx/timer/timer.c,
arm/mc9328mxl/timer/timer.c, arm/s3c2400/timer/timer.c,
arm/s3c24xx/timer/timer.c, bfin/timer/timer.c,
m68k/mcf5206/timer/timer.c, m68k/mcf5272/timer/timer.c: Rename timer
driver methods to follow RTEMS programming conventions.
* sh7032/timer/timer.c, sh7045/timer/timer.c, sh7750/timer/timer.c:
Rename timer driver methods to follow RTEMS programming conventions.
* mpc505/timer/timer.c, mpc5xx/timer/timer.c, mpc6xx/timer/timer.c,
mpc8260/timer/timer.c, mpc8xx/timer/timer.c, ppc403/timer/timer.c:
* timer/timer.c: Rename timer driver methods to follow RTEMS
* mcf5206/timer/timer.c, mcf5206/timer/timerisr.S,
mcf5272/timer/timer.c, mcf5272/timer/timerisr.S: Rename timer driver
* at91rm9200/timer/timer.c, lpc22xx/timer/timer.c,
mc9328mxl/timer/timer.c, s3c2400/timer/timer.c,
s3c24xx/timer/timer.c: Rename timer driver methods to follow RTEMS
* tm01/task1.c, tm02/task1.c, tm03/task1.c, tm04/task1.c, tm05/task1.c,
tm06/task1.c, tm07/task1.c, tm08/task1.c, tm09/task1.c, tm10/task1.c,
tm11/task1.c, tm12/task1.c, tm13/task1.c, tm14/task1.c, tm15/task1.c,
tm16/task1.c, tm17/task1.c, tm18/task1.c, tm19/task1.c, tm20/task1.c,
tm21/task1.c, tm22/task1.c, tm23/task1.c, tm24/task1.c, tm25/task1.c,
tm26/task1.c, tm27/task1.c, tm28/task1.c, tm29/task1.c, tmck/task1.c,
tmoverhd/testtask.c: Rename timer driver methods to follow RTEMS
* timer/timer.c, timer/timerisr.S: Rename timer driver methods to
* timer/timer.c, timer/timerisr.c: Rename timer driver methods to
* console/console.c, include/m340timer.h, timer/timer.c: Rename timer
* bootcard.c: Fix formatting.
* console-polled.c: Error if minor < 2 not just <= 2.
* posix/Makefile.am, rtems/src/tasksetpriority.c: Improve comments and
wrapping.
* libchip/network/sonic.c: Do not declare a variable just to hold an
ignored return value.
* acinclude.m4: Add mcf52235 and mcf5329. Regenerate.
* acinclude.m4: Add bf537Stamp. Regenerate.
* Makefile.am, startup/bspstart.c: Use default bsp_pretasking_hook().
* ftpd/ftpd.c: Fix prototype.
* Makefile.am: Remove another duplicate reference.
* Makefile.am: Remove duplicate reference.
* shared/vme/vme_universe.c: added implementation for
BSP_VMEResetBus().
* vmeUniverse/vmeTsi148.h, vmeUniverse/vmeTsi148.c:
added vmeTsi148ResetBusXX(), vmeTsi148ResetBus().
* timer/timer.c: Eliminate rtems_boolean.
* libnds/include/nds/jtypes.h: Use bool/stdbool.h instead of
local (non-POSIX compliant) "bool".
* user/object.t: Correct order of arguments.
* Makefile.am: Remove stray include_HEADERS += irq/irq.h.
* libmisc/Makefile.am, libmisc/shell/shell.c, libmisc/shell/shell.h:
Split out rtems_shell_get_prompt() so it can be overridden by the
user.
* libmisc/shell/shell_getprompt.c: New file.
* lpc22xx/timer/timer.c: Remove broken bool implementation.
Remove unused vars.
Remove unused vars.
* libnetworking/libc/getproto.c, libnetworking/libc/getprotoent.c,
libnetworking/libc/getprotoname.c,
libnetworking/libc/getservbyname.c,
libnetworking/libc/inet_makeaddr.c, libnetworking/libc/recv.c,
libnetworking/libc/send.c: Stop using old-style
function-definitions.
