Update #2514.
Close #3174.
Return stack area via pthread_getattr_np().
Simplify
* pthread_attr_setaffinity_np(), and
* pthread_attr_getaffinity_np()
and let the scheduler do the more sophisticated error checks.
Make
* pthread_setaffinity_np(),
* pthread_getaffinity_np(),
available in all configurations.
Update #2514.
Close #3145.
Close #3168.
The timestamp are based on the uptime. There is no need for a 64-bit
seconds part. The signed 32-bit seconds part of the sbintime_t limits
the uptime to roughly 68 years.
Close #2740.
Use the timestamps only for uptime based values. Use struct timespec
for the absolute time values (TOD).
Update #2740.
Update #2740.
Use the saved MSR to account for FPU and AltiVec settings.
Update #2811.
Update #3111.
The removal of the Edison code removed the wrong part of the
conditional.
Closes #3172.
This was accidentally removed during a merge conflict by
89fc9345dea5c675f8d93546fa3c723918d3279a.
Update #3090.
Update #3090.
Update #3090.
Update #3090.
Update #3155.
Update #3155.
Update #3111.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
For semaphore object pointer and object validation see
POSIX_SEMAPHORE_VALIDATE_OBJECT().
Destruction or close of a busy semaphore returns an error status. The
object is not flushed.
POSIX semaphores are now available in all configurations and no longer
Update #2514.
Update #3116.
Reduce size of pthread_once_t and make it zero-initialized.
Update #3142.
This Newlib check ensures that we have a 64-bit time_t and
self-contained POSIX synchronization objects.
Update #2514.
Update #3111.
Update #3112.
Update #3113.
Update #3114.
Update #3115.
Update #3116.
The internal status codes encode a Classic rtems_status_code and error
codes used by the POSIX and C11/C++11 APIs. In case the POSIX API is
disabled, the C11/C++11 support must still work.
Close #3167.
Update #3164.
Update #3090.
Update #3090.
Update #3090.
Update #3090.
Close #3163.
The RTEMS_MILLISECONDS_TO_TICKS() macro doesn't round up. Do not use it
to calculate the program timeout in ticks. Check program done condition
after the timeout check to account for pre-emptions.
Update #3162.
Update #3161.
The refactoring of pci_dev_create() was incorrect since the code relied on
different defines before including pci/cfg.h. This reverts back to the
original code having two pci_dev_create() one in auto and one in read library.
confdefs.h selectes between the two libraries so both there is no link
conflict.
Updates #3029
Update #3082.
Update #3122.
Make the RBTree_Node layout independent of RTEMS_DEBUG (and all other
build configuration options). This allows the use of this structure in
Newlib.
Update #3112.
Rename struct Scheduler_Control to _Scheduler_Control to allow its use
in standard header files, e.g. <pthread.h>.
Update #3112.
Update #3090.
Update #3090.
Update #3090.
Pass all interrupt cells to bsp_fdt_map_intr() since some platforms use
an array to describe an interrupt.
Update #3090.
Update #3090.
