Refactored the i2c driver to parse register values from the device
tree rather than hardcoding them. But still the clocks have to
initialized manually.
A timer may be also reinitiated by the timer server fire directives.
Change license to BSD-2-Clause according to file histories and
documentation re-licensing agreement.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
Update #3899.
Update #3993.
This patch fixes issue #4338 by changing _TOD_Validate()
to only accept years till 2105. This requires another patch
to change the documentation of rtems_clock_set() and other
affected API functions (indicating the end date is 2105 not 2514).
I tried to support till year 2514 but it turned out that
this needs changing the Timer Manager too. That in turn
would mean to change _TOD_Seconds_since_epoch( void )
from 32 to 64 bit. Sebastian pointed out that a naive extension
leads to trouble with 32 bit processors. He deemed a safe
re-implementation too costly performance wise considering
that year 2106 is far away and current binaries using RTEMS
Classic API are unlikely to be in use by 2106.
The constant TOD_SECONDS_AT_2100_03_01_00_00 in
cpukit/rtems/src/clocktodtoseconds.c happens to be wrong by
1 hour. When setting the date 2100-Feb-28 23:59:59 and then
reading the date again you will find yourself in 2100-Feb-27.
Update #4338
Set the Main Stack Pointer (MSP) to the ISR stack area end just in case
we run using the Process Stack Pointer (PSP). This helps if
applications are started by a boot loader.
The multiplication to calculate the length of the memory area to
allocate may overflow. Return NULL in case of an overflow.
Close #4389.
Move RTEMS_Malloc_Sbrk_amount to the only implementation file which uses
it and make it private to hide implementation-details from an API
header.
Move rtems_calloc() since it only depends on rtems_malloc(). This may
make it easier to customize the heap allocator.
Change licence to BSD-2-Clause according to file history.
Update #3053.
This now uses rtems_clock_get_uptime_nanoseconds
to calculate the uptime ticks in milliseconds.
The links are already in spec/build/bsps/arm/stm32h7/grp.yml.
Last use was removed by:
commit 54550e048d3a49435912797d2024f80671e93267
Author: Sebastian Huber <sebastian.huber@embedded-brains.de>
Date: Fri May 13 08:16:30 2016 +0200
posix: Rework pthread_join()
Rework pthread_join() to use _Thread_Join().
The _CPU_ISR_Is_enabled() function operates on ISR cookies and so must
mask off the appropriate status bits. This also fixes the naming of the
parameters of the _CPU_ISR_* functions to indicate use of ISR cookies
instead of interrupt enable/disable levels.
Constantly reinitializing the Cadence UART on every character output
causes data corruption/loss on some ZynqMP hardware. Only initialize
the UART once for early output and give it a kick on startup.
enabled/disabled
* On some SMP platforms, all cpus are started by the
boot-loader. We need to block the secondary cpus or they
will clobber the test output.
This reverts commit 8383572963e261ea384cddfa43cd9606e7c23cdd.
This reverts commit 3299dda2454a8847c670a732f6c12ef1f2cc5dd0.
CID 1399752: Unused value in disp_hcms29xx_update_task().
Closes #4342
CID 1399751: Unused value in fastlz2_compress().
Closes #4341
CID 1255346: Unused value in rtems_shell_ls_printacol().
Closes #4340
CID 1255344: Unused value in copy().
Closes #4339
Update #3850
Update #3850
Update #3850
Update #3850
Update #3850
Update #3850
Update #3850
Update #3850
Update #3850
Update #3850
Update #3850
The directive returns RTEMS_UNSATISFIED if the semaphore's count already
had the maximum value of UINT32_MAX.
Fix warning:
testsuites/validation/tc-signal-send.c:634:21: warning: unused variable
'sc' [-Wunused-variable]
Fix warning:
testsuites/libtests/block14/init.c:198:8: warning: 'sc' may be used
uninitialized in this function [-Wmaybe-uninitialized]
Update #3689.
Replace Objects_Name_or_id_lookup_errors with new Status_Control codes.
Get rid of the _Status_Object_name_errors_to_status lookup table.
The value of STATUS_CLASSIC_INTERNAL_ERROR must be equal to
RTEMS_INTERNAL_ERROR. Add static assertions to ensure that the status
codes match.
Update #4372
