* custom/HPUX9-posix.cfg: Remove.
* aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Remove pck6 BSP.
* custom/pck6.cfg: Remove.
* libnetworking/lib/ftpfs.c: Enable write and mount filesystem
with read-write access.
* ftpd/ftpd.c: Change SIX_MONTHS to time_t.
* sapi/include/rtems/io.h: Move extern "C" brace after includes.
* libnetworking/net/if_ppp.h: Eliminate pppattach, pppintr
(Unused).
* libnetworking/net/if_ppp.c: Eliminate pppintr (Unused).
* Makefile.am: Add -D__BSD_VISIBLE to wifi_rel_CPPFLAGS.
* libnetworking/rtems/rtems_dhcp.c: Remove #define KERNEL.
* libnetworking/Makefile.am, libnetworking/rtems/rtems_bsdnet.h,
Remove -D_COMPILING_BSD_KERNEL_ (Unused).
* libnetworking/Makefile.am: Remove -DKERNEL.
* libnetworking/rtems/rtems_mii_ioctl.c: Remove #undef KERNEL.
* libnetworking/nfs/bootp_subr.c: #include <sys/ucred.h>.
* libcsupport/include/sys/ioccom.h: Remove #define KERNEL,
#define _KERNEL.
* libfs/src/nfsclient/src/rpcio.c,
libfs/src/nfsclient/src/sock_mbuf.c,
libfs/src/nfsclient/src/xdr_mbuf.c: Remove #define KERNEL.
* libfs/src/dosfs/fat_file.h, libfs/src/dosfs/fat_fat_operations.h:
* posix/src/barrierattrdestroy.c, posix/src/barrierattrinit.c,
posix/src/condbroadcast.c, posix/src/conddefaultattributes.c,
posix/src/condsignal.c, posix/src/condtimedwait.c,
posix/src/condwait.c, posix/src/key.c, posix/src/keycreate.c,
posix/src/keydelete.c, posix/src/keyrundestructors.c,
posix/src/killinfo.c, posix/src/mqueue.c,
posix/src/mqueuecreatesupp.c, posix/src/mqueueopen.c,
posix/src/mqueuereceive.c, posix/src/mqueuerecvsupp.c,
posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c,
posix/src/mqueueunlink.c, posix/src/mutex.c,
posix/src/mutexattrdestroy.c, posix/src/mutexinit.c,
posix/src/mutexlock.c, posix/src/mutextimedlock.c,
posix/src/mutextrylock.c, posix/src/pbarrier.c,
posix/src/prwlock.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c,
posix/src/prwlockwrlock.c, posix/src/psignalunblockthread.c,
posix/src/pspin.c, posix/src/pspinlock.c,
posix/src/pspintrylock.c, posix/src/pthread.c,
posix/src/pthreadattrdestroy.c, posix/src/pthreadcreate.c,
posix/src/pthreadinitthreads.c, posix/src/pthreadkill.c,
posix/src/pthreadonce.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer.c, posix/src/rwlockattrdestroy.c,
posix/src/rwlockattrinit.c, posix/src/semaphore.c,
posix/src/semaphorecreatesupp.c, posix/src/semdestroy.c,
posix/src/semopen.c, posix/src/semtrywait.c,
posix/src/semunlink.c, posix/src/semwait.c:
Eliminate TRUE/FALSE.
* aclocal/bspopts.m4: Quoting cosmetics.
* GT64260/GT64260TWSI.h: Add missing prototypes.
Incorporate newlib inttypes.h changes.
* Makefile.am, configure.ac: Add sp48 which tests that configuring for
unlimited objects when configured for a unified workspace works as
expected.
* sp48/.cvsignore, sp48/Makefile.am, sp48/init.c, sp48/sp48.doc,
sp48/sp48.scn: New files.
* score/include/rtems/score/object.h: Maximum index if 0xffff not 0xff
when using 32-bit ids. This resulted in unlimited configurations not
being able to create more than 255 objects of a class.
PR 1359/cpukit
* libcsupport/src/libio.c: rtems_libio_allocate:
rtems_libio_iop_freelist incorrectly zeroed on semaphore error. Now
checks error and does not modify anything until sure it has created
semaphore.
PR 1363/filesystem
* libfs/src/dosfs/fat.h: Fix issue where 32 bit values are not written
correctly in FAT f/s data.
* bsp_howto/console.t: Clarify interrupt transmit process.
* user/concepts.t: Typo.
