* | updates from Tony Bennett. | Joel Sherrill | 1996-05-23 | 3 | -118/+154 |
| | | | | | Broke the setjmp/longjmp pair in the context switch into a separate routine so no code depended on local variables surviving the jump. | ||||
* | created posix test suite with test of header files | Joel Sherrill | 1996-05-22 | 102 | -0/+2758 |
* | Modified to correct variables which defined the range of object classes | Joel Sherrill | 1996-05-22 | 3 | -3/+3 |
| | | | | which are tasks. | ||||
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 31 | -14/+52 |
| | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. | ||||
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 7 | -23/+59 |
| | | | | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. The removed files were moved to newlib as they were duplicates of files already included there. | ||||
* | This commit was generated by cvs2svn to compensate for changes in r257, | Ralf Corsepius | 1996-05-21 | 2 | -0/+1574 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | Import from zlib-1.2.4 | Ralf Corsepius | 1996-05-21 | 2 | -0/+1574 |
* | added posix test directory | Joel Sherrill | 1996-05-10 | 2 | -6/+16 |
* | fixed typo | Joel Sherrill | 1996-05-10 | 2 | -2/+2 |
* | updated to remove workaround for bug in binutils 2.5.2 ld now that we are | Joel Sherrill | 1996-05-08 | 1 | -4/+4 |
| | | | | up to 2.6 | ||||
* | *** empty log message *** | Joel Sherrill | 1996-05-08 | 2 | -2/+4 |
* | Updated version to 3.5.15. | Joel Sherrill | 1996-05-02 | 2 | -2/+2 |
* | Updates from Eric Norum. | Joel Sherrill | 1996-05-01 | 7 | -106/+268 |
* | Updates from Eric Norum to use the mcpu32 flags and fix comments. | Joel Sherrill | 1996-05-01 | 4 | -84/+45 |
* | changed version number to 3.5.14 | Joel Sherrill | 1996-04-24 | 2 | -2/+2 |
* | Hacked so gld will accept this so we can purge the aout toolset. This change | Joel Sherrill | 1996-04-24 | 1 | -2/+21 |
| | | | | should be undone when the m68k-coff cross toolset is updated next time. | ||||
* | added comment regarding stack alignment issues to thread stack allocation | Joel Sherrill | 1996-04-24 | 2 | -0/+28 |
| | | | | routine. | ||||
* | Lowered number of messages created to reduce burden on workspace. | Joel Sherrill | 1996-04-22 | 2 | -2/+2 |
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 88 | -622/+494 |
* | addition of optional user provided stack allocator means that we can not | Joel Sherrill | 1996-04-22 | 2 | -28/+54 |
| | | | | | reliably produce the "insufficient memory for stack space" error if this extension is configured. | ||||
* | Updates from Tony Bennett. | Joel Sherrill | 1996-04-22 | 16 | -95/+110 |
* | Updates from Tony Bennett. rtems_environp removed among other minor things. | Joel Sherrill | 1996-04-22 | 1 | -1/+0 |
* | Fixed so now supports more than 16 nodes. Tested for up to 24 nodes | Joel Sherrill | 1996-04-22 | 5 | -3/+21 |
| | | | | by Tony Bennett. Information table is now malloc'ed. | ||||
* | thread.c: added support for optional user provided stack allocator | Joel Sherrill | 1996-04-22 | 4 | -16/+246 |
| | | | | wkspace.c: made initialization routine a regular subroutine | ||||
* | made initialization routine a regular subroutine | Joel Sherrill | 1996-04-22 | 6 | -264/+0 |
* | interr.h: added stack allocater error code | Joel Sherrill | 1996-04-22 | 6 | -3/+45 |
| | | | | wkspace.h: made initialization routine a regular subroutine | ||||
* | added stack allocation fields to the cpu table | Joel Sherrill | 1996-04-22 | 3 | -54/+124 |
| | | | | | updates from Tony Bennett. Most were to insure all variables were properly initialized and to correct the stray signal number reporting. | ||||
* | added stack allocation fields to the cpu table | Joel Sherrill | 1996-04-22 | 4 | -18/+16 |
* | added stack allocation fields to the cpu table | Joel Sherrill | 1996-04-22 | 5 | -3/+2705 |
| | | | | added CPU_M68K_EXTB_L model flag | ||||
* | added stack allocation fields to the cpu table | Joel Sherrill | 1996-04-22 | 1 | -0/+3 |
* | updartes from Tony Bennett | Joel Sherrill | 1996-04-22 | 5 | -676/+209 |
* | swapped order of operands on a movw to fix LOAD_SEGMENTS macro | Joel Sherrill | 1996-04-20 | 1 | -1/+1 |
* | event.c: _Event_Manager_initialization no longer a static inline | Joel Sherrill | 1996-04-19 | 4 | -0/+58 |
| | | | | sem.c: modified to eliminate Purify warnings | ||||
* | _Event_Manager_initialization no longer a static inline | Joel Sherrill | 1996-04-19 | 3 | -57/+0 |
* | event.h: _Event_Manager_initialization no longer a static inline | Joel Sherrill | 1996-04-19 | 3 | -57/+0 |
* | event.h: _Event_Manager_initialization no longer a static inline | Joel Sherrill | 1996-04-19 | 6 | -0/+36 |
| | | | | support.h: updated to use RTEMS_APPLICATION macro | ||||
* | modified to generate fatal error when an unconfigured directive is invoked. | Joel Sherrill | 1996-04-19 | 24 | -8/+794 |
* | changes to compile in macro configuration without warnings. | Joel Sherrill | 1996-04-19 | 9 | -6/+72 |
* | minor mods to get to compile locally | Joel Sherrill | 1996-03-21 | 2 | -3/+4 |
* | some instructions altered for older binutils | Joel Sherrill | 1996-03-21 | 2 | -16/+16 |
* | updated | Joel Sherrill | 1996-03-21 | 1 | -15/+0 |
* | *** empty log message *** | Joel Sherrill | 1996-03-21 | 5 | -14/+8 |
* | updated for 68302 and so gen68360 bsp would compile | Joel Sherrill | 1996-03-21 | 4 | -3/+19 |
* | update to reflect internal threads reorganization | Joel Sherrill | 1996-03-21 | 2 | -0/+44 |
* | updated to reflect gen68360 from Eric Norum. | Joel Sherrill | 1996-03-21 | 1 | -0/+4 |
* | include of mc68360.h changed to m68360.h to reflect filename change. | Joel Sherrill | 1996-03-06 | 4 | -4/+4 |
* | Added 68360 support submitted by W. Eric Norum (eric@skatter.usask.ca). | Joel Sherrill | 1996-03-06 | 2 | -2/+12 |
| | | | | Also increased minimum stack size from 1K to 2K. | ||||
* | Generic 68360 BSP (gen360) submitted by: W. Eric Norum <eric@skatter.usask.ca>. | Joel Sherrill | 1996-03-06 | 12 | -0/+2355 |
| | | | | | | | | | | | Contact information: W. Eric Norum Saskatchewan Accelerator Laboratory 107 North Road University of Saskatchewan Saskatoon, Saskatchewan, CANADA S7N 5C6 | ||||
* | As part of reducing visibility into rtems and hiding the .inl files | Joel Sherrill | 1996-03-06 | 28 | -0/+28 |
| | | | | | from the application code, this file required more visibility than is given by default to application code. | ||||
* | Removed prototyes for static inline routines and moved the comments into | Joel Sherrill | 1996-03-06 | 238 | -10301/+3638 |
| | | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana. |
