* | Base file | Joel Sherrill | 1998-04-03 | 4 | -1/+53 | |
* | Changed Perl executable location | Joel Sherrill | 1998-04-03 | 2 | -2/+2 | |
* | Base files from texi2www-960103 | Joel Sherrill | 1998-04-03 | 4 | -0/+2122 | |
* | Added constants through ch13 | Joel Sherrill | 1998-04-02 | 11 | -446/+459 | |
* | Make sure OAR logo is accessible | Joel Sherrill | 1998-04-02 | 1 | -0/+1 | |
* | Added egcs 1.0.2 gcc docs | Joel Sherrill | 1998-04-02 | 1 | -1/+1 | |
* | Corrected wildcard for info files | Joel Sherrill | 1998-04-02 | 1 | -1/+2 | |
* | Went back to not printing an index. makeinfo does fine if you have indices | Joel Sherrill | 1998-04-02 | 2 | -5/+7 | |
| | | | | but do not print them. texi2dvi barfs if the entries are even there. | |||||
* | Added "findex" for all directive pages but it turns out that this | Joel Sherrill | 1998-04-02 | 18 | -4/+98 | |
| | | | | blows up both makeinfo and texi2dvi. So I have commented them out. | |||||
* | Added copy of HELP.html. | Joel Sherrill | 1998-04-02 | 1 | -1/+1 | |
* | Added newlib to support and ada_user to internal. | Joel Sherrill | 1998-04-02 | 1 | -2/+2 | |
* | changed version to 4.0.0-beta2 | Joel Sherrill | 1998-03-31 | 2 | -2/+2 | |
* | Fixed CUSTOM_FILES rule so it properly picked up files included from | Joel Sherrill | 1998-03-31 | 1 | -2/+11 | |
| | | | | make/custom files. | |||||
* | Make.config | Joel Sherrill | 1998-03-31 | 1 | -1/+3 | |
* | Added "sigemptyset()" call to insure that the memcmp() would work. | Joel Sherrill | 1998-03-31 | 2 | -0/+8 | |
| | | | | | It appears that the new glibc does not clear all the bits of the signal set with a sigprocmask. | |||||
* | Taking care of minor build problems | Joel Sherrill | 1998-03-30 | 4 | -6/+5 | |
* | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1998-03-30 | 15 | -218/+115 | |
* | Corrected distribution levels for html | Joel Sherrill | 1998-03-30 | 14 | -15/+19 | |
* | Added distribution level to each manual | Joel Sherrill | 1998-03-30 | 13 | -20/+39 | |
* | Added 4th icon | Joel Sherrill | 1998-03-30 | 1 | -2/+0 | |
* | Added directories | Joel Sherrill | 1998-03-30 | 1 | -0/+3 | |
* | Added support for multiple distribution levels. | Joel Sherrill | 1998-03-30 | 1 | -4/+15 | |
* | Mediocre graphic just to use as a place holder to show what it looks like. | Joel Sherrill | 1998-03-30 | 1 | -0/+0 | |
* | Made the POSIX API option follow the configure line. | Joel Sherrill | 1998-03-30 | 1 | -3/+1 | |
* | Made the HAS_POSIX_API follow the configure line option. | Joel Sherrill | 1998-03-30 | 1 | -5/+0 | |
* | Made the C++ option follow the configure option. | Joel Sherrill | 1998-03-30 | 1 | -9/+0 | |
* | Made HAS_POSIX_API have a "no" definition when it is not enabled. | Joel Sherrill | 1998-03-30 | 1 | -0/+2 | |
* | Made C++ follow the configure option. | Joel Sherrill | 1998-03-30 | 1 | -4/+0 | |
* | Were looking at the wrong C++ variable. | Joel Sherrill | 1998-03-30 | 1 | -1/+1 | |
* | Moved bsp_postdriver_hook() to a shared file and made it a common | Joel Sherrill | 1998-03-30 | 47 | -666/+118 | |
| | | | | component. | |||||
* | Renamed crt0.o to crt0_go32.o to avoid build problems. | Joel Sherrill | 1998-03-30 | 1 | -1/+1 | |
* | Update from "erik.ivanenko" <erik.ivanenko@utoronto.ca>. | Joel Sherrill | 1998-03-30 | 12 | -130/+1432 | |
| | | | | | Also removed bsp_postdriver_hook() from every bsp possible and moved to shared version. | |||||
* | GO32 does not have sockets. | Joel Sherrill | 1998-03-27 | 1 | -0/+2 | |
* | Added dependency so html would build from scratch. | Joel Sherrill | 1998-03-27 | 1 | -1/+1 | |
* | Corrected by adding "end markers". | Joel Sherrill | 1998-03-27 | 1 | -8/+9 | |
* | Changed int to unsigned32 to match cpu.h. | Joel Sherrill | 1998-03-27 | 2 | -2/+2 | |
* | Nodes, menus, etc are automatically generated now | Joel Sherrill | 1998-03-27 | 24 | -1883/+176 | |
* | Renamed extra_manuals to oar_manuals. | Joel Sherrill | 1998-03-27 | 1 | -3/+2 | |
* | Removed ruler line since it is automatically inserted now along with | Joel Sherrill | 1998-03-27 | 1 | -1/+0 | |
| | | | | the buttons at the bottom. | |||||
* | Localized for use in doc tree. | Joel Sherrill | 1998-03-27 | 1 | -2/+7 | |
* | Added directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 1 | -0/+2 | |
* | Completed sweep adding directive and constant prefixes. | Joel Sherrill | 1998-03-27 | 22 | -613/+830 | |
* | Should have included <rtems.h> before checking for ifdef RTEMS_UNIX. | Joel Sherrill | 1998-03-27 | 3 | -6/+6 | |
| | | | | Bug report from Olivier Hainque <hainque@inf.enst.fr> on SPARC Solaris 2.6. | |||||
* | Conditionally adding RTEMS_ and rtems_ prefixes. | Joel Sherrill | 1998-03-27 | 17 | -554/+554 | |
* | Added Hitachi SH | Joel Sherrill | 1998-03-27 | 6 | -58/+60 | |
* | Attempting to add variable so that in C all constants start with RTEMS_ | Joel Sherrill | 1998-03-27 | 9 | -89/+160 | |
| | | | | and all directives start with rtems_. | |||||
* | Added POSIX 1003.1h and PowerPC supplement to internal manuals. | Joel Sherrill | 1998-03-27 | 1 | -2/+2 | |
* | New file. Basically m68k version with Hitachi SH comments thrown in. | Joel Sherrill | 1998-03-26 | 1 | -0/+102 | |
* | The script did not handle public distributions at all. | Joel Sherrill | 1998-03-26 | 1 | -1/+8 | |
* | Added support for easily building different sets of the manuals | Joel Sherrill | 1998-03-26 | 1 | -7/+27 | |
| | | | | for the public, support, partners, and internal use. |
