that addresses the librdbg/rpcgen related problems:
* All rpcgen generated files are now kept inside of the source tree
* Fix librdbg/configure to correctly detect presence of rpcgen and awk
* Use rpcgen -m to generated remdeb_svc.c
* Remove msgout/_msgout from awk.svc
* minor cleanups to librdbg/configure.in
ATTENTION --- IMPORTANT:
* With keeping rpc-generated files pre-build inside of the source tree,
you as the packager of RTEMS have to ensure that timestamps are
correctly set up: The generated files must not be older than the *.x
files.
* This is extraordinarily important when
- putting the package on read-only media
- after checking out from CVS
- after modifications to the *.x files
* If one of the *.x files is modified you have to either
- build for i386/pc386 and powerpc/mcp750
- or to invoke the same rpcgen calls as the
librdbg/src/<cpu>/<bsp>/Makefile.am do manually
before checking-in the files to CVS.
Proposal:
We could add something to bootstrap for touching the rpcgen-generated
sources and/or to manually regenerate them.
NOTE FROM JOEL:
Ralf proposed modifying bootstrap to handle rpcgen. I think this
is the best solution as it is something already done in the
snapshot procedure.
were done by Joel.
were done by Joel.
because of the conversion to automake and replaced by a Makefile.am.
The message queue manager chapter needs to be updated to reflect
completion of the implementation.
and _CORE_message_queue_Insert_message for posix message queues.
+ Yellow line tested new source
Added correct include file.
and memory layout. Next step is to share the same bsp_pretasking_hook.
+ Yellow lined tested routine with Posix message queue test (01)
+ Added messsage size check
+ Debugged and yellowed out routine
+ Yellow line tested source.
+ Removed extra flag attribute from message queue structure.
+ Yellow-lined all posix message queue routines.
queues as well as the messages.
that converts the libbsp/i386 subdirectory to full automake.
for the gen68360 that let it work with ELF and C++ exceptions. This
was used as the basis for changes to EVERY m68k bsp_specs and linkcmds.
Before this modification is over, the layout of the starting stack,
heap, and workspace will likely be modified for every m68k BSP. Then
they will all be very similar.
that fixes the following problems:
1. Removing bogus ';' in some configure.in (cosmetical fix)
2. Moves GAS_CODE16 checks to libbsp/i386/*/configure.in (essential fix)
#2 was responsible for the gcc/binutils-2.9.5 choking while building for
the pc386.
expansion. These macros were modified to correct warnings and
obviously needed more parentheses to expand correctly.
must deal with a pending process oriented signal. Prior to the addition
of this testcase, sigtimedwait() did not return properly when a process
oriented signal was pending. The problem was reported by Wayne
Bullaughey <wayneb@cacdsp.com>.
was pending. Reported by Wayne Bullaughey <wayneb@cacdsp.com>.
of the mask when disabling the interrupt.
registers.
