* configure.ac: Check of __assert().
* libcsupport/src/__assert.c: Conditionally build __assert().
* bootcard.c: Swap order of RTEMS Workspace and Malloc Heap. This
allows the potential for sbrk() to extend the heap area. This
actually is done on PowerPC BSPs with more than 32MB which use
dynamic loading.
* configure.ac: Check for creat().
* libcsupport/src/creat.c: Build conditionally.
* include/bsp.h: Added missing include.
PR 1391/bsps
* startup/spurious.c: Format was %d but had leading 0x.
PR 1376/filesystem
* libcsupport/include/rtems/libio.h, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/msdos.h, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_file.c, libfs/src/imfs/deviceio.c,
libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_directory.c,
libfs/src/imfs/imfs_fifo.c, libfs/src/imfs/memfile.c,
libfs/src/nfsclient/src/nfs.c: lseek handlers should return off_t.
* score/inline/rtems/score/heap.inl: Use the correct fields and do end
- begin.
to have been mangled. I believe that the this version fixes things.
* include/bsp.h, start/start.S, startup/bspstart.c:
removed BSP_INIT_STACK_SIZE -- this BSP now also uses
__stack defined by the linker script for the initial
stack.
Removed legacy code (inherited from old mvme2307 BSP
but not relevant to this one) that tested trapping
into PPCBug.
* startup/misc.c, flash/flashcfg.c, irq/irq_init.c,
pci/detect_host_bridge.c: changed function arguments
to silence compiler warnings.
* bootcard.c: use aligned heap_start (instead of
original heap_start) when calculating default heap
size (to take into account loss due to alignment).
* vmeUniverse/vmeTsi148.h, vmeUniverse/vmeTsi148.c:
fixed function declarations to silence compiler
warnings.
robust against erroneous external exception disable times.
* libcsupport/src/malloc_initialize.c: Fixed invalid function
parameter.
* Makefile.am, console/console.c: Use shared polled console framework.
* Makefile.am, preinstall.am, include/bsp.h, startup/setvec.c: Now
compiles again but applications do not link.
PR 1375/bsps
* clock/clock.c: Correct implementation of nanoseconds since last tick
handler.
* cpu_asm.S: Eliminate extern of unused variables.
* libcsupport/src/malloc_initialize.c, score/Makefile.am,
score/include/rtems/score/protectedheap.h,
score/inline/rtems/score/heap.inl: Get total heap size correct when
using unified C Program Heap and RTEMS Workspace.
* score/src/pheapgetsize.c: New file.
* cdtest/main.cc: Use printk() in global destructors since printf() no
longer works.
PR 1390/bsps
* startup/linkcmds: Fix sections so C++ global constructors and
destructors work with late model (>= 4.3) gcc versions.
* shared/irq/irq_asm.S: Newer compilers handle alignment better.
PR 1380/bsps
* include/bsp.h: Switch to English comments.
PR 1388/cpukit
* sp09/screen05.c, sp09/screen09.c, sp09/sp09.scn: Classic Semaphores
allow both priority inherit and ceiling attributes to be set on
semaphore create. These attributes are mutually exclusive and this
should be an error.
PR 1388/cpukit
* rtems/src/semcreate.c: Classic Semaphores allow both priority inherit
and ceiling attributes to be set on semaphore create. These
attributes are mutually exclusive and this should be an error.
* user/.cvsignore: Add Object ID PDF files.
* cpu.c: Remove stray semi-colon.
* Makefile.am: Remove unnecessary copy of cpu_asm.S
* console/Modif_cpu_asm.S: Removed.
* rtems/score/cpu.h: AVR stack grows down.
* posix_users/preface.texi, shell/preface.texi: Add stock
acknowledgement paragraphs that are required when excerpting and
reusing text from POSIX standards per the agreement at
* common/opengroup_manpage_acknowledgement.texi,
common/opengroup_preface_acknowledgement.texi: New files.
