* | 2006-04-18 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-18 | 8 | -4/+20 |
| | | | | * aclocal/version.m4: Updated to rtems-4.6.99.3. | ||||
* | Fixed comment. | Joel Sherrill | 2006-04-13 | 1 | -1/+4 |
* | 2006-04-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-13 | 1 | -1/+1 |
| | | | | | | | | PR 949/networking * libnetworking/sys/socket.h: GNU/Linux is wrong in making MSG_DONTWAIT public. It is strictly BSD and not SUSV. See http://www.opengroup.org/onlinepubs/009695399/basedefs/sys/socket.h.html for clarification. | ||||
* | 2006-04-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-13 | 1 | -0/+5 |
| | | | | | PR 949/networking * libnetworking/sys/socket.h: | ||||
* | 2006-04-12 Lars Munch <lars@segv.dk> | Joel Sherrill | 2006-04-12 | 2 | -1/+6 |
| | | | | | PR 949/networking * libnetworking/sys/socket.h: Make MSG_DONTWAIT public as in GNU/Linux. | ||||
* | 2006-04-12 Konrad Eisele <konrad@gaisler.com> | Joel Sherrill | 2006-04-12 | 2 | -0/+6 |
| | | | | * include/leon.h: Add LEON_INTERRUPT_EXTERNAL_1 define. | ||||
* | Add default exception handler. | Eric Norum | 2006-04-11 | 2 | -1/+57 |
* | Keep the frame pointer since its presence makes various diagnostic tools | Eric Norum | 2006-04-10 | 2 | -1/+5 |
| | | | | much more useful. | ||||
* | 2006-04-06 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-07 | 6 | -8/+22 |
| | | | | | | | | * posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/timer.inl, posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/mutex.inl, posix/macros/rtems/posix/timer.inl: Fix warnings. | ||||
* | * score/inline/rtems/score/threadmp.inl, | Joel Sherrill | 2006-04-07 | 3 | -0/+5 |
| | | | | score/macros/rtems/score/threadmp.inl: Fix compile error. | ||||
* | Fix formatting. | Joel Sherrill | 2006-04-05 | 1 | -2/+2 |
* | 2006-04-05 Victor V. Vengerov <Victor.Vengerov@oktetlabs.ru> | Joel Sherrill | 2006-04-05 | 2 | -4/+17 |
| | | | | * mpc6xx/clock/c_clock.c: Now works with MPCI SHM driver. | ||||
* | 2006-04-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-05 | 2 | -2/+10 |
| | | | | | | | | | | Victor V. Vengerov <Victor.Vengerov@oktetlabs.ru> * spsize/size.c: Victor spotted the problem that _MPCI_Receive_server_tcb and _Thread_MP_Receive were duplicate variables and needed to be set to the same value. I took that idea and just removed _Thread_MP_Receive. All uses are now _MPCI_Receive_server_tcb. | ||||
* | 2006-04-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-04-05 | 7 | -15/+27 |
| | | | | | | | | | | | | | | Victor V. Vengerov <Victor.Vengerov@oktetlabs.ru> * score/include/rtems/score/mpci.h, score/include/rtems/score/threadmp.h, score/inline/rtems/score/threadmp.inl, score/macros/rtems/score/threadmp.inl, score/src/threadmp.c, score/src/threadqenqueue.c: Victor spotted the problem that _MPCI_Receive_server_tcb and _Thread_MP_Receive were duplicate variables and needed to be set to the same value. I took that idea and just removed _Thread_MP_Receive. All uses are now _MPCI_Receive_server_tcb. | ||||
* | 2006-04-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-04-02 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove bogus CFLAGS_OPTIMIZE_V. | ||||
* | Eliminate undesired sign-extension. | Eric Norum | 2006-03-27 | 2 | -1/+5 |
* | Add missing reset cause bit. | Eric Norum | 2006-03-24 | 2 | -0/+5 |
* | This commit was generated by cvs2svn to compensate for changes in r13387, | Ralf Corsepius | 2006-03-23 | 1 | -0/+12 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2006-03-23 | 1 | -0/+12 |
| * | Import from zlib-1.2.4 | Ralf Corsepius | 2006-03-03 | 1 | -4/+4 |
* | | New. | Ralf Corsepius | 2006-03-23 | 1 | -0/+3 |
* | | Add defaults for non-standard $prefix. | Ralf Corsepius | 2006-03-23 | 1 | -2/+7 |
* | | 2006-03-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-22 | 6 | -0/+27 |
| | | | | | | | | * include/.cvsignore: New file. | ||||
* | | 2006-03-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-17 | 2 | -6/+17 |
| | | | | | | | | | | | | * shared/interrupts/vectorexceptions.c: Merger with submission from Bruce Robinson <brucer@pmccorp.com>. Make some arrays static const. | ||||
* | | Apply @sysdirpattern@ | Ralf Corsepius | 2006-03-17 | 2 | -1/+7 |
* | | Use %sysdir instead of %if %_prefix ==|!= /usr | Ralf Corsepius | 2006-03-17 | 12 | -41/+27 |
* | | Misc. cosmetics. | Ralf Corsepius | 2006-03-17 | 17 | -77/+24 |
* | | Remove eof include file | Ralf Corsepius | 2006-03-17 | 79 | -79/+0 |
* | | 2006-03-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-17 | 2 | -1/+6 |
| | | | | | | | | * cpu.c (_CPU_Initialize): Add fpu initialization. | ||||
* | | 2006-03-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-17 | 2 | -0/+14 |
| | | | | | | | | | | * rtems/score/cpu.h: Setup CPU_*_ENDIAN from GCC's__MIPS{EL|EB}__. (Partial merger of submission by Bruce Robinson <brucer@pmccorp.com>). | ||||
* | | Regenerate. | Ralf Corsepius | 2006-03-16 | 1 | -0/+14 |
* | | Cosmetics. | Ralf Corsepius | 2006-03-16 | 1 | -8/+0 |
* | | 2006-03-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 3 | -0/+46 |
| | | | | | | | | * Makefile.am, configure.ac: Reflect addition of rm52xx, tx49. | ||||
* | | 2006-03-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 1 | -0/+8 |
| | | | | | | | | | | | | | | | | * rm52xx/include/rm5231.h, rm52xx/vectorisrs/maxvectors.c, rm52xx/vectorisrs/vectorisrs.c, tx49/include/tx4925.h, tx49/include/tx4938.h, tx49/vectorisrs/maxvectors.c, tx49/vectorisrs/vectorisrs.c: New (Submission by Bruce Robinson <brucer@pmccorp.com>). | ||||
* | | New (Submission by Bruce Robinson <brucer@pmccorp.com>). | Ralf Corsepius | 2006-03-16 | 7 | -0/+543 |
* | | Regenerate. | Ralf Corsepius | 2006-03-16 | 1 | -2/+6 |
* | | AC_CONFIG_SRCDIR(csb350). | Ralf Corsepius | 2006-03-16 | 1 | -1/+1 |
* | | 2006-03-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 1 | -1/+3 |
| | | | | | | | | | | * configure.ac: AC_CONFIG_SRCDIR(csb350). * acinclude.m4: Regenerate. | ||||
* | | New. | Ralf Corsepius | 2006-03-16 | 1 | -0/+58 |
* | | Add preinstall.am | Ralf Corsepius | 2006-03-16 | 1 | -48/+1 |
* | | New (Submission by Bruce Robinson <brucer@pmccorp.com>). | Ralf Corsepius | 2006-03-16 | 23 | -0/+4984 |
* | | Add preinstall.am | Ralf Corsepius | 2006-03-16 | 2 | -100/+2 |
* | | New (Submission by Bruce Robinson <brucer@pmccorp.com>) | Ralf Corsepius | 2006-03-16 | 21 | -0/+3722 |
* | | New. | Ralf Corsepius | 2006-03-16 | 1 | -0/+62 |
* | | New (Submission by Bruce Robinson <brucer@pmccorp.com>). | Ralf Corsepius | 2006-03-16 | 28 | -0/+4472 |
* | | 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 4 | -0/+109 |
| | | | | | | | | | | * custom/hurricane.cfg, custom/rbtx4925.cfg, custom/rbtx4938.cfg: New (Submission by Bruce Robinson <brucer@pmccorp.com>). | ||||
* | | 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 2 | -7/+1 |
| | | | | | | | | * README: Remove (obsolete). | ||||
* | | 2006-03-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-03-16 | 1 | -0/+4 |
| | | | | | | | | * acinclude.m4: Remove p4000. | ||||
* | | Remove (abandoned). | Ralf Corsepius | 2006-03-16 | 27 | -3477/+0 |
