* libnetworking/rtems/rtems_bsdnet.h: Eliminate rtems_* fixed size
types.
* Makefile.am, configure.ac, acinclude.m4: Remove.
* bsp_specs, clock/clockdrv.c, configure.ac,
console/console.c, console/console.h, include/bsp.h,
include/tm27.h, Makefile.am, README, start/start.S,
startup/bspclean.c, startup/bspstart.c, startup/linkcmds,
startup/setvec.c, timer/timer.c, timer/timerisr.c, times: Remove.
* include/gen2.h: Changed rtems_unsigned types to uint types
* libchip/network/open_eth.c, libchip/serial/mc68681.c,
libchip/serial/ns16550.c, libchip/serial/z85c30.c: Removed warning
* console/init68360.c, include/bsp.h, startup/bspstart.c: Changed
* rtems/score/powerpc.h: Removed warning
* libchip/network/dec21140.c, libchip/network/elnk.c,
libchip/network/if_fxp.c: Moved irq.h to bsp subdirectory.
* clock/ckinit.c, console/console.c, include/bsp.h, network/ne2000.c:
* Makefile.am, comm/i386-stub-glue.c, comm/tty_drv.c, comm/uart.c,
irq/idt.c, irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c: Moved
irq.h and irq_asm.h to bsp subdirectory.
* 3c509/3c509.c, clock/ckinit.c, console/console.c, console/fb_vga.c,
console/inch.c, console/ps2_mouse.c, console/serial_mouse.c,
ne2000/ne2000.c, timer/timer.c, wd8003/wd8003.c: Moved irq.h to bsp
subdirectory.
* clock/ckinit.c, console/console.c, include/bsp.h, startup/bspstart.c:
* libnetworking/net/if.h: Revert include of sys/mbuf.h in this .h file
since it causes other problems.
* libcsupport/src/termios.c: Removed warnings.
* libnetworking/net/if.h, libnetworking/net/if_ppp.c,
libnetworking/net/ppp_tty.c: Removed warnings.
* libblock/src/blkdev.c, libfs/src/dosfs/fat_file.c,
libfs/src/dosfs/fat_file.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_create.c, libfs/src/dosfs/msdos_dir.c,
libfs/src/dosfs/msdos_initsupp.c, libfs/src/dosfs/msdos_misc.c:
Removed warnings.
* tmtests/tmoverhd/tmtest.adb: Removed warnings.
* pci/pci.h: Add pci_bus_count().
* mpc8xx/console-generic/console-generic.c: Added parameter to ISRs.
* irq/irq_init.c, network/network.c: Fix calls/routines to match
prototypes. Modified when a parameter was added to ISRs.
* sptests/sp04/sptest.adb, tmtests/tm02/tmtest.adb,
* gccnewlib/gccnewlib.add: Further clean up of tools not supported
by individual targets. Add %build_libgcj.
* gccnewlib/target-gcc.add: Remove dep to base-gcc.
* include/rtems/pci.h: Name change to support common PCI interface
* libchip/network/dec21140.c, libchip/network/elnk.c: Consolidation
of code as a result of the implementation of a common PCI interface.
* irq/irq_init.c, pci/pci.c, pci/pcifinddevice.c, startup/bspstart.c:
* irq/irq_init.c: Name change to support common PCI interface
* include/tm27.h: Correct error in tm27 test
* pci/pci.c, pci/pci.h, startup/bspstart.c: Name change to support
* clock/p_clock.c, irq/irq.c, irq/irq_init.c: Addition of a parameter
to ISRs
* irq/irq_init.c, startup/bspstart.c: Name modification for generic pci
interface
* pci/pcibios.c, pci/pcibios.h: Corrected spacing
Name modifications for a generic PCI interface
Added wrapper routines for pci read/write configuration data
* rtems/score/m68k.h: Change _ColdFire_VBR to _VBR.
* libchip/network/open_eth.c: Remove prototype of set_vector.
* startup/init5282.c: Remove use of _Coldfire_VBR and use _VBR as rest
of m68k family.
* rtems/score/cpu.h: Change definition of _VBR to a simple pointer.
* rtems/score/m68k.h: Remove use of _Coldfire_VBR.
* cpu.c: Remove warning.
* mc9328mxl/irq/irq.c, s3c2400/irq/irq.c: Remove warnings.
* mpc8260/cpm/dpram.c, mpc8260/timer/timer.c, mpc8xx/cpm/dpram.c:
Remove warnings.
* librdbg/src/ptrace.c: Remove warning.
* libcsupport/include/ringbuf.h: Use uint8_t instead of char for raw
data buffer.
* rtems/src/regiongetfreeinfo.c: Return RTEMS_SUCCESSFUL instead of
RTEMS_INVALID_ADDRESS on success path.
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_load_tar.c: Use uint8_t
instead of char for raw data buffer.
* samples/hello/sptest.adb, sptests/sp03/sptest.adb,
sptests/sp04/sptest.adb, sptests/sp05/sptest.adb,
sptests/sp07/sptest.adb, sptests/sp13/sptest.adb,
sptests/sp14/sptest.adb, sptests/sp20/sptest.adb,
sptests/sp24/sptest.adb, tmtests/tm01/tmtest.adb,
tmtests/tm02/tmtest.adb, tmtests/tm03/tmtest.adb,
tmtests/tm04/tmtest.adb, tmtests/tm05/tmtest.adb,
tmtests/tm06/tmtest.adb, tmtests/tm07/tmtest.adb,
tmtests/tm08/tmtest.adb, tmtests/tm09/tmtest.adb,
tmtests/tm10/tmtest.adb, tmtests/tm11/tmtest.adb,
tmtests/tm12/tmtest.adb, tmtests/tm13/tmtest.adb,
tmtests/tm14/tmtest.adb, tmtests/tm15/tmtest.adb,
tmtests/tm16/tmtest.adb, tmtests/tm17/tmtest.adb,
tmtests/tm18/tmtest.adb, tmtests/tm19/tmtest.adb,
tmtests/tm20/tmtest.adb, tmtests/tm21/tmtest.adb,
tmtests/tm22/tmtest.adb, tmtests/tm23/tmtest.adb,
tmtests/tm24/tmtest.adb, tmtests/tm25/tmtest.adb,
tmtests/tm28/tmtest.adb, tmtests/tm29/tmtest.adb,
tmtests/tmck/tmtest.adb, tmtests/tmoverhd/dummy_rtems.adb,
tmtests/tmoverhd/tmtest.adb: Remove warnings.
* rtems.adb: Remove gcc 4.x warnings.
* include/.cvsignore: New file.
* .cvsignore: New file.
