* mpc6xx/mmu/bat.c: Per PR241, fix a tiny bug introduced by the
fix for an earlier patch (PR213) which added support for setting
BAT0 to setdbat().
* Templates/Makefile.leaf: Clarify the MANAGERS example.
* aclocal/subdirs.m4: Remove.
* acinclude.m4: New (Replaces aclocal/subdirs.m4).
* src/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/xdr/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/rpc/Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* kern/Makefile.am: Use .$(OBJEXT) instead of .o.
* lib/Makefile.am: Ditto.
* libc/Makefile.am: Ditto.
* net/Makefile.am: Ditto.
* netinet/Makefile.am: Ditto.
* nfs/Makefile.am: Ditto.
* rtems/Makefile.am: Ditto.
* wrapup/Makefile.am: Ditto.
* src/dosfs/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/src/imfs/Makefile.am: Ditto.
* startup/bspstart.c: Per PR252 removed hack that tripled size of
RTEMS Workspace when POSIX is configured. This was probably done to
account for confdefs.h missing some application requirements.
* configure.ac: AC_CONFIG_SRCDIR([../libmisc]).
* aclocal/check-cpu.m4: Peek into cpukit/score/cpu instead of
exec/score/cpu.
* binutils/Makefile.am: Add or32-rtems-binutils.
* wrapup/Makefile.am: Use project_libdir instead of
$(PROJECT_RELEASE)/lib. Eliminate LIBNAME. Pickup *.o's instead of
*.rels for CPU_OBJS. Manually create $(project_libdir)$(MULTISUBDIR).
* src/xdr/Makefile.am: Eliminate LIBNAME.
* src/rpc/Makefile.am: Eliminate LIBNAME.
* src/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES.
* automake/lib.am: Use project_libdir instead of
* configure.ac: Remove RTEMS_ENABLE_MULTIPROCESSING,
RTEMS_ENABLE_POSIX, RTEMS_ENABLE_ITRON, RTEMS_ENABLE_INLINES,
RTEMS_ENABLE_RTEMS_DEBUG, RTEMS_CHECK_RTEMS_DEBUG,
RTEMS_CHECK_NEWLIB.
* acinclude.m4: Add test "$multilib" != "yes".
* config-ml.in: Remove.
* src/Makefile.am: Eliminate LIBNAME. Cosmetical cleanups.
* aclocal/bsp-configure.m4: Add RTEMS_CHECK_MULTIPROCESSING.
* automake/compile.am: Add test -d $(ARCH) || mkdir $(ARCH) to all
compilation rules (Work-around to an automake bug).
* automake/lib.am: Add test -d $(ARCH) || mkdir $(ARCH) to
make-library.
* aclocal/env-rtemsbsp.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE.
Add project_libdir, libdir. New GCC_SPECS. Various cleanups.
* aclocal/env-rtemscpu.m4: Remove RTEMS_BSP_SPECS, PROJECT_RELEASE.
* aclocal/rtems-top.m4: New PROJECT_ROOT handling.
* automake/compile.am: Remove RTEMS_BSP_SPECS, LD* flags, LINK,
references to bsp_specs. Use project_libdir instead of
* configure.ac: Activate cpukit. Remove references to c/src/exec.
* kern/Makefile.am: Eliminate LIBNAME.
* src/dosfs/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES and
AM_CFLAGS. Eliminate LIBNAME.
* src/imfs/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES and
* wrapup/Makefile.am: Eliminate LIBNAME.
* Makefile.am: Eliminate LIBNAME. Use AM_CPPFLAGS instead of
INCLUDES (Upcoming automake standard).
* Makefile.am: Eliminate LIBNAME. Cosmetical cleanups.
* src/Makefile.am: Add bsplib_DATA. Eliminate LIBNAME. Cosmetical
changes.
* acinclude.m4: Cleanups.
* configure.ac: Build ${srcdir}/../../cpukit/ as ./exec/ instead of
${srcdir}/exec/.
Further adaptations to autoconf >= 2.50.
* Makefile.am: Fix oversights in previous patch.
* startup/Makefile.am: Reformat.
* rtems.S: Remove.
* Makefile.am: Reflect having removed rtems.S. Use AM_CPPFLAGS
instead of INCLUDES (Latest automake standard).
* start/Makefile.am: Fix bug in previous patch.
Really add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
Fix bsplib_DATA = $(PROJECT_RELEASE)/lib/rxgen_romld$(LIB_VARIANT).o.
(Didn't make it into cvs at 2002-07-20 :( )
* start/Makefile.am: Eliminate PGMS.
bsplib_DATA += $(PROJECT_RELEASE)/lib/except_vect_332_ROM$(LIB_VARIANT).o
bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init$(LIB_VARIANT)
bsplib_DATA += $(PROJECT_RELEASE)/lib/ram_init_FW$(LIB_VARIANT)
Add bsplib_DATA = $(PROJECT_RELEASE)/lib/rxgen_romld$(LIB_VARIANT).o.
* start/Makefile.am: Remove leftover from eliminating PGM.
