* custom/jmr3904.cfg: Use -m3900 not -mips3. TX3904 is actually
a mips1. gcc translates -m3900 into that.
* mw-fb/mw_uid.c: Removed unnecessary dependency on <bsp.h>.
* cache/Makefile.am: Removed automake warning by introducing a
simple variable.
* erc32sonic/Makefile.am: Only compile this if networking is enabled.
* src/msgqsubmit.c: Modified multiprocessing conditional so
this would compile with both macros and inlines.
* macros/rtems/rtems/sem.inl: Added macro implementation of
_Semaphore_Get_interrupt_disable().
* inline/rtems/posix/mqueue.inl: Removed explicit dependency on abs().
* README: Updated to reflect current status. Misaligned reference
during initialization may be compiler problem.
* console/console-io.c: Added support for printk().
* startup/linkcmds: Reserve 512K for RTEMS Workspace.
* General effort to make things compile with macros not inlines
* inline/rtems/score/coremutex.inl: Added comment indicating
for macros there is another copy of
_CORE_mutex_Seize_interrupt_trylock() in src/coremutexseize.c.
* src/coremutexseize.c: Added body of
_CORE_mutex_Seize_interrupt_trylock() for macro case.
* macros/rtems/score/coremutex.inl: Added prototype for
_CORE_mutex_Seize_interrupt_trylock() since there is a real
body when macros are enabled.
* macros/rtems/score/coresem.inl: Added macro implementation of
_CORE_semaphore_Seize_isr_disable.
* macros/score/Makefile.am: Fixed typos.
* rtems/score/address.inl: Correct macro implementation of
_Addresses_Is_aligned() so it would compile.
* macros/rtems/score/coremsg.inl: Added closing parentheses.
* cpu_asm.S: Changed "_CPU_Ccontext_switch_restore: typo to
correct name of _CPU_Context_switch_restore. Added dummy
version of exc_utlb_code() so applications would link.
* include/rtems/Makefile.am: Added termiostypes.h.
* libc/Makefile.am: Removed termiostypes.h.
* libc/termios.c: Changed include of "termiostypes.h" to
<rtems/termiostypes.h> since that is an RTEMS specific header file.
* modem/ppp_tty.c: Changed to include <rtems/termiostypes.h> since
* sys/ttycom.h: Moved to lib/include/sys.
* Makefile.am: Modified to reflect above.
* include/sys/ttycom.h: New file -- moved from libnetworking/sys.
* src/imfs/memfile.c: Bug report from Sturniolo Jose
<jsturnio@nec.com.ar> where NULL pointer was dereferenced.
* libc/getcwd.c: Ensure _closedir(dir) is called even on
error exit from the routine.
* src/heapallocate.c: Do not allow the size to overflow when
adjusting it. A test allocated a stack of -1 (~0). This
actually resulted in a stack being allocated but with a
size of 0xb. The allocator did not test the size to see if
it rolled through 0 and so allowed the allocation to happen, the
thread to get created. The task crashed as you would expect.
* README, sim68000.setup, clock/clockdrv.c: Modified to add
support for timer as clock tick source. Compiles but untested.
* libc/termiostypes.h: New file -- missed in earlier commits.
* custom/jmr3904.cfg: Fix incorrect reference to i960.
* libc/res_init.c: Fix typo - adding missing # on include.
* cache/cache.h: Fix reference to MC68040 and put in stubs
for missing support routines. The functionality of these
routines needs to be addressed.
* startup/linkcmds: Fix typo and add extra 0 to base address.
Now runs until printf() tries to put a character and then
it locks up checking a status bit that does not change.
* configure.in: Change mips64orion reference to mips.
* start/start.S, startup/bspstart.c: Not functional for CPU32
but hopefully will compile now and give a warning saying that
the CPU32 variant needs work.
* src/sysconf.c: Add support for _SC_CLK_TCK and _SC_OPEN_MAX.
* custom/shsim.cfg: New file.
* custom/Makefile.am: Modified to reflect addition of shsim.cfg.
The shsim is for the SH simulator in gdb. It should be able
to be used with multiple SH CPU models. This will require
adding BSP variants.
* The shsim is for the SH simulator in gdb. It should be able
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, clock/.cvsignore, clock/Makefile.am,
clock/clockdrv.c, console/.cvsignore, console/Makefile.am,
console/console-io.c, console/console-support.S,
start/.cvsignore, start/Makefile.am, start/regs.S,
start/start.S, startup/.cvsignore, startup/Makefile.am,
startup/bspstart.c, startup/linkcmds, wrapup/.cvsignore,
wrapup/Makefile.am: New files.
* config.guess, config.sub: Update from CVS-autoconf to pick
up new features (e.g. CC_FOR_BUILD in config.guess) but is
necessary anyway to use autoconf-versions > 2.13.
* wrapup/Makefile.am: Added modem subdir.
* configure.in, Makefile.am: Added modem subdir.
* net/Makefile.am: Added if_pppvar.h, pppcompress.h.
* pppd/Makefile.am: Added pppmain.c (which needs work).
* pppd/chat.c, pppd/fsm.c, pppd/fsm.h, pppd/ipxcp.c, pppd/main.c,
pppd/ppp_tty.c, pppd/upap.c: Changes from Thomas Doerfler
<Thomas.Doerfler@imd-systems.de> and cosmetic changes by me.
Actually main.c and ppp_tty.c should be scratched. The modem
subdir has the real ppp_tty.c and the real pppd main is in pppmain.c.
* custom/pc386.cfg: make-exe rule would write into
$(PROJECT_RELEASE) area. This is not cool because it $(PROJECT_RELEASE)
is generally not writeable after the BSP is installed and you do not
want every application installed there by default. Reported by
Eric Norum <eric.norum@usask.ca>.
* libc/res_init.c: Move include to avoid compiler dumping core.
* libc/termios.c, libc/termiostypes.h: Task driver driver model
and line discipline support from Thomas Doerfler
<Thomas.Doerfler@imd-systems.de>.
* The JMR BSP is for a Toshiba TX39 evaluation board but
can also be used with the mips simulator in gdb.
console/console-io.c, include/.cvsignore,
include/Makefile.am, include/bsp.h, start/.cvsignore,
start/Makefile.am, start/regs.S, start/start.S,
startup/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/linkcmds, wrapup/.cvsignore, wrapup/Makefile.am: New files.
* TESTED: Added jmr3904 entry.
* custom/Makefile.am: Updated to add jmr3904.cfg
* custom/jmr3904.cfg: New file.
* TESTED: Added new sparc variations (erc32, leon, and Tharsys).
* cpu_asm.S: Fix for CPUs with FPU revision B or C.
* erc32sonic/erc32sonic.c: Minor modifications which enable
network interface to come up and work for some time before
getting an error in the SONIC driver. The error is a bit random,
sometimes MCLGET (m, M_WAIT) tries to access memory way outside the
available ram (and traps) while sometimes there is a panic due
to RBAE/RXEN.
* psxstat/test.c, psxstat/psxstat.scn: Forced inode numbers
to remain consistant across platforms and bsps by forcing
a mount point in front of all paths.
2000-11-17 Jennifer Averret <jennifer@OARcorp.com>
* psxmount/test.c, psxmount/psxmount.scn: Improve output to report
expected error condition in one case.
* psxreaddir/test.c, psxreaddir.scn: Added test cases to exercise
readdir() of root of mounted filesystem. Also corrected the screen
file for some mistakes noticed in this effort.
* itrontask01/system.h: Configure enough stack memory.
* libc/mount.c: Make sure there is space allocated for a device name
in the mount table entry.
* src/imfs/imfs_eval.c: Always return imaginary node at mount points.
* libc/mount.c (search_mt_for_mount_point): Deleted routine.
* libc/mount.c (Is_node_fs_root): Replacement for above that
accounts for the imaginary root node being returned by the
filesystem evaluation routine.
* libc/unmount.c (unmount): Account for imaginary root node
being returned and improved variable names to clarify code.
* libc/unmount.c (file_systems_below_this_mountpoint): Body of
routine replaced to account for imaginary root node being returned.
