* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+5 |
| | | | | | * base_sp/apptask.c, unlimited/init.c: Use PRIdrtems_task_argument to print rtems_task_argument's. | ||||
* | Use PRIdrtems_task_argument to print rtems_task_argument's. | Ralf Corsepius | 2009-10-27 | 8 | -18/+18 |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+6 |
| | | | | | | * sp44/init.c, sp35/priinv.c, sp33/init.c, sp28/init.c, sp12/pritask.c, sp34/changepri.c: Use PRIdrtems_task_argument to print rtems_task_argument's. | ||||
| | | | | | * support/include/tmacros.h: Add PRIdThread_Entry_numeric_type. Add PRIdrtems_task_argument. | ||||
* | Add PRIdThread_Entry_numeric_type. | Ralf Corsepius | 2009-10-27 | 1 | -0/+5 |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+2 |
| | | | | | * sp25/task1.c: segment_size is uintptr_t. * spfatal06/testcase.h: Add missing return. | ||||
* | segment_size is uintptr_t. | Ralf Corsepius | 2009-10-27 | 1 | -3/+3 |
* | Add missing return. | Ralf Corsepius | 2009-10-27 | 1 | -0/+1 |
| | | | | | * psxenosys/init.c: Add missing args in calls to execl, execlp, execle. | ||||
* | Add missing args in calls to execl, execlp, execle. | Ralf Corsepius | 2009-10-27 | 1 | -3/+3 |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+4 |
| | | | | | | | | | * psxhdrs/pthread36.c: Use HAVE_DECL_PTHREAD_ATTR_GETCPUTIME. * psxhdrs/pthread35.c: Use HAVE_DECL_PTHREAD_ATTR_SETCPUTIME. * psx07/init.c: Use HAVE_DECL_PTHREAD_ATTR_GETCPUTIME, HAVE_DECL_PTHREAD_ATTR_SETCPUTIME. * configure.ac: Add AC_CHECK_DECLS pthread_attr_getcputime, pthread_attr_setcputime. | ||||
* | Use HAVE_DECL_PTHREAD_ATTR_GETCPUTIME. | Ralf Corsepius | 2009-10-27 | 1 | -0/+6 |
* | Use HAVE_DECL_PTHREAD_ATTR_SETCPUTIME. | Ralf Corsepius | 2009-10-27 | 1 | -0/+6 |
* | Use HAVE_DECL_PTHREAD_ATTR_GETCPUTIME, HAVE_DECL_PTHREAD_ATTR_SETCPUTIME. | Ralf Corsepius | 2009-10-27 | 1 | -0/+12 |
* | Add AC_CHECK_DECLS pthread_getcputime, pthread_setcputime. | Ralf Corsepius | 2009-10-27 | 1 | -0/+8 |
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+3 |
| | | | | | | * sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c, sp07/tstart.c: Duplicate code from rtems_name_to_characters to convert rtems_name's into char arrays. | ||||
* | Duplicate code from rtems_name_to_characters to convert rtems_name's into ↵ | Ralf Corsepius | 2009-10-27 | 4 | -20/+44 |
| | | | | char arrays. | ||||
* | 2009-10-27 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-27 | 1 | -0/+7 |
| | | | | | | | * sp09/screen13.c: Comment out unused return status. * sp63/init.c: Use PRIu32 to print uint32_t's. * sp33/init.c: Use PRIu32 to print uint32_t's. * sp28/init.c: Use PRIu32 to print uint32_t's. | ||||
* | Comment out unused return status. | Ralf Corsepius | 2009-10-27 | 1 | -1/+1 |
* | Use PRIu32 to print uint32_t's. | Ralf Corsepius | 2009-10-27 | 4 | -8/+8 |
| | | | | * tmck/task1.c: Use PRIu32 to print uint32_t's. | ||||
| | | | | | | | * psxtimer01/psxtimer.c: Use %ld to print *.tv_nsec. * psxsysconf/init.c: Use %ld to print *.tv_nsec. * psxclock/init.c: Use %ld to print *.tv_nsec. * psx06/init.c, psx06/system.h: Misc. warning fixes. | ||||
* | Use %ld to print *.tv_nsec. | Ralf Corsepius | 2009-10-27 | 3 | -10/+10 |
* | Misc. warning fixes. | Ralf Corsepius | 2009-10-27 | 2 | -2/+2 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+2 |
| | | | | | * sp31/task1.c: Use PRIdWatchdog_Interval to print Watchdog_Interval's. | ||||
* | Use PRIdWatchdog_Interval to print Watchdog_Interval's. | Ralf Corsepius | 2009-10-26 | 1 | -6/+6 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+5 |
| | | | | | * sp20/task1.c, sp32/init.c, spclockget/init.c: Use PRIdrtems_interval to print rtems_interval's. | ||||
* | Use PRIdrtems_interval to print rtems_interval's. | Ralf Corsepius | 2009-10-26 | 3 | -5/+5 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 2 | -1/+11 |
| | | | | | * support/include/tmacros.h: Add PRIdWatchdog_Interval. Add PRIdrtems_interval. | ||||
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+1 |
| | | | | * sp13/task1.c: Misc. uint32_t fixes. | ||||
* | Misc. uint32_t fixes. | Ralf Corsepius | 2009-10-26 | 2 | -11/+11 |
| | | | | * sp20/task1.c: Misc. uint32_t fixes. | ||||
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+4 |
| | | | | | | | * sp47/init.c: Add PRIXModes_Control, PRIXrtems_mode. Use PRIXrtems_mode to print rtems_mode's. * sp08/system.h: Add PRIxModes_Control, PRIxrtems_mode. Use PRIxrtems_mode to print rtems_mode's. | ||||
* | Add PRIXModes_Control, PRIXrtems_mode. | Ralf Corsepius | 2009-10-26 | 1 | -1/+4 |
| | | | | Use PRIXrtems_mode to print rtems_mode's. | ||||
* | Add PRIxModes_Control, PRIxrtems_mode. | Ralf Corsepius | 2009-10-26 | 1 | -1/+4 |
| | | | | | * sp19/first.c, sp19/fptask.c, sp19/fptest.h, sp19/inttest.h, sp19/task1.c: Add missing PRI*32's. | ||||
* | Add missing PRI*32's. | Ralf Corsepius | 2009-10-26 | 5 | -6/+6 |
| | | | | | * sp34/changepri.c, sp35/priinv.c: Use PRIdPriority_Control to print Priority_Control's. | ||||
* | Use PRIdPriority_Control to print Priority_Control's. | Ralf Corsepius | 2009-10-26 | 2 | -2/+2 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 2 | -1/+9 |
| | | | | | * support/include/tmacros.h: Add PRIdPriority_Control. Change PRIdrtems_task_priority to using PRIdPriority_Control. | ||||
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -1/+3 |
| | | | | | * sp34/changepri.c, sp59/init.c: Use PRIdrtems_task_priority to print rtems_task_priority's. | ||||
* | Use PRIdrtems_task_priority to print rtems_task_priority's. | Ralf Corsepius | 2009-10-26 | 2 | -3/+3 |
* | 2009-10-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-26 | 1 | -0/+10 |
| | | | | | | | | | | * sp07/task1.c, sp07/task2.c, ssp12/pritask.c: Use PRIdrtems_task_priority to print rtems_task_priority's * sp12/system.h: Change Priority_Test_driver to use rtems_task_priority argument. * sp12/pridrv.c: Change Priority_Test_driver to use rtems_task_priority argument. Use PRIdrtems_task_priority to print rtems_task_priority's. | ||||
* | Change Priority_Test_driver to use rtems_task_priority argument. | Ralf Corsepius | 2009-10-26 | 1 | -1/+1 |
* | Change Priority_Test_driver to use rtems_task_priority argument. | Ralf Corsepius | 2009-10-26 | 1 | -3/+3 |
* | Use PRIdrtems_task_priority to print rtems_task_priority's. | Ralf Corsepius | 2009-10-26 | 3 | -10/+10 |
| | | | | * support/include/tmacros.h: Add PRIdrtems_task_priority. | ||||
* | Add PRIdrtems_task_priority. | Ralf Corsepius | 2009-10-26 | 1 | -0/+2 |
| | | | | * psxsignal03/init.c: Add missing argument to printf. |
