* | score: Create schedulersimple impl header | Sebastian Huber | 2013-07-26 | 8 | -36/+27 |
| | | | | | | Move implementation specific parts of schedulersimple.h and schedulersimple.inl into new header file schedulersimpleimpl.h. The schedulersimple.h contains now only the application visible API. | ||||
* | libtests/malloc04: Fixes for RTEMS_DEBUG | Sebastian Huber | 2013-07-26 | 2 | -17/+17 |
* | conf.t: Fix minor typos. | Joel Sherrill | 2013-07-24 | 1 | -2/+2 |
* | readdir_r(): Add restrict keyword per Single UNIX Specification | Sahil Patnayakunii | 2013-07-24 | 1 | -1/+5 |
* | POSIX Semaphore: Add restrict keyword per Single UNIX Specification | Sahil Patnayakunii | 2013-07-24 | 3 | -8/+8 |
* | POSIX AIO: Add restrict keyword per Single UNIX Specification | Sahil Patnayakunii | 2013-07-24 | 2 | -8/+9 |
* | POSIX mqueue.h: Add restrict keyword per Single UNIX Specification | Sahil Patnayakunii | 2013-07-24 | 3 | -10/+10 |
* | doc/user/conf.t: Fix SMP_MAXIMUM_PROCESSORS and add Go configuration | Cynthia Rempel | 2013-07-24 | 1 | -1/+93 |
* | bsp/mpc55xx: Fix prototype | Peter Dufault | 2013-07-24 | 1 | -1/+1 |
* | score: Move _Heap_Area_overhead() definition. | Sebastian Huber | 2013-07-24 | 2 | -31/+31 |
| | | | | This function is used in bootcard.h. | ||||
* | score: Include <rtems/score/cpu.h> | Sebastian Huber | 2013-07-24 | 1 | -1/+1 |
| | | | | This file uses CPU_ALIGNMENT. | ||||
* | score: Add freechain | Zhongwei Yao | 2013-07-24 | 10 | -0/+419 |
* | score: Delete priority.inl | Sebastian Huber | 2013-07-24 | 4 | -62/+0 |
* | score: Merge sysstate API into one file | Sebastian Huber | 2013-07-24 | 103 | -184/+99 |
* | libtests/malloctest: Fixes for RTEMS_DEBUG | Sebastian Huber | 2013-07-24 | 2 | -5/+36 |
* | bsp/lpc32xx: Fix memory map for GPIO registers | Sebastian Huber | 2013-07-24 | 1 | -0/+2 |
* | score: Create stack implementation header | Sebastian Huber | 2013-07-23 | 13 | -29/+38 |
| | | | | | | Move implementation specific parts of stack.h and stack.inl into new header file stackimpl.h. The stack.h contains now only the application visible API. | ||||
* | posix: Include missing <stdint.h> | Sebastian Huber | 2013-07-23 | 1 | -0/+2 |
* | score: Create heap implementation header | Sebastian Huber | 2013-07-23 | 25 | -642/+643 |
| | | | | | | Move implementation specific parts of heap.h and heap.inl into new header file heapimpl.h. The heap.h contains now only the application visible API. | ||||
* | score: Include missing <rtems/score/thread.h> | Sebastian Huber | 2013-07-23 | 1 | -0/+1 |
* | score: PR1782: CPU_USE_DEFERRED_FP_SWITCH | Sebastian Huber | 2013-07-23 | 4 | -11/+14 |
| | | | | Do not redefine CPU_USE_DEFERRED_FP_SWITCH. | ||||
* | score: Include missing <rtems/score/address.h> | Sebastian Huber | 2013-07-23 | 2 | -0/+2 |
* | score: Merge wkspace API into one file | Sebastian Huber | 2013-07-23 | 5 | -62/+17 |
* | score: Merge address API into one file | Sebastian Huber | 2013-07-23 | 4 | -202/+160 |
* | rtems: Include missing header | Sebastian Huber | 2013-07-23 | 1 | -1/+2 |
* | rtems: Create tasks implementation header | Sebastian Huber | 2013-07-23 | 36 | -201/+216 |
| | | | | | | Move implementation specific parts of tasks.h and tasks.inl into new header file tasksimpl.h. The tasks.h contains now only the application visible API. | ||||
* | rtems: Create region implementation header | Sebastian Huber | 2013-07-23 | 23 | -118/+119 |
| | | | | | | Move implementation specific parts of region.h and region.inl into new header file regionimpl.h. The region.h contains now only the application visible API. | ||||
* | rtems: Include <rtems/debug.h> in <rtems.h> | Sebastian Huber | 2013-07-23 | 1 | -0/+1 |
| | | | | This header file is included indirectly via <rtems/rtems/region.h>. | ||||
* | rtems: Create part implementation header | Sebastian Huber | 2013-07-23 | 17 | -69/+75 |
| | | | | | | Move implementation specific parts of part.h and part.inl into new header file partimpl.h. The part.h contains now only the application visible API. | ||||
* | rtems: Create timer implementation header | Sebastian Huber | 2013-07-23 | 24 | -267/+272 |
| | | | | | | Move implementation specific parts of timer.h and timer.inl into new header file timerimpl.h. The timer.h contains now only the application visible API. | ||||
* | rtems: Create ratemon implementation header | Sebastian Huber | 2013-07-23 | 22 | -312/+313 |
| | | | | | | Move implementation specific parts of ratemon.h and ratemon.inl into new header file ratemonimpl.h. The ratemon.h contains now only the application visible API. | ||||
* | score: Include <string.h> in basedefs.h | Sebastian Huber | 2013-07-23 | 1 | -0/+7 |
* | Include missing <string.h> | Sebastian Huber | 2013-07-23 | 44 | -2/+50 |
* | rtems: Create dpmem implementation header | Sebastian Huber | 2013-07-23 | 14 | -61/+57 |
| | | | | | | Move implementation specific parts of dpmem.h and dpmem.inl into new header file dpmemimpl.h. The dpmem.h contains now only the application visible API. | ||||
* | rtems: Create event implementation header | Sebastian Huber | 2013-07-23 | 23 | -399/+302 |
| | | | | | | Move implementation specific parts of event.h, event.inl, eventset.h and eventset.inl into new header file eventimpl.h. The event.h contains now only the application visible API. | ||||
* | rtems: Merge support API into one file | Sebastian Huber | 2013-07-23 | 4 | -73/+30 |
* | rtems: Create asr implementation header | Sebastian Huber | 2013-07-23 | 8 | -25/+29 |
| | | | | | | Move implementation specific parts of asr.h and asr.inl into new header file asrimpl.h. The asr.h contains now only the application visible API. | ||||
* | rtems: Create modes implementation header | Sebastian Huber | 2013-07-23 | 6 | -28/+35 |
| | | | | | | Move implementation specific parts of modes.h and modes.inl into new header file modesimpl.h. The modes.h contains now only the application visible API. | ||||
* | rtems: Create attr implementation header | Sebastian Huber | 2013-07-23 | 29 | -65/+74 |
| | | | | | | Move implementation specific parts of attr.h and attr.inl into new header file attrimpl.h. The attr.h contains now only the application visible API. | ||||
* | rtems: Create options implementation header | Sebastian Huber | 2013-07-23 | 12 | -27/+35 |
| | | | | | | Move implementation specific parts of options.h and options.inl into new header file optionsimpl.h. The options.h contains now only the application visible API. | ||||
* | rtems: Create status implementation header | Sebastian Huber | 2013-07-23 | 17 | -89/+95 |
| | | | | | | Move implementation specific parts of status.h and status.inl into new header file statusimpl.h. The status.h contains now only the application visible API. | ||||
* | score: Create rbtree implementation header | Sebastian Huber | 2013-07-23 | 13 | -562/+555 |
| | | | | | | Move implementation specific parts of rbtree.h and rbtree.inl into new header file rbtreeimpl.h. The rbtree.h contains now only the application visible API. | ||||
* | sapi: Create extension implementation header | Sebastian Huber | 2013-07-23 | 13 | -35/+41 |
| | | | | | | Move implementation specific parts of extension.h and extension.inl into new header file extensionimpl.h. The extension.h contains now only the application visible API. | ||||
* | sapi: Merge rbtree API into one file | Sebastian Huber | 2013-07-23 | 5 | -507/+470 |
* | sapi: Merge timespec API into one file | Sebastian Huber | 2013-07-23 | 4 | -305/+261 |
* | sapi: Merge CBS API into one file | Sebastian Huber | 2013-07-23 | 4 | -214/+182 |
* | posix: Include proper header file | Sebastian Huber | 2013-07-23 | 2 | -2/+2 |
* | doc/user/conf.t: Fix SMP_MAXIMUM_PROCESSORS and add Go Configuration | Cynthia Rempel | 2013-07-22 | 1 | -4/+97 |
* | doc/shell/Makefile.am: Fix dependency | Joel Sherrill | 2013-07-22 | 1 | -1/+1 |
* | network: SMP support for network semaphore | Sebastian Huber | 2013-07-22 | 1 | -0/+6 |
