* | Fixed comment. | Joel Sherrill | 2000-01-06 | 2 | -4/+4 |
* | changed version to 20000104 | Joel Sherrill | 2000-01-05 | 0 | -0/+0 |
* | Fixed comment thanks to John M. Mills <jmills@tga.com>. | Joel Sherrill | 2000-01-05 | 2 | -12/+0 |
* | changed version to 20000104 | Joel Sherrill | 2000-01-05 | 1 | -1/+1 |
* | Added support for simple binary semaphores in addition to the high | Joel Sherrill | 2000-01-05 | 32 | -222/+348 |
| | | | | | | | | | | | | power binary/mutex style semaphores already supported by RTEMS. This was done at the request of Eric Norum <eric@cls.usask.ca> in support of his effort to port EPICS to RTEMS. This change consisted of changing the nesting_allowed boolean into a lock_nesting_behavior enumerated value as well as allowing the core mutex object to optionally support ensuring that the holder of a binary semaphore released it. Finally, a more subtle enhancement was to allow the non-holder to release a priority inheritance/ceiling mutex and still allow the holding task to return to its original priority. | ||||
* | Updated to reflect a time that had previously been left out due to | Joel Sherrill | 2000-01-05 | 2 | -0/+74 |
| | | | | an array sizing coding error. | ||||
* | Screen updated since test runs. | Joel Sherrill | 2000-01-05 | 2 | -2/+48 |
* | Was not actually installing the test. | Joel Sherrill | 2000-01-05 | 2 | -12/+10 |
* | Added message priority parameter returned by core support routine. | Joel Sherrill | 2000-01-05 | 2 | -2/+6 |
* | Added new message priority parameter as returned by core support routine. | Joel Sherrill | 2000-01-05 | 2 | -10/+14 |
* | Increased stack space. | Joel Sherrill | 2000-01-05 | 2 | -0/+2 |
* | Updated to reflect change in object class numbering due to ITRON API | Joel Sherrill | 2000-01-05 | 6 | -6/+6 |
| | | | | addition. | ||||
* | Corrected test and screen to reflect implementation working. | Joel Sherrill | 2000-01-05 | 4 | -10/+26 |
* | Changed screen to reflect change in object class numbers with ITRON | Joel Sherrill | 2000-01-05 | 8 | -38/+38 |
| | | | | addition. | ||||
* | Spacing corrected. | Joel Sherrill | 2000-01-05 | 4 | -4/+4 |
* | Corrected so header message is printed. | Joel Sherrill | 2000-01-05 | 4 | -0/+6 |
* | patch from Eric Norum <eric@cls.usask.ca> as follows: | Joel Sherrill | 2000-01-05 | 1 | -0/+124 |
| | | | | | | | | | | | At the request of kjoutwater@west.raytheon.com I'm submitting the following patch. c/src/lib/libbsp/m68k/gen68360/console/console.c Allow console baud rate to be set by debugger/downloader. c/src/lib/libbsp/m68k/gen68360/startup/init68360.c Add support for generic 68360 with static RAM. | ||||
* | Patch from Eric Norum <eric@cls.usask.ca> as follows: | Joel Sherrill | 2000-01-05 | 1 | -1/+6 |
* | Fixed recursive release for mutexes with nesting allowed. | Joel Sherrill | 2000-01-05 | 2 | -2/+8 |
* | Now print strings -- not error numbers. | Joel Sherrill | 2000-01-05 | 2 | -4/+6 |
* | + Added tests for open, close, unlink, and send. | Jennifer Averett | 2000-01-05 | 2 | -106/+446 |
* | + Added return priority from message seize. | Jennifer Averett | 2000-01-05 | 2 | -20/+22 |
| | | | | + Changed priority to be based off of min and max int. | ||||
* | Added the recording of the submit type. | Jennifer Averett | 2000-01-05 | 2 | -0/+2 |
* | + Added return of the message priority. | Jennifer Averett | 2000-01-05 | 2 | -12/+16 |
* | Added priority conversion between POSIX and core. | Jennifer Averett | 2000-01-05 | 2 | -4/+34 |
* | Added priority conversion between POSIX and core priorities. | Jennifer Averett | 2000-01-05 | 2 | -4/+58 |
* | + Changed priority to the POSIX priority type. | Jennifer Averett | 2000-01-05 | 2 | -18/+92 |
| | | | | | | | + Added priority validation + Changed to call correct core routine. + Added priority conversion + Resolved return type problems. | ||||
* | + Added check for reading from a write only queue. | Jennifer Averett | 2000-01-05 | 2 | -2/+24 |
| | | | | + Added ability to return message priority from the core. | ||||
* | + Added check for name greater than PATH_MAX. | Jennifer Averett | 2000-01-05 | 2 | -0/+6 |
* | + Changed to resonable default values for maxmsg and msgsize. | Jennifer Averett | 2000-01-05 | 2 | -6/+22 |
| | | | | + Added oflag tracking. | ||||
* | Added mqueuetranslatereturncode.c. | Jennifer Averett | 2000-01-05 | 2 | -2/+2 |
* | Added routines to translate to and from the core message queue return codes. | Jennifer Averett | 2000-01-05 | 2 | -0/+136 |
* | Fixed typos. | Joel Sherrill | 2000-01-04 | 2 | -11/+12 |
* | Updated dates and miscellaneous. | Joel Sherrill | 2000-01-04 | 9 | -18/+27 |
* | Added timer manager. | Joel Sherrill | 2000-01-04 | 1 | -0/+5 |
* | Improved clean stanza. | Joel Sherrill | 2000-01-04 | 1 | -1/+1 |
* | Added this file to contain an example program. | Joel Sherrill | 2000-01-04 | 2 | -0/+54 |
* | Fixed warnings. | Joel Sherrill | 2000-01-04 | 24 | -24/+22 |
* | Removed warning. | Joel Sherrill | 2000-01-04 | 2 | -0/+6 |
* | Removed warnings. | Joel Sherrill | 2000-01-04 | 4 | -8/+8 |
* | Removed unitialized variable warning. | Joel Sherrill | 2000-01-04 | 2 | -8/+6 |
* | Added shared version of this file. | Joel Sherrill | 2000-01-04 | 1 | -0/+103 |
* | Made to compile again. | Joel Sherrill | 2000-01-04 | 1 | -1/+1 |
* | Fixed path to shared/include/coverhd.h. | Joel Sherrill | 2000-01-03 | 12 | -12/+12 |
* | Added new URL. | Joel Sherrill | 2000-01-03 | 1 | -0/+3 |
* | Comments added and some messages translated from Polish. | Joel Sherrill | 2000-01-03 | 3 | -6/+97 |
* | Patch from Eric Norum <eric@cls.usask.ca>: | Joel Sherrill | 2000-01-03 | 3 | -1/+5 |
| | | | | | | | | | | | | | In another attempt to get C++ exceptions working on the gen68360 target I tried building for the m68k-elf target. All the tools built and installed properly as did all of RTEMS. No applications would run, though -- not even hello.exe! It turns out the problem was in the linker script. The alignment was in the wrong place. Here's a patch. Exceptions still don't work, but at least I can get some things working with the ELF format now. | ||||
* | Updated times. | Joel Sherrill | 2000-01-03 | 2 | -150/+150 |
* | Increased stack size to 4K per Eric Norum. | Joel Sherrill | 2000-01-03 | 2 | -2/+2 |
