* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-276-3/+15
| | | | * libc/res_init.c: Fix typo - adding missing # on include.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-272-2/+25
| | | | | | * cache/cache.h: Fix reference to MC68040 and put in stubs for missing support routines. The functionality of these routines needs to be addressed.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-272-1/+7
| | | | | | * startup/linkcmds: Fix typo and add extra 0 to base address. Now runs until printf() tries to put a character and then it locks up checking a status bit that does not change.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-272-1/+5
| | | | * configure.in: Change mips64orion reference to mips.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-273-0/+12
| | | | | | * start/start.S, startup/bspstart.c: Not functional for CPU32 but hopefully will compile now and give a warning saying that the CPU32 variant needs work.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-274-0/+38
| | | | * src/sysconf.c: Add support for _SC_CLK_TCK and _SC_OPEN_MAX.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-273-2/+64
| | | | | | | | * custom/shsim.cfg: New file. * custom/Makefile.am: Modified to reflect addition of shsim.cfg. The shsim is for the SH simulator in gdb. It should be able to be used with multiple SH CPU models. This will require adding BSP variants.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-2726-0/+1033
| | | | | | | | | | | | | | * The shsim is for the SH simulator in gdb. It should be able to be used with multiple SH CPU models. * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/console-io.c, console/console-support.S, include/.cvsignore, include/Makefile.am, include/bsp.h, start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, wrapup/.cvsignore, wrapup/Makefile.am: New files.
* 2000-11-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-273-272/+1020
| | | | | | * config.guess, config.sub: Update from CVS-autoconf to pick up new features (e.g. CC_FOR_BUILD in config.guess) but is necessary anyway to use autoconf-versions > 2.13.
* 2000-11-25 Antti P Miettinen <antti.p.miettinen@nokia.com>Joel Sherrill2000-11-2513-0/+5383
| | | | | | | | | | | | * wrapup/Makefile.am: Added modem subdir. * configure.in, Makefile.am: Added modem subdir. * net/Makefile.am: Added if_pppvar.h, pppcompress.h. * pppd/Makefile.am: Added pppmain.c (which needs work). * pppd/chat.c, pppd/fsm.c, pppd/fsm.h, pppd/ipxcp.c, pppd/main.c, pppd/ppp_tty.c, pppd/upap.c: Changes from Thomas Doerfler <Thomas.Doerfler@imd-systems.de> and cosmetic changes by me. Actually main.c and ppp_tty.c should be scratched. The modem subdir has the real ppp_tty.c and the real pppd main is in pppmain.c.
* 2000-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-252-25/+33
| | | | | | | | * custom/pc386.cfg: make-exe rule would write into $(PROJECT_RELEASE) area. This is not cool because it $(PROJECT_RELEASE) is generally not writeable after the BSP is installed and you do not want every application installed there by default. Reported by Eric Norum <eric.norum@usask.ca>.
* 2000-11-25 Eric Norum <eric.norum@usask.ca>Joel Sherrill2000-11-256-3/+27
| | | | * libc/res_init.c: Move include to avoid compiler dumping core.
* 2000-11-25 Antti P Miettinen <antti.p.miettinen@nokia.com>Joel Sherrill2000-11-2523-27/+77
* 2000-11-25 Antti P Miettinen <antti.p.miettinen@nokia.com>Joel Sherrill2000-11-256-467/+1325
| | | | | | * libc/termios.c, libc/termiostypes.h: Task driver driver model and line discipline support from Thomas Doerfler <Thomas.Doerfler@imd-systems.de>.
* 2000-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-2525-0/+1170
| | | | | | | | | | | | | * The JMR BSP is for a Toshiba TX39 evaluation board but can also be used with the mips simulator in gdb. * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/console-io.c, include/.cvsignore, include/Makefile.am, include/bsp.h, start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, wrapup/.cvsignore, wrapup/Makefile.am: New files.
* 2000-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-252-0/+5
| | | | * TESTED: Added jmr3904 entry.
* 2000-11-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-253-2/+60
| | | | | * custom/Makefile.am: Updated to add jmr3904.cfg * custom/jmr3904.cfg: New file.
* changed version to ss-20001121Joel Sherrill2000-11-210-0/+0
* changed version to ss-20001121Joel Sherrill2000-11-211-1/+1
* 2000-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-212-0/+8
| | | | * TESTED: Added new sparc variations (erc32, leon, and Tharsys).
* 2000-11-21 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-214-6/+28
| | | | * cpu_asm.S: Fix for CPUs with FPU revision B or C.
* 2000-11-21 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-212-4/+12
| | | | | | | | | * erc32sonic/erc32sonic.c: Minor modifications which enable network interface to come up and work for some time before getting an error in the SONIC driver. The error is a bit random, sometimes MCLGET (m, M_WAIT) tries to access memory way outside the available ram (and traps) while sometimes there is a panic due to RBAE/RXEN.
* 2000-11-17 Jennifer Averett <jennifer@OARcorp.com>Jennifer Averett2000-11-202-0/+28
| | | | | | | | | | | | | | * psxstat/test.c, psxstat/psxstat.scn: Forced inode numbers to remain consistant across platforms and bsps by forcing a mount point in front of all paths. 2000-11-17 Jennifer Averret <jennifer@OARcorp.com> * psxmount/test.c, psxmount/psxmount.scn: Improve output to report expected error condition in one case. * psxreaddir/test.c, psxreaddir.scn: Added test cases to exercise readdir() of root of mounted filesystem. Also corrected the screen file for some mistakes noticed in this effort.
* 2000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2000-11-204-34/+32
* 2000-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-204-0/+12
| | | | * itrontask01/system.h: Configure enough stack memory.
* 2000-11-20 Dmitry Kargapolov <dk@gentex.ru>Joel Sherrill2000-11-204-9/+43
| | | | | * libc/mount.c: Make sure there is space allocated for a device name in the mount table entry.
* 2000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2000-11-174-580/+534
* 2000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2000-11-178-162/+286
* 2000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2000-11-176-48/+60
| | | | * src/imfs/imfs_eval.c: Always return imaginary node at mount points.
* 2000-11-17 Jennifer Averret <jennifer@OARcorp.com>Jennifer Averett2000-11-176-234/+159
| | | | | | | | | | | * libc/mount.c (search_mt_for_mount_point): Deleted routine. * libc/mount.c (Is_node_fs_root): Replacement for above that accounts for the imaginary root node being returned by the filesystem evaluation routine. * libc/unmount.c (unmount): Account for imaginary root node being returned and improved variable names to clarify code. * libc/unmount.c (file_systems_below_this_mountpoint): Body of routine replaced to account for imaginary root node being returned.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-162-1/+5
| | | | * gccnewlib/gccnewlib.add: Fix typo in URL.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-155-19/+18
| | | | | | | | * aclocal/canonical-host.m4: Abandon changequotes (autoconf-2.49b). * aclocal/check-newlib.m4: Let check message refer to RTEMS newlib. * aclocal/rtems-debug.m4: Fix formating and contents of the check's help string. * aclocal/rtems-top.m4: Remove AC_ARG_WITH(target-subdir).
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-152-7/+11
| | | | * Makefile.inc.in: Use * instead of *_FOR_TARGET (BUG-FIX).
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-152-13/+5
| | | | | * custom/leon2.cfg: Removed defines that are now generated in a non-BSP specific manner.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-154-7/+10
| | | | * Makefile.am: Cleanup.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-152-1/+4
| | | | * include/Makefile.am: Cleanup.
* 2000-11-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-152-2/+6
| | | | * shgen.c: Set default Phi to 20MHz (BUG-FIX).
* 2000-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-156-4/+12
| | | | * psxmount/psxmount.scn, psxmount/test.c: Correct spelling.
* 2000-11-14 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-157-1/+100
| | | | | | | * Makefile.am, configure.in: Added support for instruction cache enabling based on CPU model. * cache/.cvsignore, cache/Makefile.am, cache/cache.c, cache/cache_.h: New files.
* 2000-11-14 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-152-1/+8
| | | | | | | * shared/src/cache_manager.c (rtems_cache_invalidate_multiple_instruction_lines): If CPU_INSTRUCTION_CACHE_ALIGNMENT is defined but 0, then there is an instruction cache but no notion of line size.
* 2000-11-14 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-154-4/+14
| | | | | * wrapup/Makefile.am: Pick up cache code from libcpu and pick up .o's instead of .rel's from libcpu.
* 2000-11-14 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-156-2/+40
| | | | | | * cpu.c, rtems/cpu/sparc.h: Make floating point optional based on gcc arguments. Do not initialize FP context if there is no FPU. Flush instruction cache after installing RTEMS trap handler.
* 2000-11-14 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-152-0/+5
| | | | * startup/boardinit.S: St 32-bit ram width by default.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-132-0/+7
| | | | | | * ChangeLog, .cvsignore, Makefile.am, bspclean.c, bspstart.c, gnatcommon.c, start.S: New files. Largely moved from ERC32 BSP to be able to be shared with LEON and other SPARC BSPs.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-132-0/+41
| | | | | | | * network/sonic.c: Added ipalign() routine to align the received packet so that the ip header is on a 32-bit boundary. Necessary for cpu's that do not allow unaligned loads and stores and when the 32-bit DMA mode is used.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-134-1/+12
| | | | | | * README.configure, aclocal/bsp-alias.m4, aclocal/check-bsps.m4: Modified to reflect addition of LEON BSPs as well as the no-FP ERC32 variant.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-136-7/+149
| | | | | | * custom/Makefile.am: Modified to reflect addition of files. * custom/erc32.cfg: Modified to support addition of no-FP ERC32 variant. * custom/erc32nfp.cfg, custom/leon1.cfg, custom/leon2.cfg: New file.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-133-3/+9
| | | | | * Makefile.am, configure.in: Added shared directory as part of enhancing ERC32 and adding LEON.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-1340-0/+3121
| | | | | | | | | | | | | | | | | * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, times, clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, console/.cvsignore, console/Makefile.am, console/console.c, console/consolereserveresources.c, console/debugputs.c, gnatsupp/.cvsignore, gnatsupp/Makefile.am, gnatsupp/gnatsupp.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/coverhd.h, include/leon.h, start/.cvsignore, start/Makefile.am, startup/.cvsignore, startup/Makefile.am, startup/boardinit.S, startup/linkcmds, startup/setvec.c, startup/spurious.c, timer/.cvsignore, timer/Makefile.am, timer/timer.c, tools/.cvsignore, tools/Makefile.am, tools/configure.in, tools/runtest.in, wrapup/.cvsignore, wrapup/Makefile.am: New file.
* 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl>Joel Sherrill2000-11-135-0/+685
