* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 4 | -12/+0 | |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 8 | -25/+0 | |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 20 | -68/+0 | |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -6/+0 | |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -8/+0 | |
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 2 | -7/+0 | |
* | Remove. | Ralf Corsépius | 2012-05-04 | 1 | -0/+0 | |
* | nds/linkcmds - Remove execute permission | Joel Sherrill | 2012-05-03 | 1 | -0/+0 | |
* | libcpu misc m68k and sh - Correct formatting and remove weird Id strings | Joel Sherrill | 2012-05-03 | 6 | -59/+41 | |
* | General - Remove extraneous blank line in license message | Joel Sherrill | 2012-05-03 | 100 | -85/+0 | |
| | | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | |||||
* | Libcpu misc files - Remove execute permission on source files. | Joel Sherrill | 2012-05-03 | 10 | -0/+0 | |
* | rtems-message_queue.adb - Convert DOS to UNIX CF/LF | Joel Sherrill | 2012-05-03 | 1 | -245/+245 | |
* | psxaio01/psxaio02 - Formatting corrections | Joel Sherrill | 2012-05-03 | 2 | -18/+18 | |
| | | | | | The file header was moved over one space. These two were the only files in the testsuite which did this. | |||||
* | sp07/buffered_io.c add missing copyright | Joel Sherrill | 2012-05-03 | 1 | -1/+6 | |
| | | | | Date and ownership determined from file history. | |||||
* | smdk2410 - Remove odd $Id$ | Joel Sherrill | 2012-05-02 | 1 | -2/+0 | |
* | gp32 - Remove odd $Id$ | Joel Sherrill | 2012-05-02 | 1 | -3/+0 | |
* | pc386 - Remove odd $Id$ | Joel Sherrill | 2012-05-02 | 7 | -14/+0 | |
* | libchip hcms29xx - Remove odd $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 5 | -17/+1 | |
* | score603e - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -4/+6 | |
* | libcpu/m68k/mcf532x - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -3/+3 | |
* | libchip z85c30 - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -4/+6 | |
* | LEON3 - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -4/+6 | |
* | LEON2 - Remove bad $Id$ and clean up file header | Joel Sherrill | 2012-05-02 | 1 | -4/+6 | |
* | MRM332 - Remove incorrect $Id$ string and correct file header | Joel Sherrill | 2012-05-02 | 2 | -2/+26 | |
* | Merge branch 'master' of ssh://rgit/data/git/rtems | Chris Johns | 2012-04-28 | 4 | -26/+48 | |
| * | Update config.guess and config.sub | Joel Sherrill | 2012-04-26 | 2 | -10/+25 | |
| * | bsps/stackalloc: Add initialization hook | Sebastian Huber | 2012-04-26 | 2 | -16/+23 | |
* | | IMFS: Update IMS_assert check when RTEMS_DEBUG is enabled. | Chris Johns | 2012-04-28 | 1 | -1/+1 | |
|/ | | | | Update the assert macro to the new IMFS_jnode_t. | |||||
* | smp08 screen replacement | Joel Sherrill | 2012-04-24 | 1 | -16/+29 | |
* | Simple SMP Scheduler - Fix typo which likely broke scheduling | Joel Sherrill | 2012-04-24 | 1 | -8/+31 | |
* | bsp/mpc55xxevb: Enable stack allocator | Sebastian Huber | 2012-04-24 | 6 | -4/+10 | |
* | bsps/stackalloc: Use stack section symbols | Sebastian Huber | 2012-04-24 | 5 | -55/+26 | |
* | bsps/powerpc: Add no cache section | Sebastian Huber | 2012-04-24 | 14 | -89/+78 | |
* | bsp/mpc55xxevb: Change early MMU settings | Sebastian Huber | 2012-04-24 | 3 | -17/+28 | |
| | | | | | | Add internal SRAM sections with cache enabled to early MMU settings. The internal SRAM initialization will use the early MMU settings. This allows applications to use cache inhibited areas in the internal SRAM. | |||||
* | score: Remove _Stack_Adjust_size() | Sebastian Huber | 2012-04-24 | 2 | -30/+0 | |
| | | | | | | | | | | The increase of the stack size by CPU_STACK_ALIGNMENT in _Thread_Stack_Allocate() is disadvantageous. This may lead to a huge over allocation for specialized stack allocators. The CPU_STACK_ALIGNMENT is at most 16 on all current RTEMS CPU ports. The mimimum stack size ensured by _Stack_Ensure_minimum() must be considerable larger than this value, otherwise stack overflows will likely occur. Thus the _Stack_Adjust_size() is also superfluous. | |||||
* | nfsclient: Use UID and GID of NFS handle | Sebastian Huber | 2012-04-23 | 1 | -10/+10 | |
| | | | | Use UID and GID of the NFS handle for node and symbolic link creation. | |||||
* | nfsclient: POSIX conformance | Sebastian Huber | 2012-04-23 | 1 | -9/+37 | |
| | | | | | According to POSIX the read() call should return the maximum number of bytes available for regular files. | |||||
* | bsp/lpc24xx: Fix define name | Sebastian Huber | 2012-04-23 | 1 | -1/+1 | |
* | PR1908: consolidate libqos code and fix installed header location | Gedare Bloom | 2012-04-23 | 8 | -258/+196 | |
* | score: Documentation | Sebastian Huber | 2012-04-20 | 1 | -0/+3 | |
* | bsps/arm: Make the Clock_isr() static again | Sebastian Huber | 2012-04-20 | 1 | -1/+1 | |
