PR 587/bsps
* shared/include/cpuIdent.h, shared/include/cpuIdent.c: Add defines
for MPC_5XX.
* Makefile.am, configure.ac: Reflect having added mpc5xx.
* mpc5xx/.cvsignore, mpc5xx/Makefile.am: New.
* mpc5xx/exceptions/asm_utils.S, mpc5xx/exceptions/raw_exception.c,
mpc5xx/exceptions/raw_exception.h, mpc5xx/ictrl/ictrl.c,
mpc5xx/ictrl/ictrl.h, mpc5xx/timer/timer.c: New (Submission from
Wilfried Busalski <w.busalski@lancier-monitoring.de>).
* libnetworking/net/radix.c: Remove warning.
* custom/p4650.cfg: Remove obsolete variables and get closer to gcc 3.x
support.
* libmisc/shell/cmds.c: Remove warning.
* aclocal/canonicalize-tools.m4: Add SIZE, NM, and OBJCOPY so
they can be used in application level makefiles.
* sp07/buffered_io.c: Remove warning.
* libnetworking/lib/ftpfs.c: Switch bcopy to memcpy.
* libcsupport/src/newlibc.c, libcsupport/src/sync.c: Eliminate
warnings. Explicitly defeat __STRICT_ANSI__ since both
legitimately use routines beyond ANSI.
* libblock/src/bdbuf.c: Initialize pointer to avoid warning.
* libnetworking/rtems_webserver/ejparse.c,
libnetworking/rtems_webserver/emfdb.c,
libnetworking/rtems_webserver/sock.c,
libnetworking/rtems_webserver/socket.c,
libnetworking/rtems_webserver/sym.c,
libnetworking/rtems_webserver/webs.c,
libnetworking/rtems_webserver/websuemf.c: Remove warnings.
* libchipnetwork/open_eth.c: Remove warnings by conditionally
compiling this file only only those CPU families with supported
exception models.
* mpc6xx/mmu/pte121.c: Add missing ifdef DEBUG to remove warning for
unused static routine.
* bootloader/pci.c: Remove warnings by adding include <string.h>.
* irq/irq.c: Clean up includes to remove warnings.
* pci/pci.c, pci/pci.h, startup/bspstart.c: Better use of const
on struct _int_map.
* network/network.c: Remove warnings for unused routines left from
original code.
* score/macros/rtems/score/chain.inl, score/src/objectidtoname.c:
Add cast to avoid type punning warning in gcc 3.3.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/svc.c,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c: Too
much was accidentally committed -- revert.
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
* psxfile01/test.c, psxmsgq01/init.c, psxstat/test.c,
psxtimer/psxtimer.c: Eliminate warnings and typos.
PR 576/doc
* FAQ/FAQ.texi, FAQ/Makefile.am: Remove embedded information as it was
out of date and frequently duplicated information available from
other public sources like the CrossGCC Wiki.
* FAQ/embeddedinfo.t: Removed.
PR 505/bsps
* setvec.c: Rework to remove punned pointer warning generated by gcc
3.3 and newer.
* include/buffer_test_io.h: Correct typo.
* startup/linkcmds: Add more memory and sections so tests can link.
This is a generic BSP for a CPU model so OK to do this.
* vectors/vectors.h, vectors/vectors_init.c: Undo previous change.
* irq/irq.h: Correct typo.
* Makefile.am: Correct typo.
* startup/linkcmds: Add more memory so tests can link. This is a
PR 570/bsps
* custom/mvme2307.cfg: Do not use -msdata=eabi since
it breaks the linking of the vectors.
* cpu_asm.S: Close window while restoring interrupted task state which
resulted in CWP corruption.
PR 584/RTEMS
* rtems/src/eventtimeout.c: Fix critical section window.
PR 583/tests
* tm26/task1.c, tm27/task1.c: Correctly reset
_Thread_Dispatch_disable_level so printing is safe.
PR 582/core
* posix/src/mqueue.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueueunlink.c: Use memory
from workspace to avoid use of mutex during dispatch disable critical
section. Besides memory for object names should come from the
Workspace anyway.
PR 582/core
* psxmsgq01/init.c, psxmsgq01/psxmsgq01.scn: Fix the POSIX message
queue test so more of it runs now.
PR 580/tools
* setup.def: Fix setup.def to match current reality.
* gdb/base-gdb.add: Add annotate.info.
* gdb/gdb.add: Remove info/dir.
* README: New file.
* rtems-apt-conf.spec.in: Add @VERSION@ to Source0.
* Makefile.am, gpg/gpg-pubkey-eac29b6f-3fe1f458, ChangeLog,
vendors.list.d/rtems.list, sources.list.d/rtems-4.6.list,
sources.list.d/rtems-4.7.list, configure.ac, .cvsignore, COPYING,
rtems-apt-conf.spec.in, INSTALL: New.
* Makefile.am: Cosmetics.
* aclocal/rtems-top.m4: Sync with c/src/aclocal/rtems-top.m4
* Makefile.am, gdb/Makefile.am: Cosmetics.
* Makefile.am: Add EXTRA_DIST = search-id.sh multigen
cvsignore-add.sh.
