* rtems/src/ratemonreportstatistics.c: owner field is always set so
safe to use. Reformat.
* rtems/src/regionresizesegment.c: Always evaluate the blocked queue
if the resize succeeded.
* rtems/src/tasksetnote.c: Spacing.
* posix/include/rtems/posix/psignal.h: Add extern for ualarm timer.
* posix/src/alarm.c, posix/src/ualarm.c: Change from switch to if since
many enumerated values have no action.
* posix/src/psignal.c: Initialize ualarm and alarm timers.
* sp07/init.c, sp07/sp07.scn, sp09/init.c, sp09/screen01.c,
sp09/sp09.scn, sp28/init.c, sp62/init.c, sp62/sp62.scn, sp64/init.c,
sp64/sp64.scn: Add more test cases highlighted on SPARC at -O2, x86
at -Os and m68k at -Os. Fix typos.
* shared/openpic/openpic.c: Make openpic_writefield
static inline (Get rid of GCC warning).
* sp54/init.c: Use rtems_build_id to make building Objects_Id
RTEMS_USE_16_BIT_OBJECT clean.
* libmisc/monitor/mon-driver.c: Fix warning if
defined(RTEMS_USE_16_BIT_OBJECT).
add basic IRQ support (for decrementer)
* start/start.S, startup/cmain.c, startup/linkcmds: add support
for sdata* sections
* startup/bsppanic.c: some cleanup
* libmisc/monitor/mon-prmisc.c: Fix warning if
* hello/init.c: Remove call to devFS_Show() which had accidentally
gotten committed.
* Makefile.am, configure.ac, termios01/termios_testdriver.c: Do not use
CONSOLE_USE_INTERRUPTS. That is in use by BSPs and we should not use
it.
* termios02/.cvsignore, termios02/Makefile.am, termios02/init.c,
termios02/termios02.doc, termios02/termios02.scn: New files.
termios02 is a test for tcdrain().
* aclocal/bsp-alias.m4: Add BSP for GDB ARM simulator so we can easily
experiment with and debug different ARM architectural variations.
* acinclude.m4: Add BSP for GDB ARM simulator so we can easily
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac,
preinstall.am, console/.cvsignore, console/console-io.c,
include/.cvsignore, include/bsp.h, include/irq.h, include/swi.h,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspreset.c, startup/bspstart.c, startup/linkcmds,
startup/syscalls.c: New files.
* rtems/score/arm.h: Recognize ARMv7A.
* Makefile.am: Add new BSP variants for ARM simulator in GDB.
* custom/arm1136jfs.cfg, custom/arm1136js.cfg, custom/arm7tdmi.cfg,
custom/arm920.cfg, custom/armcortexa9.cfg: New files.
* libchip/ide/ata.c: Use simple vectored CPU macro to select interrupt
model.
* rtems/score/arm.h: Recognize ARMv6J as needed by arm1136 variants.
PR 1445/BSPs
* shared/pci/pcibios.c: Rename indirect_pci_* into BSP_pci_*.
PR 1445/BSPs
* pci/pci.c: Rename pci_[read|write]_config* functions into
BSP_pci_[read|write]_config* and make them static.
PR 1445/bsps
* include/rtems/pci.h:
Make pci_[read|write]_config* static inline, again.
* include/rtems/pci.h: Add another missing prototype.
* termios01/init.c, termios01/termios_testdriver.c:
Reflect changes to termios.
* include/bsp.h: BSP does not have much memory. Limited to BIOS space.
* include/rtems/pci.h: Add missing prototype.
* libcsupport/src/fstat.c, libcsupport/src/fcntl.c,
libcsupport/src/calloc.c, libcsupport/src/isatty_r.c,
libcsupport/src/issetugid.c, libcsupport/src/lseek.c,
libcsupport/src/read.c, libcsupport/src/getpid.c:
Rework autoconf defines.
* libcsupport/src/_rename_r.c: Rework autoconf defines.
Remove unused includes.
* libcsupport/src/__gettod.c: Rework autoconf defines.
Eliminate RTEMS_UNIX.
* libcsupport/src/_calloc_r.c, libcsupport/src/_realloc_r.c:
* libcsupport/src/open.c, libcsupport/src/close.c:
* libcsupport/src/tcflow.c: Remove unused includes.
* libcsupport/src/__sbrk.c: Eliminate RTEMS_UNIX.
* libcsupport/src/_free_r.c, libcsupport/src/_malloc_r.c:
