* Initial attempt at building HP PA-RISC using Solaris hosted tools.Joel Sherrill1995-09-1212-28/+313
| | | | Changed back to Newlib for Solaris UNIX simulator.
* Added...Joel Sherrill1995-09-112-0/+90
* Added... This is the Configuration Tables Template file.Joel Sherrill1995-09-113-0/+846
* AddedJoel Sherrill1995-09-113-0/+621
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-11883-11327/+20872
* new file -- split from inlinesJoel Sherrill1995-08-292-0/+404
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-28159-804/+2388
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-2373-248/+513
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-23414-1118/+3776
* Added file .. fixed RCS IdJoel Sherrill1995-08-221-0/+285
* fixed RCS IdJoel Sherrill1995-08-221-0/+249
* Fixed missing RCS IdsJoel Sherrill1995-08-228-7/+58
* Merged PowerPC port as submitted by Andy Bray of I-CUBED, LtdJoel Sherrill1995-08-2231-21/+2831
| | | | | | | | | | (andy@i-cubed.demon.co.uk). This initial submission is known to work on the IBM 403. It is thought to work on the Motorola 601, 603, and 604 although this remains to be tested. Another user -- Doug Currie (e@flavors.com) -- is interested in this work and will be testing it on the 604 using the Metrowerks C compiler and a different format assembly language.
* fix broken RCS Ids -- $ accidentally lost merging changes earlierJoel Sherrill1995-08-2234-34/+34
* make inline and macro implementations matchJoel Sherrill1995-08-225-42/+63
* make inline and macro implementations matchJoel Sherrill1995-08-226-54/+51
* Modified object name to id translation loop to make it easier toJoel Sherrill1995-08-222-32/+48
| | | | | | | incorporate variable length object names. Previously the algorithm scanned an array of 4-byte names for a match. Now it scans the object table, grabs a pointer to the name, and then compares it if the object is active and has a name.
* Changed to reflect adding object class to idJoel Sherrill1995-08-184-4/+4
| | | | Added "0x" to printf of id
* Changed to reflect adding object class to idJoel Sherrill1995-08-1814-48/+48
* Modified references to task name.Joel Sherrill1995-08-183-6/+9
* + Added object type field to object id.Joel Sherrill1995-08-1826-33/+80
| | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information
* + Added object type field to object id.Joel Sherrill1995-08-1812-63/+306
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-17151-1775/+15436
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* variable length messagesJoel Sherrill1995-08-174-238/+538
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-17250-1052/+3372
* added tty driver to simhppaJoel Sherrill1995-08-171-0/+254
* Id reinsertedJoel Sherrill1995-08-173-3/+3
* no limit removedJoel Sherrill1995-08-175-14/+11
* bug fixes to make macro implementations workJoel Sherrill1995-08-1652-246/+101
* final 3.2.1 Module file and version updatesJoel Sherrill1995-08-152-2/+2
* added alignment attribute for array used as partition memory.Joel Sherrill1995-08-112-2/+2
* cleanupJoel Sherrill1995-08-112-12/+16
* Added functions to access the errno of the native system when using theJoel Sherrill1995-08-116-3/+150
| | | | | | | newlib C library. Fixed bug where length did not take into account amount added for alignment requirements.
* Added functions to access the errno of the native system when using theJoel Sherrill1995-08-114-28/+8
| | | | newlib C library.
* Added flush of output on exit. On some UNIX's using the native libraryJoel Sherrill1995-08-114-48/+65
| | | | | | | | | resulted in no output when the output was redirected until this was done. Redirection is important because runtest redirects test output. Added support for numerous environment variables which make it easier to run a multi-node system using a single executable and to tailor the size of the workspace and heap.
* Initialization of semaphores was incorrect. It did not forceJoel Sherrill1995-08-114-56/+98
| | | | | | | | | | | | the count to "1" to indicate availability. Interrupt support was added. Problem where newlib's errno "overrides" that set by system calls was addressed. Fixed bug which resulted in all nodes using the same semaphore although an array of semaphores was allocated.
* clean up -- interrupt support is in placeJoel Sherrill1995-08-111-5/+25
* minor clean up -- switched to memset for zero'ing SHMJoel Sherrill1995-08-119-152/+135
* cleaned up include statementsJoel Sherrill1995-08-111-1/+1
* clean up of RunWay interrupt supportJoel Sherrill1995-08-112-3/+11
* added constant for number of notepadsJoel Sherrill1995-08-113-24/+30
* cleanup and optimization from TonyJoel Sherrill1995-08-043-38/+38
* Split out event manager support functionJoel Sherrill1995-08-042-40/+0
* split out event support functions in anticipation of making a handlerJoel Sherrill1995-08-042-382/+0
* Tony's updatesJoel Sherrill1995-08-041-4/+9
* updaetd to remove UNIX simulator bugsJoel Sherrill1995-08-041-11/+0
* Changed order of include files.Joel Sherrill1995-08-021-1/+1
* *** empty log message ***Joel Sherrill1995-08-023-2/+13
* Added test cases:Joel Sherrill1995-08-022-4/+142
| | | | | | + some from Andy Bray (andy@i-cubed.demon.co.uk) which do not include task start up cost. + cases for interrupt disable, enable, and flash
* deleted unused codeJoel Sherrill1995-08-012-76/+0
