* Makefile.am: genoffsets must be built before the executive.
* tools/Makefile.am: Build the cpu dependent tools as well.
* With the addition of serdbg, the standard polled I/O functions
for gdbstub and/or printk are optionally routed to any termios-aware
device driver, that supports polled mode. See libmisc/serdbg/README.
* serdbg/Makefile.am, serdbg/README, serdbg/serdbg.c, serdbg/serdbg.h,
serdbg/serdbgcnf.h, serdbg/serdbgio.c, serdbg/termios_printk.c,
serdbg/termios_printk.h, serdbg/termios_printk_cnf.h,
serdbg/.cvsignore: New files.
* configure.ac, Makefile.am, wrapup/Makefile.am: Modified to
reflect addition.
* Makefile.am, bsp_specs: Now this target almost compiles again.
* Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k
support to the shared gdb stub glue thus adding a directory at the
top shared level.
* shared/gdbstub: New directory.
* configure.ac: Modified to reflect above.
* Makefile.am, cpu.c, cpu_asm.S, rtems.S: Modified to make
this all compile again. It has been a while since we have
had a semi-working hppa1.1-rtems cross compiler. :)
support to the shared gdb stub glue thus moving some of the
gdbstub support to a higher level.
* startup/Makefile.am: Modified to reflect above.
support to the shared gdb stub glue necessitating a move up.
* Makefile.am: Reflect new gdbstub directory.
* ChangeLog, Makefile.am, .cvsignore: New file.
* rtems-stub-glue.c: Moved from mips/shared/gdbstub and
m68k/shared/gdbstub.
support to the shared gdb stub glue thus adding a directory.
* startup/Makefile.am: Compile the m68k gdb stub and glue.
* gdbstub: New directory.
* Makefile.am: Modified to reflect above.
* Added m68k serial stub that is thread aware.
* ChangeLog, gdb_if.h, m68k-stub.c, Makefile.am: New files.
* configure.ac: Add RTEMS_PROG_CCAS
* aclocal/prog-ccas.m4: New.
* aclocal/canonicalize-tools.m4: Remove AS, OBJCOPY, NM, SIZE, STRIP.
RTEMS_GCC_PRINT
* aclocal/check-multiprocessing.m4: Fix typo.
* automake/compile.am: Remove CXX support.
Replace AS by CCAS. Remove LINK_LIBS, LINK_OBJS, LINK_FILES.
RTEMS_GCC_PRINT
* configure.ac: Use AC_CONFIG_AUX_DIR(../..).
Add AC_PROG_RANLIB.
* configure.ac: Use AC_CONFIG_AUX_DIR(..).
* configure.ac: Use AC_CONFIG_AUX_DIR(../../../..).
Add AC_PROG_RANLIB.
* autotools/automake-rtems.spec.in: Update to automake-1.6.2.
* wrapup/Makefile.am: Build libnetapps.a.
Don't preinstall libnetapps.a
* Makefile.am: Pickup libnetapps.a from build directory.
* wrapup/Makefile.am: Don't preinstall libmisc.a.
* Makefile.am: Pickup libmisc.a from build directory.
Remove libxdr.a.
* ChangeLog: Fix bogus changelog entries.
* wrapup/Makefile.am: Don't preinstall libnetworking.a.
* wrapup/Makefile.am: Don't preinstall libfs.a.
* src/Makefile.am: Don't preinstall libblock.a.
* configure.ac: Remove references to RTEMS_BSP.
* src/Makefile.am: Add libposix.a.
* src/Makefile.am: Add libitron.a.
* aclocal/check-multiprocessing.m4: Remove references to RTEMS_BSP.
Allow building w/ --enable-multiprocessing --enable-multilib.
* aclocal/enable-multiprocessing.m4:
Eliminate RTEMS_HAS_MULTIPROCESSING.
* wrapup/Makefile.am: Remove libxdr.a.
Remove RTEMS_CANONICAL_HOST.
Use RTEMS_ENV_RTEMSCPU.
Add AC_PROG_RANLIB.
* include/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/rpcsvc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
ACLOCAL_AMFLAGS = -I ../aclocal.
* src/rpc/PSD.doc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/rpc/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* src/xdr/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* wrapup/Makefile.am: Fix stupid typo in previous patch.
* configure.ac: Add librpc. AC_PROG_RANLIB.
* wrapup/Makefile.am: Add librpc.
Use relative path to lib*.a for
POSIX_OBJS, ITRON_OBJS, NETWORKING_OBJS.
* configure.ac: Remove librpc.
* Per PR233, moved librpc to exec. Ralf will patch after move.
The patches associated with this PR are out of date.
* configure.ac, wrapup/Makefile.am: Modified.
* librpc, librpc/ChangeLog: Removed.
./include/rpc/.cvsignore, ./include/rpc/Makefile.am,
./include/rpc/auth.h, ./include/rpc/auth_des.h,
./include/rpc/auth_unix.h, ./include/rpc/clnt.h,
./include/rpc/des.h, ./include/rpc/des_crypt.h,
./include/rpc/pmap_clnt.h, ./include/rpc/pmap_prot.h,
./include/rpc/pmap_rmt.h, ./include/rpc/rpc.h,
./include/rpc/rpc_com.h, ./include/rpc/rpc_msg.h,
./include/rpc/svc.h, ./include/rpc/svc_auth.h,
./include/rpc/types.h, ./include/rpc/xdr.h,
./include/.cvsignore, ./include/Makefile.am,
./include/rpcsvc/.cvsignore, ./include/rpcsvc/Makefile.am,
./include/rpcsvc/bootparam_prot.x, ./include/rpcsvc/crypt.x,
./include/rpcsvc/key_prot.x, ./include/rpcsvc/klm_prot.x,
./include/rpcsvc/mount.x, ./include/rpcsvc/nfs_prot.x,
./include/rpcsvc/nis.x, ./include/rpcsvc/nis_cache.x,
./include/rpcsvc/nis_callback.x, ./include/rpcsvc/nis_db.h,
./include/rpcsvc/nis_object.x, ./include/rpcsvc/nis_tags.h,
./include/rpcsvc/nislib.h, ./include/rpcsvc/nlm_prot.x,
./include/rpcsvc/pmap_prot.x, ./include/rpcsvc/rex.x,
./include/rpcsvc/rnusers.x, ./include/rpcsvc/rquota.x,
./include/rpcsvc/rstat.x, ./include/rpcsvc/rwall.x,
./include/rpcsvc/sm_inter.x, ./include/rpcsvc/spray.x,
./include/rpcsvc/yp.x, ./include/rpcsvc/yp_prot.h,
./include/rpcsvc/ypclnt.h, ./include/rpcsvc/yppasswd.x,
./include/rpcsvc/ypupdate_prot.x, ./include/rpcsvc/ypxfrd.x,
./.cvsignore, ./Makefile.am, ./README_RTEMS,
./configure.ac, ./src/rpc/PSD.doc/.cvsignore,
./src/rpc/PSD.doc/Makefile.am, ./src/rpc/PSD.doc/nfs.rfc.ms,
./src/rpc/PSD.doc/rpc.prog.ms, ./src/rpc/PSD.doc/rpc.rfc.ms,
./src/rpc/PSD.doc/rpcgen.ms, ./src/rpc/PSD.doc/xdr.nts.ms,
./src/rpc/PSD.doc/xdr.rfc.ms, ./src/rpc/.cvsignore,
./src/rpc/DISCLAIMER, ./src/rpc/Makefile.am,
./src/rpc/README, ./src/rpc/auth_des.c,
./src/rpc/auth_none.c, ./src/rpc/auth_time.c,
./src/rpc/auth_unix.c, ./src/rpc/authdes_prot.c,
./src/rpc/authunix_prot.c, ./src/rpc/bindresvport.3,
./src/rpc/bindresvport.c, ./src/rpc/clnt_generic.c,
./src/rpc/clnt_perror.c, ./src/rpc/clnt_raw.c,
./src/rpc/clnt_simple.c, ./src/rpc/clnt_tcp.c,
./src/rpc/clnt_udp.c, ./src/rpc/clnt_unix.c,
./src/rpc/crypt_client.c, ./src/rpc/des_crypt.3,
./src/rpc/des_crypt.c, ./src/rpc/des_soft.c,
./src/rpc/get_myaddress.c, ./src/rpc/getpublickey.c,
./src/rpc/getrpcent.3, ./src/rpc/getrpcent.c,
./src/rpc/getrpcport.3, ./src/rpc/getrpcport.c,
./src/rpc/key_call.c, ./src/rpc/key_prot_xdr.c,
./src/rpc/netname.c, ./src/rpc/netnamer.c,
./src/rpc/pmap_clnt.c, ./src/rpc/pmap_getmaps.c,
./src/rpc/pmap_getport.c, ./src/rpc/pmap_prot.c,
./src/rpc/pmap_prot2.c, ./src/rpc/pmap_rmt.c,
./src/rpc/publickey.3, ./src/rpc/publickey.5,
./src/rpc/rpc.3, ./src/rpc/rpc.5, ./src/rpc/rpc_callmsg.c,
./src/rpc/rpc_commondata.c, ./src/rpc/rpc_dtablesize.c,
./src/rpc/rpc_prot.c, ./src/rpc/rpc_secure.3,
./src/rpc/rpcdname.c, ./src/rpc/rstat.1,
./src/rpc/rstat_svc.8, ./src/rpc/rtems_portmapper.c,
./src/rpc/rtems_rpc.c, ./src/rpc/rtime.3, ./src/rpc/rtime.c,
./src/rpc/svc.c, ./src/rpc/svc_auth.c,
./src/rpc/svc_auth_des.c, ./src/rpc/svc_auth_unix.c,
./src/rpc/svc_raw.c, ./src/rpc/svc_run.c,
./src/rpc/svc_simple.c, ./src/rpc/svc_tcp.c,
./src/rpc/svc_udp.c, ./src/rpc/svc_unix.c,
./src/xdr/.cvsignore, ./src/xdr/Makefile.am, ./src/xdr/xdr.3,
./src/xdr/xdr.c, ./src/xdr/xdr_array.c,
./src/xdr/xdr_float.c, ./src/xdr/xdr_mem.c,
./src/xdr/xdr_rec.c, ./src/xdr/xdr_reference.c,
./src/xdr/xdr_sizeof.c, ./src/xdr/xdr_stdio.c,
./src/.cvsignore, ./src/Makefile.am: Moved to exec.
* aclocal/subdirs.m4: Remove.
* Makefile.am: Remove commented out net-apps.
* wrapup/Makefile.am: Use relative path to lib*.a for
LIBCSUPPORT_OBJS, LIBBLOCK_OBJS, LIBDOSFS_OBJS, LIBIMFS_OBJS.
* Makefile.am: Merge src/Makefile.am.
* src/Makefile.am: Remove.
* aclocal/env-rtemscpu.m4: Remove.
* aclocal/multi.m4: Remove.
* aclocal/multilib.m4: Remove RTEMS_ENABLE_MULTILIB_MASTER.
* Makefile.am: Include $(top_srcdir)/automake/*.am.
Use aclocal.
* sapi/include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/inline/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/macros/Makefile.am: Include $(top_srcdir)/automake/*.am.
* sapi/src/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/cpu/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/inline/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/macros/Makefile.am: Include $(top_srcdir)/automake/*.am.
* score/src/Makefile.am: Include $(top_srcdir)/automake/*.am.
* wrapup/Makefile.am: Include $(top_srcdir)/automake/*.am.
* include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/include/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/inline/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/macros/Makefile.am: Include $(top_srcdir)/automake/*.am.
* rtems/src/Makefile.am: Include $(top_srcdir)/automake/*.am.
* Include $(top_srcdir)/automake/*.am. Use aclocal/.
* Makefile.am: Include $(top_srcdir)/../../../automake/*.am.
Use ../../../aclocal.
Use ../aclocal.
