* binaries.t, buildc.t: Use @value{RTEMSRPMPREFIX} in refs to rpms.
* configure.ac: Add RTEMS_ENABLE_RPMPREFIX.
Add RTEMSRPMPREFIX.
* common/rtems.texi.in: Add RTEMSRPMPREFIX.
wrapup/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, startup/Makefile.am,
* start/start.S: Replace #-ASM-style comments with C-/**/ comments.
* start/reg.S: Remove //-comments
* Makefile.am: Merge-in clock/.cvsignore, console/.cvsignore,
irq/.cvsignore, network/.cvsignore, startup/.cvsignore,
vectors/.cvsignore. Use automake compilation rules.
* clock/.cvsignore, console/.cvsignore, irq/.cvsignore,
network/.cvsignore, startup/.cvsignore, vectors/.cvsignore: Remove.
* wrapup/Makefile: Reflect changes above.
network/Makefile.am, nvram/Makefile.am, pci/Makefile.am,
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am,
universe/Makefile.am, vectors/Makefile.am. Use automake compilation
rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
nvram/Makefile.am, pci/Makefile.am, startup/Makefile.am,
timer/Makefile.am, tod/Makefile.am, universe/Makefile.am,
vectors/Makefile.am: Remove.
PCI_bus/Makefile.am, startup/Makefile.am, timer/Makefile.am,
tod/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, PCI_bus/Makefile.am,
ide/Makefile.am, irq/Makefile.am, network/Makefile.am,
startup/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, ide/Makefile.am,
irq/Makefile.am, network/Makefile.am, startup/Makefile.am,
* Makefile.am: Merge-in dlentry/Makefile.am, flashentry/Makefile.am,
startup/Makefile.am. Use automake compilation rules.
* dlentry/Makefile.am, flashentry/Makefile.am, startup/Makefile.am:
Remove.
scv64/Makefile.am, sonic/Makefile.am, start/Makefile.am,
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, scv64/Makefile.am,
sonic/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, tod/Makefile.am: Remove.
* configure.ac, wrapup/Makefile.am: Reflect changes above.
* Makefile.am: Merge-in dlentry/Makefile.am, startup/Makefile.am. Use
* dlentry/Makefile.am, startup/Makefile.am: Remove.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
startup/Makefile.am, timer/Makefile.am, vectors/Makefile.am: Remove.
* Makefile.am: Merge-in canbus/Makefile.am, clock/Makefile.am,
console/Makefile.am, irq/Makefile.am, network/Makefile.am,
* canbus/Makefile.am, clock/Makefile.am, console/Makefile.am,
* wrapup/Makefile.am: Remove.
* configure.ac: Remove wrapup.
* shared/Makefile.am: Use automake compilation rules.
Build *.rels.
irq/Makefile.am, motorola/Makefile.am, openpic/Makefile.am,
pci/Makefile.am, residual/Makefile.am, start/Makefile.am,
startup/Makefile.am, vectors/Makefile.am, vme/Makefile.am.
Rename clock.rel to pclock.rel (Conflict with libcpu).
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
motorola/Makefile.am, openpic/Makefile.am, pci/Makefile.am,
residual/Makefile.am, start/Makefile.am, startup/Makefile.am,
vectors/Makefile.am, vme/Makefile.am: Remove.
PR pppd/564
* libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h,
libnetworking/net/ppp_tty.c: ppp0 Interface lose packets if the
system use a slow baudrate for the modem or the tcp/ip-packet is
fragmented.
* ChangeLog, rtems/Makefile.am, rtems/include/rtems/rtems/support.h:
Reverse developmental patches accidentally committed.
PR pppd/564
* rtems/Makefile.am, rtems/include/rtems/rtems/support.h: ppp0
Interface lose packets if the system use a slow baudrate for the
modem or the tcp/ip-packet is fragmented.
* Makefile.am: Merge-in start/Makefile.am.
* start/Makefile.am: Remove.
* wrapup/Makefile.am: Reflect changes to
../support/*exception_processing/*.
* configure.ac: Add RTEMS_PROG_CCAS.
* Makefile.am: Use automake compilation rules.
* Makefile.am: Cosmetics.
* configure.ac: Add RTEMS_ENV_RTEMSBSP.
* Makefile.am: Merge-in debug_ada/Makefile.am, debug_c/Makefile.am,
dos_sup/Makefile.am, network_ada/adasockets/Makefile.am,
network_ada/Makefile.am, network_ada/listener/Makefile.am,
network_ada/tcprelay/Makefile.am, ts_1325_ada/Makefile.am. Use automake
compilation rules.
* debug_ada/Makefile.am, debug_c/Makefile.am, dos_sup/Makefile.am,
network_ada/adasockets/Makefile.am, network_ada/Makefile.am,
network_ada/listener/Makefile.am, network_ada/tcprelay/Makefile.am,
ts_1325_ada/Makefile.am: Remove.
network/Makefile.am, startup/Makefile.am, timer/Makefile.am,
PR 561/rtems
* asm.h: Add CONCAT0, EVAL. Let SYM and REG use CONCAT0 and EVAL.
compilation rules.
* Makefile.am: Merge-in clock/Makefile.am, gdbsci/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am, console/Makefile.am,
scitab/Makefile.am, trap34/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, gdbsci/Makefile.am, startup/Makefile.am,
wrapup/Makefile.am, console/Makefile.am, scitab/Makefile.am,
trap34/Makefile.am: Remove.
* Makefile.am: Merge-in console/Makefile.am, hw_init/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
* console/Makefile.am, hw_init/Makefile.am, startup/Makefile.am,
* Makefile.am: Merge-in console/Makefile.am, scitab/Makefile.am,
* console/Makefile.am, scitab/Makefile.am,
startup/Makefile.am, wrapup/Makefile.am: Remove.
wrapup/Makefile.am.
Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
* Makefile.am: Merge-in clock/Makefile.am, erc32sonic/Makefile.am,
startup/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am,
* clock/Makefile.am, erc32sonic/Makefile.am, startup/Makefile.am,
console/Makefile.am, gnatsupp/Makefile.am, timer/Makefile.am,
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am.
* include/bsp.h: Remove config.
* irq/irq.c: Remove stray blanks.
* start/start.S: Add missing */ in comments.
