* mpc83xx/include/mpc83xx.h: #include <bspopts.h> to make sure
defines from bspopts.h get propagated.
* include/bsp.h: #include <bspopts.h> first.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Remove scitab.c (Not applicable).
* custom/brs5l.cfg, custom/gen5200.cfg, custom/gen83xx.cfg,
custom/genmcf548x.cfg, custom/hsc_cm01.cfg, custom/icecube.cfg,
custom/m5484FireEngine.cfg, custom/mpc5566evb.cfg,
custom/mpc55xx.cfg, custom/mpc8313erdb.cfg, custom/mpc8349eamds.cfg,
custom/pgh360.cfg, custom/pghplus.cfg, custom/pm520_cr825.cfg,
custom/pm520_ze30.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg:
Back out parts of yesterdays changes.
* custom/gen83xx.cfg, custom/lpc2478.cfg: Remove warning flags.
PR 1324/bsps
* aclocal/check-bsps.m4: Revert Joel's icecube patch.
* include/irq-config.h: New file.
* startup/spurious.c: Removed.
* custom/score603e.cfg: Modifications required to run on hardware. Some
cleanup.
* Makefile.am, preinstall.am, PCI_bus/universe.c, console/console.c,
include/bsp.h, irq/FPGA.c, irq/irq.c, startup/Hwr_init.c,
startup/bspstart.c, startup/vmeintr.c: Modifications required to run
on hardware. Some cleanup.
* custom/m5484FireEngine.cfg:
Eliminate RTEMS_54XX_DERIVATE (Unused).
* custom/pghplus.cfg, custom/tqm8xx.cfg, custom/tqm8xx_stk8xx.cfg:
Eliminate RTEMS_TQM_MODEL (Unused).
custom/lpc2478.cfg, custom/m5484FireEngine.cfg,
custom/mpc5566evb.cfg, custom/mpc55xx.cfg, custom/mpc8313erdb.cfg,
custom/mpc8349eamds.cfg, custom/pgh360.cfg, custom/pm520_cr825.cfg
custom/pm520_ze30.cfg: Remove RTEMS_BOARD_MODEL.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* bsp_howto/timer.t: Eliminate uses of old benchmark timer names.
* include/tm27.h: Do not use set_vector.
* preinstall.am: Regenerated.
* sh7750/score/ispsh7750.c, shgdb/score/ispshgdb.c: Fine tune
conditional so _CPU_ISR_install_vector is in CPU Kit now.
* cpu.c: Fine tune conditional so _CPU_ISR_install_vector is in CPU Kit
now.
* custom/simsh1.cfg, custom/simsh2.cfg, custom/simsh4.cfg: Make all use
RTEMS_BSP_FAMILY.
* Makefile.am, preinstall.am: Add timer driver stub.
* acinclude.m4: simsh4 folded into shsim.
* Makefile.am, preinstall.am, include/bsp.h, include/tm27.h,
trap34/console-io.c: Now builds cleanly for runs for SH1, SH2, and
SH4.
* include/syscall.h: New file.
* include/gdbsci.h: Removed.
* start/startfor340only.S: Remove (Unused).
* include/tm27.h: Now links all tests.
* simsh4/.cvsignore, simsh4/ChangeLog, simsh4/Makefile.am,
simsh4/README, simsh4/bsp_specs, simsh4/configure.ac,
simsh4/preinstall.am, simsh4/clock/ckinit.c,
simsh4/console/console.c, simsh4/include/.cvsignore,
simsh4/include/bsp.h, simsh4/include/coverhd.h,
simsh4/include/ramdisk.h, simsh4/include/syscall.h,
simsh4/include/tm27.h, simsh4/start/start.S,
simsh4/startup/hw_init.c, simsh4/startup/linkcmds,
simsh4/startup/linkcmds-le, simsh4/startup/linkcmds-le.coff,
simsh4/timer/timer.c, simsh4/tools/.cvsignore,
simsh4/tools/ChangeLog, simsh4/tools/Makefile.am,
simsh4/tools/configure.ac, simsh4/tools/runtest.in: Removed.
* Makefile.am: Eliminate bsp.am. Cleanup.
* shgdb/score/ispshgdb.c: Add dummy _CPU_ISR_install_vector.
* Makefile.am, preinstall.am: Now links all tests.
* include/tm27.h: New file.
* include/tm27.h: Remove reference to set_vector.
* clock/clockdrv.c: Correct spelling error in comment.
* include/tm27.h: Delete duplicate #endif.
* mcf5206/timer/timerisr.S: Make compile again.
* clockdrv_shell.c: Empty file. Add warning to not use this file.
* clock_driver_simidle.c: include clockdrv_shell.h.
* clock/clockdrv.c: include "../../../shared/clockdrv_shell.h".
* liblnk/regs.S: Remove (Renamed into liblnk/regs.h).
* liblnk/regs.h: New (Renamed from liblnk/regs.S).
* Makefile.am, liblnk/pmon.S: Reflect renamer.
* clock/clock.c: include "../../../shared/clockdrv_shell.h".
* clock/ckinit.c: include "../../../shared/clockdrv_shell.h".
