PR 1947/doc
* started/buildrt.t: Make note that native toolset is needed to
configure and build RTEMS.
* libcsupport/src/newlibc_exit.c: Don't undef __USE_INIT_FINI__.
PR 1944/misc
* libchip/serial/mc68681.c: Remove #if 0.
* libmisc/monitor/mon-monitor.c (rtems_monitor_wakeup):
Remove unused var "status" (Avoid warning).
* Makefile.am: Fix DIST_SUBDIRS.
Reformat.
Add support/fstest.h.
* mouse01/init.c: Account for extra message buffer size.
* ftp01/init.c: Account for extra FTP worker task stack sizes.
* ftpd/ftpd.h, ftpd/ftpd.c: Moved buffer and stack size constants into
header file.
* ftpd/ftpd.c: Increased data buffer size to 4096 bytes. Use
RTEMS_MINIMUM_STACK_SIZE plus the data buffer size for worker thread
stack size.
* libfs/src/imfs/imfs.h: Add IMFS_memfile_maximum_size.
* shared/can/occan.c: Comment out unused var "tmp".
* network/network.c: Remove unused var "dptr".
* libchip/serial/ns16550.c (ns16550_init):
Remove unused var "ucTrash".
* support/include/tmacros.h:
Remove fatal_posix_service_pointer_minus_one (unused).
* psxmsgq01/init.c: Introduce fatal_posix_mqd.
Replace fatal_posix_service_pointer_minus_one with fatal_posix_mqd.
* psxsem01/init.c: Introduce fatal_posix_sem.
Replace fatal_posix_service_pointer_minus_one with fatal_posix_sem.
* psxreaddir/test.c: Remove bogus casts.
Fix fprintf format strings.
* rtems/Makefile.am: Add src/status.c.
* rtems/include/rtems/rtems/status.h: Make
_Status_Object_name_errors_to_status an external variable.
* rtems/src/status.c: New (split out from
rtems/include/rtems/rtems/status.h).
* rtems/Makefile.am: Reformat.
* configure.ac: Check for decls of utime and utimes.
PR 1942/cpukit:
* score/src/schedulercbsdetachthread.c: Move initialization of var
"sched_info" down (Avoid it being used uninitialized).
* libchip/network/smc91111.c (lan91cxx_recv):
Define var "lp" conditionally (Avoid warning).
* libcsupport/src/utimes.c (utimes): Remove casts to time_t.
* page.c: Remove unused var "dirCount".
* psxfile01/test.c: Remove local redeclaration of IMFS_dump.
* shared/comm/uart.c (uartError): Remove unused var "uartStatus".
* libchip/network/dec21140.c (dec21140_rxDaemon):
Remove unused var "tbase".
* libchip/rtc/mc146818a.c (mc146818a_initialize):
Remove unused var "getReg".
* libchip/rtc/mc146818a.c (mc146818a_set_time):
* malloc04/init.c: Define p1, p2, p3, p4 extern (Avoid warnings).
* console/console.c (ISS_output_char): Add return type.
* timer/timer.c: Remove unused vars "old_ie".
* nios2-mpu-configuration.c, nios2-mpu-descriptor.c,
nios2-mpu-disable-protected.c, nios2-mpu-reset.c: New files.
* rtems/score/nios2-utility.h, nios2-context-initialize.c: Added
support for the memory protection unit (MPU).
* automake/compile.am: Remove -Werror=...
* libchip/display/disp_hcms29xx.c: Remove ARRAY_COUNT (unused).
* console.c: Include <rtems/error.h> for rtems_panic().
* libnetworking/net/if_ethersubr.c (ether_output):
Remove unused vars "hlen", "off".
* score/include/rtems/score/rbtree.h (_RBTree_Container_of):
Use offsetof. Don't cast to size_t. Include <stddef.h>.
PR 1940/misc:
* libchip/serial/ns16550.c: Reflect changes to console-driver.
* libnetworking/libc/res_mkupdate.c (res_mkupdate):
Remove unused var "sp1".
* libfs/src/dosfs/msdos_file.c (msdos_file_datasync):
Remove unused var "rc".
PR 1926/bsps
* timer/timer.c: New file.
* Makefile.am: Reflect change above.
* MAINTAINERS: Remove references to c4x, or32 (abandoned).
* libchip/network/smc91111.c: Use PRIxPTR to print pointers.
* psxtmbarrier01/init.c, psxtmbarrier02/init.c, psxtmbarrier03/init.c,
psxtmkey01/init.c, psxtmkey02/init.c, psxtmmq01/init.c,
psxtmmutex01/init.c, psxtmmutex02/init.c, psxtmmutex03/init.c,
psxtmmutex04/init.c, psxtmmutex05/init.c, psxtmmutex06/init.c,
psxtmmutex07/init.c, psxtmnanosleep01/init.c, psxtmnanosleep02/init.c,
psxtmrwlock01/init.c, psxtmrwlock02/init.c, psxtmrwlock03/init.c,
psxtmrwlock04/init.c, psxtmrwlock05/init.c, psxtmrwlock06/init.c,
psxtmrwlock07/init.c, psxtmsem01/init.c, psxtmsem02/init.c,
psxtmsem03/init.c, psxtmsem04/init.c, psxtmsem05/init.c,
psxtmsleep01/init.c, psxtmsleep02/init.c, psxtmthread03/init.c:
Use benchmark_timer_t for benchmark_timer values (Avoid 64bit
arch issues).
* include/rtems/btimer.h: Introduce benchmark_timer_t.
Let benchmark_timer_read return benchmark_timer_t.
* console.c: RTEMS_DEBUG is a define, not a variable.
PR 1939/cpukit
* rtems/src/ratemonperiod.c: Fixed type mismatch.
