* | libblock: Init deps in rtems_blkdev_create() | Sebastian Huber | 2018-05-18 | 3 | -6/+19 | |
| | | | | Update #3358. | |||||
* | sparc64 BSPs: Hard define configuration required settings | Joel Sherrill | 2018-05-15 | 2 | -13/+3 | |
| | | | | Updates #3425. | |||||
* | rtems-bsps: Change 4.12 to 5 | Joel Sherrill | 2018-05-14 | 1 | -1/+1 | |
* | Drop executable permissions on .[S] files | Joel Sherrill | 2018-05-14 | 1 | -0/+0 | |
* | spcpucounter01: Enable floating-point output | Sebastian Huber | 2018-05-14 | 1 | -0/+1 | |
* | build: Fix RTEMS_ENABLE_RTEMSBSP() | Sebastian Huber | 2018-05-14 | 1 | -3/+7 | |
| | | | | | | The riscv32 and riscv64 targets share a riscv source directory. The potential future powerpcspe and powerpc targets need this change as well. | |||||
* | no_cpu/no_bsp: Fix Makefile | Amaan Cheval | 2018-05-14 | 1 | -1/+1 | |
* | dev/sc16is752: Add ioctl calls for modem controll. | Christian Mauderer | 2018-05-14 | 2 | -1/+96 | |
| | | | | | | | | This add ths following ioctl calls to the sc16is752 driver: - TIOCMGET - TIOCMSET - TIOCMBIS - TIOCMBIC | |||||
* | sparc64 niagara, usiii: Remove -D options from cfg file and move to bspopts.h | Joel Sherrill | 2018-05-09 | 9 | -3/+34 | |
* | smdk2410: Move define of CPU_S3C2410 to bspopts.h | Joel Sherrill | 2018-05-09 | 4 | -3/+12 | |
* | rtl22xx_t.cfg: Remove comment with -D __THUMB_INTERWORK__ | Joel Sherrill | 2018-05-08 | 1 | -4/+0 | |
* | ftpd: Fix infinite recursion in yield() | Sebastian Huber | 2018-05-08 | 1 | -1/+1 | |
| | | | | Update #3419. | |||||
* | telnetd: Use syslog() instead of printk() | Sebastian Huber | 2018-05-02 | 1 | -2/+8 | |
* | telnetd: Always build telnet daemon | Sebastian Huber | 2018-05-02 | 4 | -31/+76 | |
| | | | | | | Add support for libbsd initialization. Update #3419. | |||||
* | ftpd: Always build FTP daemon | Sebastian Huber | 2018-05-02 | 4 | -36/+66 | |
* | ftpd: Use floating-point tasks due to syslog() | Sebastian Huber | 2018-05-02 | 1 | -1/+1 | |
* | ftpd: Fairplay with libbsd | Sebastian Huber | 2018-05-02 | 1 | -0/+18 | |
* | network: Import latest <arpa/ftp.h> from FreeBSD | Sebastian Huber | 2018-05-02 | 3 | -7/+10 | |
* | ftpfs: Always build FTP client | Sebastian Huber | 2018-05-02 | 5 | -3/+9 | |
| | | | | | | Move FTP client filesystem to separate library libftpfs.a. Update #3419. | |||||
* | tftpfs: Always build TFTP client | Sebastian Huber | 2018-05-02 | 5 | -6/+24 | |
| | | | | | | | Move TFTP client filesystem to separate library libtftpfs.a. Conditionally use legacy network stack features, e.g. BOOTP support. Update #3419. | |||||
* | libdebugger: Move to separate library | Sebastian Huber | 2018-05-02 | 6 | -14/+11 | |
| | | | | | | | | | | Always build remote TCP support since it depends only on the POSIX socket API. It works with the legacy network stack and libbsd. Move it to a separate libdebugger.a library to allow an easy use with libbsd via "-ldebugger -lbsd" otherwise we would have a cyclic dependency between libbsd.a and librtemscpu.a. Update #3419. | |||||
* | tests: Move rtems-test-check.py | Sebastian Huber | 2018-05-02 | 3 | -204/+1 | |
| | | | | Remove shell script variant. | |||||
* | tests: Remove difftest and sorttimes tools | Sebastian Huber | 2018-05-02 | 7 | -364/+0 | |
| | | | | Close #3418. | |||||
* | tests: Remove configure feature checks | Sebastian Huber | 2018-05-02 | 23 | -334/+11 | |
| | | | | Update #3409. | |||||
* | Drop executable permissions on .[ch] files | Joel Sherrill | 2018-04-30 | 22 | -0/+0 | |
* | jffs2: Do not use command line defines | Sebastian Huber | 2018-04-30 | 21 | -2/+40 | |
| | | | | Update #3375. | |||||
* | config: Fix -Wint-in-bool-context warnings | Sebastian Huber | 2018-04-30 | 1 | -1/+1 | |
* | smptests/smpschededf02: Add test case | Sebastian Huber | 2018-04-27 | 1 | -3/+8 | |
* | bsp/pc386: Remove bin2boot support | Sebastian Huber | 2018-04-27 | 7 | -857/+0 | |
| | | | | | Update #3408. Close #3410. | |||||
* | bsp/mcf5206elite: Do not install runtest script | Sebastian Huber | 2018-04-26 | 5 | -48/+0 | |
| | | | | | | | Provide the runtest script only as a part of the sources. This simplifies the build system. Test support should be included in the RTEMS Tester. | |||||
* | bsps: Move documentation, etc. files to bsps | Sebastian Huber | 2018-04-26 | 127 | -0/+0 | |
| | | | | | | This patch is a part of the BSP source reorganization. Update #3285. | |||||
* | bsps: Remove unmaintained times files | Sebastian Huber | 2018-04-26 | 4 | -765/+0 | |
* | bsp/sparc64: Move asm.S to bsps and rename | Sebastian Huber | 2018-04-26 | 3 | -2/+2 | |
* | bsps/mips: Move liblnk to bsps | Sebastian Huber | 2018-04-26 | 5 | -6/+6 | |
* | bsps/powerpc: Move bsp-start-zero.S to bsps | Sebastian Huber | 2018-04-26 | 5 | -4/+4 | |
* | bsp/psim: Move align_h.S to bsps | Sebastian Huber | 2018-04-26 | 2 | -1/+1 | |
* | bsp/haleakala: Move assembler files to bsps | Sebastian Huber | 2018-04-26 | 3 | -2/+2 | |
* | bsp/qemuppc: Install linkcmds.base | Sebastian Huber | 2018-04-25 | 1 | -0/+1 | |
| | | | | | Update #3339. Close #3411. | |||||
* | bsps/arm: Remove unused files | Sebastian Huber | 2018-04-25 | 13 | -17990/+0 | |
* | bsps: Remove unused u-boot-generic-board-info.h | Sebastian Huber | 2018-04-25 | 2 | -137/+1 | |
* | bsp/beagle: Move source files to bsps | Sebastian Huber | 2018-04-25 | 5 | -4/+4 | |
* | bsp/gumstix: Move fb.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -1/+1 | |
* | bsp/lm3s69xx: Move ssi.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -1/+1 | |
* | bsp/lpc176x: Move source files to bsps | Sebastian Huber | 2018-04-25 | 15 | -433/+433 | |
* | bsp/lpc24xx: Move source files to bsps | Sebastian Huber | 2018-04-25 | 10 | -9/+9 | |
* | bsp/lpc32xx: Move source files to bsps | Sebastian Huber | 2018-04-25 | 12 | -11/+11 | |
* | bsp/raspberrypi: Move source files to bsps | Sebastian Huber | 2018-04-25 | 7 | -4/+4 | |
* | bsp/smdk2410: Move smc.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -1/+1 | |
* | bsp/tms570: Move cpucounterread.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -1/+1 | |
* | bsp/mcf5206elite: Move nvram.c to bsps | Sebastian Huber | 2018-04-25 | 2 | -1/+1 | |
