* Makefile.am: Removed definition of ACLOCAL_AMFLAGS.
* Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
* Makefile.am, cpu_asm.S, psmacro.ah, rtems/score/cpu.h:
First attempt to compile with GNU tools. Minor modifications
to compile enough to get to assembler errors.
* src/objectgetbyindex.c: Do not enable dispatching on an
error path it was not disabled on.
* include/mvme16x_hw.h: Include rtems/score/targopts.h so we
can check which BSP this is being used with.
* Makefile.am: Referenceed aclocal/enable-hwapi.m4 that was removed.
* aclocal/enable-hwapi.m4: Now longer used and removed.
* automake/lib.am: Remove leaf.cfg.
* bsp_specs, console/Makefile.am, include/Makefile.am: Clean up.
* Makefile.am, bsp_specs, configure.in, console/Makefile.am,
include/Makefile.am, irq/Makefile.am, irq/irq.c, start/Makefile.am,
startup/Makefile.am, startup/exit.c, wrapup/Makefile.am:
Made to conform to current practice concerning automake and
autoconf. Corrected minor warnings.
* custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/dmv177.cfg,
custom/mcp750.cfg, custom/vegaplus.cfg: Clean up.
* vegaplus BSP submitted by Emmanuel Raguet <raguet@crf.canon.fr> and
Eric Valette <valette@crf.canon.fr>.
* custom/vegaplus.cfg: New file.
* vegaplus/bsp_specs, configure.in, console/Makefile.am,
include/Makefile.am, include/bsp.h, include/registers.h,
irq/Makefile.am, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c,
irq/irq.h, start/Makefile.am, start/start.S, startup/Makefile.am,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
wrapup/Makefile.am: New files.
* leaf.cfg: Remove Depends inclusion.
* aclocal/rtems-top.m4: Add ENDIF-hack.
* automake/compile.am: Add include $(DEPENDS) + ENDIF-hack.
* custom/erc32.cfg: Add comment on -mno-v8, -mcypress.
* custom/gen68302.cfg: Comment out LIBC_LIB[C|M].
* custom/gen68340.cfg: Comment out LIBC_LIB[C|M].
* custom/gen68360.cfg: Comment out LIBC_LIB[C|M].
* custom/idp.cfg: Comment out LIBC_LIB[C|M].
* custom/mvme162.cfg: Comment out LIBC_LIB[C|M].
* custom/ods68302.cfg: Comment out LIBC_LIB[C|M].
* leaf.cfg: Remove include ${CONFIG.CC}, add MANAGERS, START_FILE,
LINKCMDS handling.
* default.cfg.in: Remove everything but START_BASE.
* configure.in: Add RTEMS_PROG_CC_FOR_TARGET,
RTEMS_CANONICALIZE_TOOLS.
* aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS)
* aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28,
add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272.
* automake/compile.am: Replaced.
* automake/local.am: Remove building variant handling.
* rtems/score/i386.h: Corrected "#elsif" to be "#elif".
* start/Makefile.am: Remove AM_CPPFLAGS and GAS_CODE16 conditional.
* startup/Makefile.am: Cleanup comments.
* aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE,
AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS).
* aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS.
* aclocal/target.m4: Cleanup comments
* Automake/compile.am: Add DEFS support to keep building happy.
* target.cfg.in: Comment out DEFS.
* Makefile.am: Use += to set up AM_CPPFLAGS.
* custom/gensh2.cfg: Fix comments.
* multigen: Fix BARE_CPU_CFLAGS.
* custom/mvme167.cfg (CPP_CFLAGS): Corrected to only include
compiler arguments that specify CPU model options.
* custom/mbx860_005b.cfg (make-target-options): Add lines to
define PRINTK_MINOR SMC1_MINOR and PRINTK_IO_MODE. The settings
may be incorrect but the BSP now compiles.
* network/network.c (uti596_attach): Adjust cpp directives
and conditional braces so all cases compile.
* wrapup/rtems/Makefile.am: Use PROJECT_TOPdir in path to size_rtems.
* scitab/Makefile.am: PROJECT_TOPdir.
* rtems/score/Makefile.am: Use PROJECT_TOPdir in path to genoffsets.
* rtems/score/Makefile.am: Use PROJECT_TOPdir in path to gensize.
* aclocal/project-root.m4: Introduce PROJECT_TOPdir, add comments.
* multigen: Fix usage.
* ChangeLog: Cleanup.
* custom/arm_bare_bsp.cfg: Fix comments.
* network/Makefile.am: Use AM_*FLAGS += .. .
* ChangeLog: Fix formating.
* configure.in: Cleanup comments.
* io/Makefile.am: Formatting.
* Makefile.am: Formatting.
* Makefile.am, shared/Makefile.am, shared/comm/Makefile.am,
shared/irq/Makefile.am: Include compile.am
* stubdr/Makefile.am, wrapup/Makefile.am: Include compile.am
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Include compile.am
* tmitronsem01/Makefile.am: Include compile.am
* src/Makefile.am: Include compile.am
* src/i386/any/Makefile.am, src/powerpc/mcp750/Makefile.am: Include
compile.am
