-m528x as an order to load the -m5200 multilib variants) are widely available.
* ftpd/Makefile.am: Split preinstallation rules in to separate
preinstall.am-files.
* ftpd/preinstall.am: New (Generated from corresponding Makefile.am).
* librpc/Makefile.am: Split preinstallation rules in to separate
* librpc/preinstall.am: New (Generated from corresponding Makefile.am).
* Makefile.am: Split out preinstallation rules.
* preinstall.am: New (Split out from Makefile.am).
* httpd/Makefile.am: Split preinstallation rules in to separate
* httpd/preinstall.am: New (Generated from corresponding Makefile.am).
* itron/Makefile.am, libcsupport/Makefile.am,
libnetworking/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am,
* itron/preinstall.am, libcsupport/preinstall.am,
libnetworking/preinstall.am, posix/preinstall.am,
rtems/preinstall.am, sapi/preinstall.am,
score/preinstall.am, wrapup/preinstall.am,
preinstall.am: New (Generated from corresponding Makefile.ams).
* configure.ac: Add AM_CONDITIONAL(AMPOLISH3)-stub.
* configure.ac: Add new header guard to cpuopts.h.
* Makefile.am: Add libfs, libblock, ftpd header install rules.
* libfs/Makefile.am, libblock/Makefile.am, ftpd/Makefile.am: Remove
* aclocal/prog-cc.m4:
Quote CFLAGS's RHS to accomodate Solaris broken sh.
* aclocal/rtems-top.m4 (rtems_updir): Quote sed args.
* libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h:
Ansification, cosmetics from FreeBSD.
Levels range from 1 to 6.
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_load_tar.c,
libmisc/untar/untar.c, libmisc/untar/untar.h:
Various generalizations and fixes.
* Makefile.am: Add include/rtems/tar.h.
Merge-in header rules from libmisc/Makefile.am
* libmisc/Makefile.am: Remove header rules.
Remove lib-specific CPPFLAGS.
* configure.ac: Add checks for <tar.h>
* include/rtems/tar.h: New.
* custom/uC5282.cfg: Cleanup.
* libfs/Makefile.am: Build libfs/src/imfs/imfs_load_tar.c.
Enable UART2.
* libnetworking/libc/res_init.c, libnetworking/netinet/in.h,
libnetworking/netinet/in_pcb.c, libnetworking/netinet/raw_ip.c:
Misc. part. updates from FreeBSD.
* aclocal/enable-itron.m4: Allow unix.
* aclocal/check-itron.m4: Allow unix.
* make/bsp.mak: Remove CFLAGS_DEBUG_V.
* automake/compile.am: Remove depend: (Redundant).
* gcc3newlib/Makefile.am: Remove sh-rtemself. Add sh-rtemscoff.
* rtems/include/rtems/rtems/sem.h, rtems/src/semcreate.c,
rtems/src/semdelete.c, rtems/src/semflush.c,
rtems/src/semident.c, rtems/src/semobtain.c,
rtems/src/semrelease.c: Use rtems_id for semaphores.
* libcsupport/include/rtems/libio.h: Use rtems_id for semaphores.
Use char* for buffer.
* backward/ftpd.h: New.
* Makefile.am: Reflect having added backward/ftpd.h.
* optman/rtems/no-sem.c: Semaphores are rtems_id not Object_id.
* libnetworking/rtems_servers/ftp.c,
libnetworking/rtems_servers/ftp.h,
libnetworking/rtems_servers/Makefile.am:
Remove (relocated to cpukit/ftpd).
* configure.ac, Makefile.am, wrapup/Makefile.am: Reflect having
removed move libnetworking/rtems_servers.
PR 756/rtems
* ftpd/ftpd.c, ftpd/ftpd.h, ftpd/Makefile.am: New (relocated from
/c/src/libnetworking/ftpd)
* ftpd/ftd.h: New header guards.
* ftpd/Makefile.am: Install libftd.a, install ftp.h to rtems/ftp.h.
* configure.ac: Add ftpd/Makefile.
* Makefile.am: Add ftpd.
* console/console.c, include/bsp.h, network/network.c,
startup/bspstart.c: Remove obsolete fixed size types.
* startup/bspstart.c:
rtems_interrupt_catch(trampoline, vector, &old_handler).
* rtems/mips/idtcpu.h, rtems/mips/iregdef.h, rtems/score/mips.h:
Header guards cleanup.
