* Replaced critical section algorithm to correct race conditions.Joel Sherrill1995-12-012-20/+38
* Made _Event_Sync volatileJoel Sherrill1995-12-013-6/+45
| | | | | | Replaced critical section algorithm to correct race conditions. This resulted in the new variable _Event_Sync_state and the type _Event_Sync_states.
* Corrected use of the state WATCHDOG_REINSERT and renamed itJoel Sherrill1995-12-015-24/+50
| | | | WATCHDOG_BEING_INSERTED.
* typos fixedJoel Sherrill1995-10-3125-73/+481
* SPARC port passes all testsJoel Sherrill1995-10-30112-1370/+4366
* reordered test cases from simple to complexJoel Sherrill1995-10-112-26/+50
* fixed null pointer dereferenceJoel Sherrill1995-10-062-4/+4
* fixed missing CVS IDsJoel Sherrill1995-10-06136-24/+215
* SPARC merged and successfully tested w/o interrupt supportJoel Sherrill1995-10-0623-4/+2295
* moved to new development machine and went to gcc 2.7.0Joel Sherrill1995-10-0617-6/+38
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-2970-318/+629
* new programs addedJoel Sherrill1995-09-276-2/+552
* updatedJoel Sherrill1995-09-271-13/+8
* Modified UNIX simulator port so all references to native unixJoel Sherrill1995-09-2736-342/+966
| | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files.
* Fixed typoJoel Sherrill1995-09-273-6/+6
* posix support initially addedJoel Sherrill1995-09-26488-1203/+21585
* fixed Id stringsJoel Sherrill1995-09-266-3/+12
* new fileJoel Sherrill1995-09-261-0/+436
* Removed unnecessary include files.Joel Sherrill1995-09-222-2/+2
* Removed unneeded referenced to rtems/fatal.hJoel Sherrill1995-09-2211-11/+0
* moving files around and adding the exec/wrapup directoryJoel Sherrill1995-09-228-16/+22
* More file movement required api extension to be added to scoreJoel Sherrill1995-09-219-10/+442
* More file movementJoel Sherrill1995-09-218-8/+8
* More file movementJoel Sherrill1995-09-2110-12/+6
* More file movementJoel Sherrill1995-09-219-17/+12
* Fixed problem in fast_idle_switch_hookJoel Sherrill1995-09-211-1/+1
* moving files aroundJoel Sherrill1995-09-2122-38/+28
* Changed version numberJoel Sherrill1995-09-202-2/+2
* Actually adding efi bsp's from John Gwynne after forgetting toJoel Sherrill1995-09-2028-0/+4376
| | | | commit them.
* Heap changes required some changes in this screen.Joel Sherrill1995-09-192-14/+34
* Modifications from Tony Bennett accepted to tune this test a little.Joel Sherrill1995-09-198-22/+44
* Modifications from Tony Bennett accepted to return aligned block.Joel Sherrill1995-09-194-24/+80
| | | | | Thread_Close fixed to avoid returning FP context area when one was not allocated at initialization time.
* Modifications from Tony Bennett accepted to return aligned block.Joel Sherrill1995-09-199-0/+114
* Removed a section of code which was "#if 0"'ed.Joel Sherrill1995-09-191-16/+0
* Incorporated the submission from John S. GwynneJoel Sherrill1995-09-1914-94/+1754
| | | | | | <jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support for interrupt handling and bfffo support, the two BSPs he submitted (efi68k and efi332), and SGI Irix 5.3 host support.
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-19228-2348/+4843
* Initial attempt at building HP PA-RISC using Solaris hosted tools.Joel Sherrill1995-09-1212-28/+313
| | | | Changed back to Newlib for Solaris UNIX simulator.
* Added...Joel Sherrill1995-09-112-0/+90
* Added... This is the Configuration Tables Template file.Joel Sherrill1995-09-113-0/+846
* AddedJoel Sherrill1995-09-113-0/+621
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-11883-11327/+20872
* new file -- split from inlinesJoel Sherrill1995-08-292-0/+404
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-28159-804/+2388
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-2373-248/+513
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-23414-1118/+3776
* Added file .. fixed RCS IdJoel Sherrill1995-08-221-0/+285
* fixed RCS IdJoel Sherrill1995-08-221-0/+249
* Fixed missing RCS IdsJoel Sherrill1995-08-228-7/+58
* Merged PowerPC port as submitted by Andy Bray of I-CUBED, LtdJoel Sherrill1995-08-2231-21/+2831
| | | | | | | | | | (andy@i-cubed.demon.co.uk). This initial submission is known to work on the IBM 403. It is thought to work on the Motorola 601, 603, and 604 although this remains to be tested. Another user -- Doug Currie (e@flavors.com) -- is interested in this work and will be testing it on the 604 using the Metrowerks C compiler and a different format assembly language.
* fix broken RCS Ids -- $ accidentally lost merging changes earlierJoel Sherrill1995-08-2234-34/+34
