* support/new_exception_processing/configure.ac,
support/new_exception_processing/rtems/score/c_isr.inl,
support/new_exception_processing/rtems/score/cpu.h,
support/old_exception_processing/configure.ac,
support/old_exception_processing/rtems/score/c_isr.inl,
support/old_exception_processing/rtems/score/cpu.h,
support/old_exception_processing/rtems/score/ppc_offs.h: New files
missed in previous commit.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/dmv177.cfg;
Rename PPC_USE_INSTRUCTION_CACHE to DMV177_USE_INSTRUCTION_CACHE,
Add RTEMS_PPC_EXCEPTIONS([old]).
* include/Makefile.am: include force-preinstall.am.
* startup/bspstart.c: Rename PPC_USE_INSTRUCTION_CACHE to
DMV177_USE_INSTRUCTION_CACHE.
* wrapup/Makefile.am: Apply @exceptions@.
* configure.ac: Add RTEMS_BSPOPTS_*(), merge-in settings
from make/custom/mbx*.cfg, add RTEMS_PPC_EXCEPTIONS([new]).
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* vectors/Makefile.am: remove bogus VPATH.
* custom/eth_comm.cfg: Reflect changes to eth_comm/configure.ac.
* custom/mbx8xx.cfg: Reflect changes to mbx8xx/configure.ac.
* custom/mbx860_005b.cfg: Ditto.
* custom/mpc8620ads.cfg: Reflect changes to mpc8620/configure.ac.
* configure.ac: Remove mpc8620 from new_exception_processing.
make/custom/mpc8260ads.cfg, add RTEMS_PPC_EXCEPTIONS([new]).
* configure.ac: Add RTEMS_BSPOPTS_*(UARTS_IO_MODE),
* irq/Makefile.am: remove irq.h from EXTRA_DIST.
* automake/force-preinstall.am: New file.
* aclocal/ppc.m4: New file.
* support/new_exception_processing/Makefile.am,
support/old_exception_processing/Makefile.am,
support/old_exception_processing/cpu_asm.S,
support/old_exception_processing/irq_stub.S: Modified to reflect
old versus new exception processing being a per BSP option.
* support/new_exception_processing/c_isr.inl,
support/new_exception_processing/cpu.h,
support/old_exception_processing/c_isr.inl,
support/old_exception_processing/cpu.h,
support/old_exception_processing/ppc_offs.h: Removed.
* ChangeLog: Corrected spacing.
* console/console-io.c: Fix incorrect comment.
* src/threadhandler.c: When __USE__MAIN__ is defined by the toolset,
invoke the global constructors via __main. Reported as tested by
Alexandra Kossovsky <sasha@oktet.ru> and Victor V. Vengerov
<vvv@oktet.ru> in conjunction with a new set of tool RPMs
(gcc2.95.3newlib1.9.0-3). This was tracked as GNATS PR tools/84.
* custom/gensh1.cfg: remove make-target-options.
* custom/gensh2.cfg: remove make-target-options.
* configure.ac: Add RTEMS_BSPOPTS_*(CPU_CLOCK_RATE_HZ),
RTEMS_BSPOPTS_*(START_HW_INIT),
RTEMS_BSPOPTS_*(STANDALONE_EVB).
* wrapup/Makefile.am: Apply RTEMS_CPU_MODEL to pickup CPU_PIECES.
* configure.ac: Apply RTEMS_BSPOPTS_*(CPU_CLOCK_RATE_HZ).
* configure.ac: Add RTEMS_BSPOPTS_*(USE_CONSOLE_A),
add RTEMS_BSPOPTS_*(USE_CONSOLE_B).
* custom/dmv152: Remove USE_CONSOLE_A, Remove USE_CONSOLE_B,
remove make-target-options, remove BSP_CPPFLAGS.
* configure.ac: Add RTEMS_BSPOPTS_*(SIMHPPA_FAST_IDLE),
remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* custom/simhppa.cfg: Remove SIMHPPA_FAST_IDLE, make-target-options.
* configure.ac: Fix typo to allow custom RPM_SPECSdirs.
* aclocal/check-bsps.m4: Reworked.
* aclocal/bsp-alias.m4: Add score603e_g1, apply m4sugar.
* startup/linkcmds: Fixed syntax error in my previous addition
of __init.
* shared/ppc.h: The mpc8260 uses the new exception processing model
and thus does not need to define PPC_USE_SPRG.
* custom/eth_comm.cfg, custom/mbx860_005b.cfg, custom/mbx8xx.cfg,
custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mvme2307.cfg:
These are new exception processing model BSPs and thus do not
* shared/ppc.h: mpc8260 has double FPU not single FPU.
* new_exception_processing/cpu_asm.S: Support double or single
precision context switches. Note that doing a single precision
context save/restore on a double precision PowerPC machine does not
only result in rounding errors but also screws up the FPSCR register!
* ChangeLog: Added missing lines about simcpu32.cfg and sim68000.cfg.
* custom/ts_386ex.cfg: Remove make-target-options.
* configure.ac: Add RTEMS_BSPOPTS_*(LOAD_RTC_AT_START),
RTEMS_BSPOPTS_*(BSP_DEBUG), RTEMS_BSPOPTS_*(UARTDEBUG),
* aclocal/bspopts.m4: New file.
* configure.ac: Add bspopts.h.
* include/.cvsignore: Add stamp-h* and bspopts.h*.
* include/Makefile.am: Add bspopts.h.
* pci/Makefile.am: Append -O2 to AM_CFLAGS.
* custom/shsim.cfg: Remove HZ, BSP_CPPFLAGS, make-target-options.
* custom/mvme2307.cfg: Fix PPC_USE_SPRG in make-target-options,
re-adopt mcp750.cfg's make-exe.
* include/Makefile.am: Fix TMPINSTALL_FILES to make automake-1.5
happy.
* include/iosh7045.h: Add SCI0_SMR, SCI1_SMR for sh7032
compatibility to make simsh happy.
* bootloader/Makefile.am: completely reworked.
* configure.ac: Add AM_PROG_AS.
* COPYING: Test of $Id$ -> $RTEMS$.
* custom/helas403.cfg, custom/gen405.cfg: Removed dependency on
the --srec-len argument to objcopy only supported in binutils 2.11
or newer.
* Makefile.am: Made to compile again.
* startup/linkcmds: Added _init, and _fini symbols.
* .cvsignore: New file.
process was captured as PR50.
* custom/gen405.cfg: New file.
* custom/helas403.cfg: Modified to generate Srecords.
* ppc403/console/console405.c ppc403/tty_drv/.cvsignore,
ppc403/tty_drv/Makefile.am, ppc403/tty_drv/tty_drv.c,
ppc403/tty_drv/tty_drv.h: New files.
* Makefile.am, README, configure.ac, old_exception_processing/cpu.c,
old_exception_processing/cpu.h, ppc403/Makefile.am,
ppc403/clock/clock.c, ppc403/console/Makefile.am,
ppc403/console/console.c, ppc403/ictrl/ictrl.c, ppc403/ictrl/ictrl.h,
ppc403/timer/timer.c: Modified.
* vectors/align_h.S: Added ppc405 support.
* startup/spurious.c: Added ppc405 support.
* include/bsp.h: Increase the interrupt stack size to 16K.
* ChangeLog, Makefile.am, README, bsp_specs, bsp_specs.dl, configure.ac,
times, dlentry/.cvsignore, dlentry/Makefile.am, dlentry/dlentry.S,
include/bspopts.h.in, include/coverhd.h, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/linkcmds.dl, startup/setvec.c,
wrapup/.cvsignore, wrapup/Makefile.am: New files that are
part of the new gen405 BSP.
This modification is a submission of the modifications necessary to
* acinclude.m4: Added gen405 BSP.
* ChangeLog: Removed bogus comment on edit of generated file.
* aclocal.m4: Added gen405 BSP.
* shared/asm.h, shared/ppc.h: Added PPC405 support.
