* Incorporated Ralf Corsepius' idea for new -q flags to properly supportJoel Sherrill1998-02-1123-40/+157
| | | | "gmake debug".
* Don't install tools using variant name.Joel Sherrill1998-02-111-1/+1
* Install size info using "standard" suffix.Joel Sherrill1998-02-111-8/+1
* Fixed hppa1.1 configuration.Joel Sherrill1998-02-112-6/+6
* new test casesJoel Sherrill1998-02-112-0/+92
* new directory structure for hwapiJoel Sherrill1998-02-112-2/+2
* hwapi addedJoel Sherrill1998-02-111-1/+2
* updatesJoel Sherrill1998-02-1117-655/+540
* Robin Kirkham reported that the install point was incorrect in this file.Joel Sherrill1998-02-101-1/+1
* Fixed to correctly operate on target variants like debug and profile.Joel Sherrill1998-02-073-21/+56
* Should not install build-tools using target variant options.Joel Sherrill1998-02-072-2/+2
* Updated copyrightsJoel Sherrill1998-02-06191-198/+192
* Added @table/@end table capability along with the avdas.d test case whereJoel Sherrill1998-02-063-3/+363
| | | | this capability was first used.
* Problem report from Brian Cuthie regarding incorrect calculationJoel Sherrill1998-02-061-1/+2
| | | | | | | | | of BSS size. The conversion from a count of u8's to a count of u32's was shifting in the wrong direction. This error had been in the start code a long time. It had not caused problems because the BSS is typically much smaller than the C heap which typically follows it in memory. Plus since this code was executed at start time, all that really happened was an extra zeroing of some memory.
* Added code to more correctly process abstract types (handle, range, etc).Joel Sherrill1998-02-052-22/+76
* Removed special ix86-rtems stanza.Joel Sherrill1998-02-041-32/+29
* Change suggested by Ralf Corsepius:Joel Sherrill1998-02-042-43/+276
| | | | | | | | | | | | | | | | | | | | | | | | | | I am not sure if this is related to this problem, but here is an observation: All config.sub scripts from rtems' intrastructure packages internally transform i386-rtems into i386-pc-rtems newlib-1.8.0-rtems/config.sub i386-rtems --> i386-pc-rtems egcs-1.0/config.sub i386-rtems ---> i386-pc-rtems egcs-1.0.1/config.sub i386-rtems ---> i386-pc-rtems bintutils-2.8.1.0.19/config.sub i386-rtems ---> i386-pc-rtems gas-98xxxx/config.sub i386-rtems ---> i386-pc-rtems The only exception is rtems itself: rtems/config.sub i386-rtems ---> i386-rtems I am not sure if this influences i386-rtems + c++/posix, but this indicates that rtems' config.sub script should to be updated. To fix this, simply copying config.sub e.g. from egcs and removing all i[3456]-rtems* case statement lines from configure.in should be sufficient. BTW, from autoconf's point of view i386-pc-rtems is the correct target conforming autoconf's naming conventions, but using i386-rtems for all packages (infrastructure and rtems) should make no difference.
* Cleaned up the definition of CONSOLE_USE_POLLED and CONSOLE_USE_INTERRUPTS.Joel Sherrill1998-02-041-9/+9
* Patch from Ralf Corsepius to reduce the amount of memory consumed byJoel Sherrill1998-02-043-6/+18
| | | | the workspace by default.
* New autoconf feature from Ralf Corsepius:Joel Sherrill1998-02-045-0/+108
| | | | | | | | | | | | | | | | | | | | It adds make rules for reconfiguring build-trees ("make Makefile") and adds dependency rules for configure and friends (i.e. calls autoconf). Most of this code has been "borrowed" from automake and was adapted to rtems. Addionally, I added automatic generation of the "aclocal.m4"-file by "aclocal" (from the automake package). Therefore I splitted aclocal.m4 into several separate files (attached to this mail), each containing one of rtems customized autoconf/m4-macros and have put them into a new subdirectory "aclocal". Normal users won't be influenced and won't even need this, unless they try to modify configure.in. The main advantage of this is: these aclocal/m4-macros become reusable and easier to administer. As a disadvantage, rtems becomes dependent of having aclocal/automake installed. To keep building rtems functional if autoconf or aclocal isn't installed, the related Makefile commands are prefixed by "-" -- only an error message should be issued by "make".
* Ralf Corsepius noticed that generally was spelled incorrectly.Joel Sherrill1998-02-0412-12/+12
* Added call to libc_wrapup() in _exit. This fixes a problem whereJoel Sherrill1998-02-033-0/+3
| | | | | the atexit routines on the global reentrancy structure were not invoked. But it does not seem like a 100% correct solution.
* Corrected spelling error so interrupt driven console would work.Joel Sherrill1998-02-031-2/+2
* Fixed so installed Makefile structure work.Joel Sherrill1998-02-021-3/+4
* Big patch form Ralf Corsepius described in this email:Joel Sherrill1998-01-30480-1924/+974
* Corrected Linux port for glibc2Joel Sherrill1998-01-3010-7/+16
* correctionJoel Sherrill1998-01-301-1/+2
* configure.inJoel Sherrill1998-01-301-16/+111
* Modified output of @Example style in MsWord output routine so it wouldJoel Sherrill1998-01-302-4/+36
| | | | be one paragraph with manual line breaks rather than multiple paragraphs..
* Change to remove warning on glibc2 systems per Ralf Corsepius'sJoel Sherrill1998-01-282-2/+12
| | | | suggestion.
* Fix from Eric Norum:Joel Sherrill1998-01-271-1/+1
| | | | | There's an explicit invocation of `make' in c/Makefile.in. This breaks for those of us with different `gmake' and `make' programs.
* Removed some stanzas per Ralf Corsepius:Joel Sherrill1998-01-271-18/+2
| | | | | | | > 4) The toplevel Makefile.in contains rules named make_subdir and > clean_modules, which probably can be deleted, IMO. > At least make_subdir doesn't give any sense anymore. (I had removed it > im my original patch).
* not submittedJoel Sherrill1998-01-271-106/+0
* Fixed missing carriage return at the bottom of the file reportedJoel Sherrill1998-01-271-1/+0
| | | | by Ralf Corsepius
* new fileJoel Sherrill1998-01-262-0/+18
* Solaris port updates from Chris JohnsJoel Sherrill1998-01-2341-83/+118
* Cleaned up a bit.Joel Sherrill1998-01-232-18/+62
* Added information about multilib problems.Joel Sherrill1998-01-231-0/+8
* minor updates .. mostly versionJoel Sherrill1998-01-2320-106/+110
* Fixed some "NodeNameIncludesChapterName" problems which were uncoveredJoel Sherrill1998-01-231-11/+29
| | | | doing the HWAPI manual.
* Reverted change ...Joel Sherrill1998-01-222-4/+4
* Added some GRUB information from Phil Wilshire.Joel Sherrill1998-01-221-0/+12
* Corrected/simplified setting of RTEMS_ROOT.Joel Sherrill1998-01-222-4/+4
* Added autoconf support for strerror/sys_errlist per Ralf Corsepius'Joel Sherrill1998-01-2120-143/+418
| | | | | direction. This fixes a problem reported by Steve Evans of Radstone since he is using glibc2.
* Changed reference from PROJECT_ROOT to RTEMS_ROOT.Joel Sherrill1998-01-211-1/+1
* Corrected prototypes for main per Ralf Corsepius' report of warningsJoel Sherrill1998-01-2112-20/+48
| | | | generated when egcs is used with "-Wall -pedantic".
* Added Code to dop the output in a format which a custom Visual BasicJoel Sherrill1998-01-213-10/+203
| | | | Application Cindy has written can transform into a nice Word document.
* Removed warning per Chris Johns' suggestion.Joel Sherrill1998-01-206-6/+6
* Removed warning per Chris John's suggestion.Joel Sherrill1998-01-201-1/+1
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-20459-511/+492
