* | Removed "NO CTOR" from list of objects to be picked up. It now comes in | Joel Sherrill | 1999-06-02 | 2 | -4/+2 |
| | | | | via libbsp.a. Reported by Ian Lance Taylor <ian@airs.com>. | ||||
* | changed version to 19990528 | Joel Sherrill | 1999-05-28 | 0 | -0/+0 |
* | Changes from Eric Norum to add a loop and limit on the length of time | Joel Sherrill | 1999-05-28 | 4 | -88/+128 |
| | | | | the stack will wait for mbufs. | ||||
* | changed version to 19990528 | Joel Sherrill | 1999-05-28 | 2 | -2/+2 |
* | Don't install this executable. It should only be built. | Joel Sherrill | 1999-05-28 | 1 | -2/+1 |
* | Use fgrep instead of grep to avoid treating filenames as regular expressions. | Joel Sherrill | 1999-05-28 | 2 | -2/+2 |
| | | | | | grep found debugio.o when looking for debug.o and said there was a filename conflict incorrectly. | ||||
* | Alignment corrected per Eric Norum's suggestion. | Joel Sherrill | 1999-05-28 | 4 | -4/+8 |
* | Corrected to include shared console driver. | Joel Sherrill | 1999-05-28 | 1 | -1/+1 |
* | At the request of Gumby, the cpu is now halted rather than spinning | Joel Sherrill | 1999-05-28 | 2 | -2/+2 |
| | | | | on a fatal exception. | ||||
* | Regenerated. | Joel Sherrill | 1999-05-28 | 0 | -0/+0 |
* | Renamed config.c to conscfg.c to avoid naming conflicts. | Joel Sherrill | 1999-05-28 | 2 | -284/+1 |
* | Renamed config.s to todcfg.c to avoid naming conflicts. | Joel Sherrill | 1999-05-28 | 2 | -80/+1 |
* | Renamed fatal.c to bspfatal.c to avoid name conflicts with | Joel Sherrill | 1999-05-28 | 2 | -128/+1 |
| | | | | Fatal Error handler in SuperCore. | ||||
* | Renamed tod.c to coretod.c to remove conflicts with "Time Of Day" | Joel Sherrill | 1999-05-28 | 2 | -240/+2 |
| | | | | device drivers. | ||||
* | Renamed clock.c to rtclock.c to avoid conflicts with clock drivers | Joel Sherrill | 1999-05-28 | 2 | -24/+1 |
| | | | | in various BSPs. | ||||
* | Switched from picking up the .rel for each subdirectory in the | Joel Sherrill | 1999-05-27 | 33 | -33/+33 |
| | | | | | BSP (BSP_PIECES) to picking up the .o files. This should help reduce the minimum size of an application. | ||||
* | Patch from Eric Norum <eric@pollux.usask.ca> to eliminate a panic when the | Joel Sherrill | 1999-05-27 | 12 | -588/+352 |
| | | | | network stack runs out of mbufs. | ||||
* | Split out the routine rtems_assoc_name_bad(). | Joel Sherrill | 1999-05-27 | 12 | -72/+207 |
* | Removed usage of printf. | Joel Sherrill | 1999-05-27 | 7 | -7/+7 |
* | Split initialization and reserve resources from termios to reduce | Joel Sherrill | 1999-05-27 | 10 | -178/+281 |
| | | | | size of mininum application. | ||||
* | Split out polled io, debug puts, and console reserve resources to | Joel Sherrill | 1999-05-27 | 4 | -83/+146 |
| | | | | reduce dependencies and shrink minimum executable size. | ||||
* | Disabled running size_rtems until all file splitting is finished. | Joel Sherrill | 1999-05-27 | 1 | -1/+1 |
* | Regenerated. | Joel Sherrill | 1999-05-27 | 15 | -1161/+2098 |
* | Corrected so rtems.o is built and installed on all targets. | Joel Sherrill | 1999-05-27 | 10 | -31/+20 |
* | Corrected macro names. | Joel Sherrill | 1999-05-27 | 2 | -4/+12 |
* | New file. | Joel Sherrill | 1999-05-26 | 1 | -0/+4 |
* | Made the gen_section more accurate. | Joel Sherrill | 1999-05-26 | 13 | -253/+257 |
* | Prototypes are now based on how the TRON specification states them. | Joel Sherrill | 1999-05-26 | 11 | -83/+166 |
| | | | | The style in the output is not right but it is a good starting point. | ||||
* | Basic prototypes are now included. | Joel Sherrill | 1999-05-26 | 1 | -1/+6 |
* | Regenerated to include more information in the stub. Now they have | Joel Sherrill | 1999-05-26 | 12 | -180/+184 |
| | | | | the descriptive titles. | ||||
* | Changed word "directive" to "system call." | Joel Sherrill | 1999-05-26 | 1 | -1/+1 |
* | Added error codes to all service calls | Joel Sherrill | 1999-05-26 | 1 | -14/+190 |
* | Corrected error code section. | Joel Sherrill | 1999-05-26 | 12 | -168/+0 |
* | Replaced error code section. | Joel Sherrill | 1999-05-26 | 12 | -252/+84 |
* | Enhanced. | Joel Sherrill | 1999-05-26 | 1 | -63/+156 |
* | Initiated updating this to reflect split up. | Joel Sherrill | 1999-05-26 | 2 | -4/+8 |
* | Initial revision | Joel Sherrill | 1999-05-20 | 16 | -0/+4561 |
* | Renamed to rtemstimer.c to avoid conflict with timer drivers in EVERY | Joel Sherrill | 1999-05-20 | 2 | -53/+2 |
| | | | | BSP as we transition to more .o's and less .rel's. | ||||
* | Removed all post 4.0 changes. | Joel Sherrill | 1999-05-20 | 4 | -324/+312 |
* | Patch from Daniel Kelley <dank@icube.com>: | Joel Sherrill | 1999-05-18 | 4 | -16/+16 |
| | | | | | | I found a small buglet in the mips64orion _CPU_ISR_Set_level; the original was wiping out the level argument, and then comparing the current interrupt level with some random value of v0. See patch below. | ||||
* | Regenerated. | Joel Sherrill | 1999-05-18 | 17 | -2100/+1163 |
* | Spacing correction. | Joel Sherrill | 1999-05-18 | 1 | -1/+0 |
* | Reworked to avoid pulling in the jump point entry in EVERY executable. | Joel Sherrill | 1999-05-17 | 11 | -19/+50 |
* | Fixed some typos. | Joel Sherrill | 1999-05-17 | 2 | -8/+8 |
* | Split Interrupt Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 5 | -77/+118 |
