* configure.ac: Pass --enable-rtems-root to ada-tests/configure.
* configure.ac: Reflect changes to testsuites/automake,
testsuites/aclocal.
* rtems/score/cpu.h: Eliminate use of unsigned32.
* rtems.adb, rtems.ads: Remove initialization directives as
rtems_initialize_executive is obsolete and the other initialization
services should not be called from Ada anyway.
* libnetworking/rtems/rtems_mii_ioctl.h: Reflect mii.h and
if_media.h having moved.
* libchip/network/if_media.h, libchip/network/mii.h:
Remove (Moved to cpukit).
* libchip/Makefile.am: Reflect having moved libchip/network/mii.h
and libchip/network/if_media.h.
* libchip/network/elnk.c, libchip/network/if_dc.c: Reflect mii.h and
* libnetworking/net/if_media.h, libnetworking/dev/mii/mii.h:
New (Moved from c/src/libchip).
* libnetworking/Makefile.am: Re-add rtems/rtems_mii_ioctl.h,
rtems/rtems_mii_ioctl.c, rtems/rtems_mii_ioctl_kern.c.
Add dev/mii/mii.h, net/if_media.h (Moved from c/src/libchip).
* Makefile.am: Remove depend-am.
* automake/compile.am, automake/host.am, automake/local.am,
automake/subdirs.am: Remove depend.
* automake/local.am: Remove depend.
* automake/host.am: Remove depend.
* automake/subdirs.am: Remove preinstall, preinstall-recursive.
* automake/local.am: Remove preinstall-am.
* configure.ac: Explicitly pass --libdir and --includedir to
testsuites.
* aclocal/env-rtemsbsp.m4: Remove includedir. Remove libdir.
Set rtems_testsdir to $libdir/rtems-4.7/tests.
* configure.ac: Remove AMPOLISH3 (Unused).
* aclocal/env-rtemsbsp.m4: Remove RTEMS_CPU_MODEL.
* automake/compile.am: Remove LINK_OBJS. Remove LINK_FILES.
Remove ARCH. Remove LINK_LIBS.
Extend clean-local to catch most temporary files make-exe is
creating.
* tm01/Makefile.am, tm02/Makefile.am,
tm03/Makefile.am, tm04/Makefile.am,
tm05/Makefile.am, tm06/Makefile.am,
tm07/Makefile.am, tm08/Makefile.am,
tm09/Makefile.am, tm10/Makefile.am,
tm11/Makefile.am, tm12/Makefile.am,
tm13/Makefile.am, tm14/Makefile.am,
tm15/Makefile.am, tm16/Makefile.am,
tm17/Makefile.am, tm18/Makefile.am,
tm19/Makefile.am, tm20/Makefile.am,
tm21/Makefile.am, tm22/Makefile.am,
tm23/Makefile.am, tm24/Makefile.am,
tm25/Makefile.am, tm26/Makefile.am,
tm27/Makefile.am, tm28/Makefile.am,
tm29/Makefile.am, tmck/Makefile.am,
tmoverhd/Makefile.am: Convert to using *_PROGRAMS.
* tmitronsem01/Makefile.am: Convert to using *_PROGRAMS.
psx13/Makefile.am, psxcancel/Makefile.am, psxchroot01/Makefile.am,
psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am,
psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am,
psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am:
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am:
* itronhello/Makefile.am, itronmbf01/Makefile.am,
itronmbox01/Makefile.am, itronsem01/Makefile.am,
itrontask01/Makefile.am, itrontask02/Makefile.am,
itrontask03/Makefile.am, itrontask04/Makefile.am,
itrontime01/Makefile.am:
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am,
hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, pppd/Makefile.am,
ticker/Makefile.am, unlimited/Makefile.am:
* cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am,
stackchk/Makefile.am, termios/Makefile.am:
sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am,
spfatal/Makefile.am, spsize/Makefile.am:
Convert to use *_PROGRAMS.
* aclocal/env-rtemsbsp.m4: Remove project_libdir.
Remove project_includedir.
Add rtems_testsdir.
* aclocal/rtems-top.m4: Remove dirstamp.
* bsp_specs: Remove %cpp.
