* | Added multigen generated bare BSP configuration files. | Joel Sherrill | 2000-06-15 | 1 | -0/+1 |
* | Patch rtems-rc-20000615-3-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-15 | 3 | -7/+9 |
| | | | | | <corsepiu@faw.uni-ulm.de> so these BSPs pick up the components they need from libcpu. | ||||
* | Patch rtems-rc-20000615-2-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-15 | 1 | -0/+6 |
| | | | | <corsepiu@faw.uni-ulm.de> to update multigen. | ||||
* | Patch rtems-rc-20000615-1-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-15 | 1 | -1/+1 |
| | | | | <corsepiu@faw.uni-ulm.de> to fix a bad file reference. | ||||
* | Moved <sys/cdefs.h> to lib/include so non-networking applications could | Joel Sherrill | 2000-06-15 | 3 | -3/+3 |
| | | | | include <sys/ioctl.h>. | ||||
* | Moved <sys/cdefs.h> to lib/include/sys from libnetworking/sys so | Joel Sherrill | 2000-06-15 | 1 | -2/+2 |
| | | | | non-networking applications could include <sys/ioctl.h>. | ||||
* | New file from Ralf. | Joel Sherrill | 2000-06-14 | 1 | -0/+165 |
* | Enable data cache as well. | Joel Sherrill | 2000-06-14 | 3 | -0/+3 |
* | Use John Cotton's more permanent email address. | Joel Sherrill | 2000-06-14 | 1 | -1/+1 |
* | Moved <sys/cdefs.h> from libnetworking to lib/include so non-networking | Joel Sherrill | 2000-06-14 | 3 | -0/+354 |
| | | | | | configurations could see it while including <sys/ioctl.h> and <sys/ioccom.h>. | ||||
* | Added Cache Manager and MBX8xx credits. | Joel Sherrill | 2000-06-14 | 1 | -0/+14 |
* | Patch from John Cotton <john.cotton@nrc.ca> to correct cache | Joel Sherrill | 2000-06-14 | 18 | -187/+177 |
| | | | | | | routine naming to follow RTEMS package/object.method rule. This patch also eliminated calls to the obsolete routine m68k_enable_caching. | ||||
* | *** empty log message *** | Joel Sherrill | 2000-06-14 | 43 | -98/+338 |
* | Added include of options.h since it was not being picked up | Joel Sherrill | 2000-06-14 | 2 | -0/+2 |
| | | | | by the network build. | ||||
* | Added .cvsignore files. | Joel Sherrill | 2000-06-14 | 4 | -0/+26 |
* | Conditionally do not assemble 403 code. | Joel Sherrill | 2000-06-14 | 1 | -0/+8 |
* | Patch from Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add missing | Joel Sherrill | 2000-06-14 | 1 | -2/+2 |
| | | | | file to Makefile.am. | ||||
* | Patch rtems-4.5-beta3-mon.diff from Chris Johns <cjohns@cybertec.com.au> | Joel Sherrill | 2000-06-14 | 6 | -348/+1522 |
| | | | | | | | | | | | | | | | to: I have also added the ability to register and unregister commands. This allows me to create a set of monitor commands for the network stack plus basic memory dump/patch commands (needs a working probe interface). I will also look at a basic ls/cd/rm/mv/cp command set at some stage. I have been thinking about changing the monitor in the future to more like a light weight RTEMS shell, `eshell' for embedded shell. This is a story for another day but is a process or getting the commands to map to the filesystem (eg, major=commands, minor=command) and supporting an environment. The filesystem provide a structure for the commands. | ||||
* | Patch from Chris Johns <cjohns@cybertec.com.au> to enhance network | Joel Sherrill | 2000-06-14 | 6 | -129/+648 |
| | | | | | | | | | | | | | initialization. This adds an interface which makes it easier to control the BSD stack from user code. The BSD stack initialise uses it. It is a sort of `function' interface for an ifconfig command. I also added support for attaching and removing interfaces. With hot swap PCI comming online support for hot swap PCI will be an important factor in "state of art" RTOS's. This is also part of a general move on my part to allow RTEMS to be configured at runtime by calls rather than table driven at initialisation. | ||||
* | Patch rtems-rc-20000614-2-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-14 | 1 | -3/+7 |
| | | | | | | | | | | <corsepiu@faw.uni-ulm.de> to evaluate ACLOCAL_AMFLAGS in Makefile.ams before running aclocal. Remark: This patch is in preparation to switching to Cygnus/GNU canonicalization. I plan to introduce to an alternate aclocal macros directory which shall contain Cygnus/GNU conforming macros only, soon. | ||||
* | Patch rtems-rc-20000614-1-cvs.diff from Ralf Corsepius | Joel Sherrill | 2000-06-14 | 3 | -10/+16 |
| | | | | | | | | | <corsepiu@faw.uni-ulm.de> that addresses a couple of minor configuration issues which popped up when experimenting with multilibs. Note: The multigen generated make/custom/bare-*.cfg will still be non-functional, even after having applied this patch. | ||||
* | Patch rtems-rc-20000614-sh.tar.gz from Ralf Corsepius | Joel Sherrill | 2000-06-14 | 37 | -1903/+210 |
| | | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de> that migrates the SH port to multilib'ing. This patch involved moving a number of files in the CVS repository, adding new files, and deleting files from their previous location. Ralf gave good instructions (not repeated here) and here are his notes: Note 1: In this version, I did not change the installation points of the headers which are moved inside of the source-tree. This is a temporary hack for not breaking compatibility with 4.5 based BSPs, but will probably not last once having real multilibs (We would have include file conflicts when several BSPs/CPU_MODELS share a common installation prefix). Note 2: I hope not to have broken too much, but I would not be astonished if something goes wrong. Note 3: There are more patches to come :) | ||||
* | Moved PowerPC cache management code to libcpu. Also compiled | Joel Sherrill | 2000-06-14 | 12 | -510/+55 |
| | | | | | | mpc8xx libcpu support for the first time and remove includes of bsp.h, references to BSP_Configuration, and Cpu_table. All of these can be obtained directly from RTEMS now. | ||||
* | Must now pull in cache management code from libcpu. | Joel Sherrill | 2000-06-14 | 4 | -2/+6 |
* | Removed alloc860.c and mmu.c from C_FILES since they are now in libcpu. | Joel Sherrill | 2000-06-14 | 1 | -2/+2 |
* | Do not build if networking disabled. | Joel Sherrill | 2000-06-14 | 1 | -0/+2 |
* | Removed building of libcpu.a. It is now the individual BSPs | Joel Sherrill | 2000-06-14 | 4 | -8/+14 |
| | | | | | responsibility to explicitly pick up the components they require. This makes it easier to override default implmentations. | ||||
* | Changed to standard make-exe type rule. | Joel Sherrill | 2000-06-14 | 1 | -1/+1 |
* | Moved PPC_VECTOR_FILE_BASE to targopts.h | Joel Sherrill | 2000-06-14 | 1 | -1/+1 |
* | Thread iterate not ready for submission -- removed. | Joel Sherrill | 2000-06-14 | 2 | -2/+2 |
* | Moved to include subdirectory. | Joel Sherrill | 2000-06-14 | 1 | -99/+0 |
* | New files containing cache manager functionality stripped from | Joel Sherrill | 2000-06-14 | 3 | -0/+220 |
| | | | | score/cpu/powerpc. | ||||
* | New file. | Joel Sherrill | 2000-06-14 | 2 | -0/+4 |
* | Functionality moved from directory above to accomodate building | Joel Sherrill | 2000-06-14 | 9 | -0/+1255 |
| | | | | shared source code. | ||||
* | Moved from score/cpu/PowerPC. | Joel Sherrill | 2000-06-14 | 8 | -1150/+4 |
* | Patch rtemsdoc-4.5.0-rc-13-cvs.diff.gz from Ralf Corsepius | Joel Sherrill | 2000-06-14 | 30 | -34/+38 |
| | | | | | | | | <corsepiu@faw.uni-ulm.de> which: * should fix the building rtemsdoc outside of the sourcetree with relative srcdir issue * adds --enable-papersize=[letter|a4|] | ||||
* | Thread iterator and libgjc support submitted too early. | Joel Sherrill | 2000-06-14 | 28 | -2086/+19 |
* | Fix typo. | Joel Sherrill | 2000-06-14 | 1 | -1/+1 |
* | Added crude i960ka support. | Joel Sherrill | 2000-06-13 | 6 | -12/+76 |
* | Pickup console-polled.c from the libbsp/shared directory. | Joel Sherrill | 2000-06-13 | 1 | -0/+2 |
* | Removing clock and timer since this BSP does not currently | Joel Sherrill | 2000-06-13 | 1 | -2/+0 |
| | | | | have them. | ||||
* | Prototypes for cache manager support functions now agree. | Joel Sherrill | 2000-06-13 | 2 | -7/+3 |
* | New file. | Joel Sherrill | 2000-06-13 | 2 | -0/+274 |
* | Moved i386 and m68k cache management code to libcpu. Everything | Joel Sherrill | 2000-06-13 | 31 | -1048/+607 |
| | | | | | | now is an implementation of the prototypes in rtems/rtems/cache.h. The libcpu/i386/wrapup directory is no longer needed. The PowerPC needs this done to it. | ||||
* | Added .cvsignore. | Joel Sherrill | 2000-06-13 | 6 | -0/+12 |
* | Added .cvsignore. | Joel Sherrill | 2000-06-13 | 11 | -0/+33 |
* | Added .cvsignore files. | Joel Sherrill | 2000-06-13 | 2 | -0/+15 |
* | Accounted for 1 task used. | Joel Sherrill | 2000-06-13 | 1 | -0/+1 |
* | Removed unused directories from Makefile.am and warnings | Joel Sherrill | 2000-06-13 | 3 | -1/+17 |
| | | | | from cvs by adding .cvsignore files. | ||||
* | Temporary hack to compile. Need to probably address definition | Joel Sherrill | 2000-06-13 | 4 | -0/+4 |
| | | | | of all FIO constants and conflict with libnetworking code. |
