* | New file. | Joel Sherrill | 1999-05-26 | 1 | -0/+4 | |
* | Made the gen_section more accurate. | Joel Sherrill | 1999-05-26 | 13 | -253/+257 | |
* | Prototypes are now based on how the TRON specification states them. | Joel Sherrill | 1999-05-26 | 11 | -83/+166 | |
| | | | | The style in the output is not right but it is a good starting point. | |||||
* | Basic prototypes are now included. | Joel Sherrill | 1999-05-26 | 1 | -1/+6 | |
* | Regenerated to include more information in the stub. Now they have | Joel Sherrill | 1999-05-26 | 12 | -180/+184 | |
| | | | | the descriptive titles. | |||||
* | Changed word "directive" to "system call." | Joel Sherrill | 1999-05-26 | 1 | -1/+1 | |
* | Added error codes to all service calls | Joel Sherrill | 1999-05-26 | 1 | -14/+190 | |
* | Corrected error code section. | Joel Sherrill | 1999-05-26 | 12 | -168/+0 | |
* | Replaced error code section. | Joel Sherrill | 1999-05-26 | 12 | -252/+84 | |
* | Enhanced. | Joel Sherrill | 1999-05-26 | 1 | -63/+156 | |
* | Initiated updating this to reflect split up. | Joel Sherrill | 1999-05-26 | 2 | -4/+8 | |
* | Initial revision | Joel Sherrill | 1999-05-20 | 16 | -0/+4561 | |
* | Renamed to rtemstimer.c to avoid conflict with timer drivers in EVERY | Joel Sherrill | 1999-05-20 | 2 | -53/+2 | |
| | | | | BSP as we transition to more .o's and less .rel's. | |||||
* | Removed all post 4.0 changes. | Joel Sherrill | 1999-05-20 | 4 | -324/+312 | |
* | Patch from Daniel Kelley <dank@icube.com>: | Joel Sherrill | 1999-05-18 | 4 | -16/+16 | |
| | | | | | | I found a small buglet in the mips64orion _CPU_ISR_Set_level; the original was wiping out the level argument, and then comparing the current interrupt level with some random value of v0. See patch below. | |||||
* | Regenerated. | Joel Sherrill | 1999-05-18 | 17 | -2100/+1163 | |
* | Spacing correction. | Joel Sherrill | 1999-05-18 | 1 | -1/+0 | |
* | Reworked to avoid pulling in the jump point entry in EVERY executable. | Joel Sherrill | 1999-05-17 | 11 | -19/+50 | |
* | Fixed some typos. | Joel Sherrill | 1999-05-17 | 2 | -8/+8 | |
* | Split Interrupt Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 5 | -77/+118 | |
* | Split Signal Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 7 | -217/+312 | |
* | Dual-Ported Memory Manager split into one routine per file. | Joel Sherrill | 1999-05-17 | 13 | -473/+697 | |
* | Split Partition Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 13 | -606/+843 | |
* | Split Timer Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 18 | -926/+944 | |
* | Split Event Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 13 | -685/+916 | |
* | Split Rate Monotonic Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 17 | -833/+1141 | |
* | Split the Semaphore Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 15 | -969/+1537 | |
* | Moved some MP routines to semmp.c. | Joel Sherrill | 1999-05-17 | 4 | -110/+108 | |
* | Forgot to actually remove the routines. :) | Joel Sherrill | 1999-05-17 | 2 | -1496/+0 | |
* | Split Message Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 25 | -1/+2217 | |
* | Moved an MP routine from msg.c to here. | Joel Sherrill | 1999-05-17 | 2 | -0/+52 | |
* | Cleaned up some multiprocessing issues. | Joel Sherrill | 1999-05-17 | 2 | -34/+30 | |
* | Split Clock Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 10 | -388/+393 | |
* | Split Region Manager into one routine per file. | Joel Sherrill | 1999-05-17 | 17 | -911/+1241 | |
* | Splitting the Thread Handler forced the inclusion of more prototypes. | Joel Sherrill | 1999-05-17 | 2 | -0/+66 | |
* | Moved _Entry_Table to its own file to avoid having every RTEMS directive | Joel Sherrill | 1999-05-17 | 3 | -95/+107 | |
| | | | | pulled in. | |||||
* | Added simple test to find minimum code size of executive with this BSP | Joel Sherrill | 1999-05-17 | 8 | -1/+175 | |
| | | | | and RTEMS configuration. | |||||
* | Split Task Manager into multiple files. Eventually this effort will | Joel Sherrill | 1999-05-17 | 31 | -1923/+2768 | |
| | | | | reduce the size of executables. | |||||
* | Thread Handler split into multiple files. Eventually, as RTEMS is | Joel Sherrill | 1999-05-17 | 51 | -2609/+3968 | |
| | | | | split into one function per file, this will decrease the size of executables. | |||||
* | Patch from D. V. Henkel-Wallace <gumby@zembu.com> to remove compiler | Joel Sherrill | 1999-05-17 | 12 | -16/+16 | |
| | | | | warnings. | |||||
* | Patch from D. V. Henkel-Wallace <gumby@zembu.com>: | Joel Sherrill | 1999-05-17 | 2 | -0/+32 | |
| | | | | | | Here's a tiny patch that shreds memory returned to the pool (such as by free() and delete). This may help people find some nasty bugs, so here it is. | |||||
* | Added C++ linking rule from Rosimildo DaSilva <rdasilva@connecttel.com>. | Joel Sherrill | 1999-05-14 | 1 | -1/+20 | |
* | Added testing for C++ exceptions from Rosimildo DaSilva | Joel Sherrill | 1999-05-14 | 2 | -34/+180 | |
| | | | | <rdasilva@connecttel.com>. | |||||
* | Added 3COM 3C509 driver from Rosimildo DaSilva <rdasilva@connecttel.com>. | Joel Sherrill | 1999-05-14 | 7 | -2/+2247 | |
* | Regenerated. | Joel Sherrill | 1999-05-14 | 0 | -0/+0 | |
* | Enabled compilation of rtems_servers at request of Jake Janovetz | Joel Sherrill | 1999-05-14 | 8 | -12/+16 | |
| | | | | <janovetz@tempest.ece.uiuc.edu>. | |||||
* | Fixed typo. | Joel Sherrill | 1999-05-14 | 1 | -1/+1 | |
* | Added tool hints. | Joel Sherrill | 1999-05-14 | 3 | -1/+12 | |
* | New file. | Joel Sherrill | 1999-05-14 | 1 | -0/+47 | |
