* 2001-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-294-15/+39
| | | | | | | | | | * Adopt more automake rules: * automake/compile.am: Add LINK, CXXLINK, AS, ASCOMPILE; Remove ARFLAGS, LINK.c, COMPILE.S, LINK.cc; Add CPU_CFLAGS to CXXFLAGS, CFLAGS, ASFLAGS; * automake/leaf.am: Add CXXLINK_APP, LINK_APP, make-exe, apply CXXLINK_APP in make-cxx-exe. * automake/lib.am: Add ARFLAGS.
* 2001-10-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-292-1/+5
| | | | * network/Makefile.am: Fix improper use of $(srcdir) in VPATH.
* 2001-10-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-292-2/+4
| | | | * startup/linkcmds: Remove explicit force of output format.
* 2001-10-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-292-1/+5
| | | | * include/bsp.h: Modify Install_tm27_vector() so this BSP will link tm27.
* 2001-10-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-293-3/+9
| | | | | | * include/bsp.h: Modify Install_tm27_vector() so this BSP will link tm27. * startup/linkcmds: Fix definition of .init and .fini sections so this BSP will properly link with new __USE_INIT_FINI__ support.
* 2001-10-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-292-0/+18
| | | | | | | | * mpc8xx/timer/timer.c: Added hack for two macros that are not defined with the new exception processing model: rtems_cpu_configuration_get_timer_least_valid() rtems_cpu_configuration_get_timer_average_overhead() This is captured as PR57.
* 2001-10-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-293-0/+21
| | | | * .cvsignore, include/.cvsignore: Add more entries.
* 2001-10-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-294-2/+33
| | | | * .cvsignore: Add more entries.
* 2001-10-28 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-282-2/+8
| | | | | * include/rtems/score/sh7750_regs.h: Fix definitions of SH7750_SCBRR1 and SH7750_SCBRR2 so things compile.
* 2001-10-26 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2001-10-262-0/+65
| | | | * custom/mcf5206elite.cfg: New file.
* 2001-10-26 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2001-10-266-0/+168
| | | | | | | | | * New libcpu support for mcf5206e. * ChangeLog, clock/ckinit.c, clock/.cvsignore, configure.ac, console/mcfuart.c, console/.cvsignore, include/mcf5206e.h, include/mcfmbus.h, include/mcfuart.h, include/.cvsignore, mbus/mcfmbus.c, mbus/.cvsignore, timer/timer.c, timer/timerisr.S, timer/.cvsignore, .cvsignore: New files.
* 2001-10-26 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2001-10-2610-0/+324
| | | | | | | | | | | | | | | * New BSP for MCF5206eLITE evaluation board BSP. * ChangeLog, README, bsp_specs, configure.ac, console/console.c, console/.cvsignore, i2c/i2c.c, i2c/i2cdrv.c, i2c/.cvsignore, include/bsp.h, include/bspopts.h.in, include/coverhd.h, include/ds1307.h, include/i2c.h, include/i2cdrv.h, include/nvram.h, include/.cvsignore, nvram/nvram.c, nvram/.cvsignore, start/start.S, start/.cvsignore, startup/bspclean.c, startup/bspstart.c, startup/gdbinit, startup/init5206e.c, startup/linkcmds, startup/linkcmds.flash, startup/.cvsignore, times, tod/ds1307.c, tod/todcfg.c, tod/.cvsignore, tools/.cvsignore, tools/configure.ac, tools/runtest, tools/changes, wrapup/.cvsignore, .cvsignore: New files.
* 2001-10-26 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2001-10-266-3/+24
| | | | | * src/imfs/imfs_load_tar.c: Minor modification so this will compile with gcc-2.95.3 with the arguments "-m5200 -O4".
* 2001-10-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-263-0/+15
| | | | * Makefile.am, configure.ac: New libcpu support for mcf5206e.
* 2001-10-26 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2001-10-2616-0/+2541
* 2001-10-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-262-0/+6
| | | | * acinclude.m4: Added mcf5206elite.
* 2001-10-26 Victor V. Vengerov <vvv@oktet.ru>Joel Sherrill2001-10-2638-0/+4377
* 2001-10-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-264-48/+20
| | | | | * libc/libio.c: Cleanup of initialization per suggestion from Eric Norum.
* 2001-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-262-1063/+4
| | | | * aclocal.m4: Removed. Should not have been in CVS.
* 2001-10-26 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-263-12/+16
| | | | * include/sh/sh4uart.h, sci/sh4uart.c: Minor fixes post merge.
* 2001-10-26 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-267-22/+16
| | | | | * README, console/console.c, hw_init/hw_init.c, include/bsp.h, startup/bspstart.c, startup/linkcmds: Minor fixes post merge.
* 2001-10-26 Alexandra Kossovsky <sasha@oktet.ru>Joel Sherrill2001-10-263-0/+257
| | | | | * tools: New subdirectory. * tools/Makefile.am, tools/runtest: New files.
* changed version to ss-20011025Joel Sherrill2001-10-251-1/+1
* 2001-10-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-254-2/+10
| | | | * rtems++/Makefile.am: Pick up -lrtems++ even when debug.
* 2001-10-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-2520-18/+60
| | | | * startup/linkcmds: Added _init and _fini.
* 2001-10-25 Eric Norum <eric.norum@usask.ca>Joel Sherrill2001-10-254-0/+12
| | | | | * cdtest/system.h: Configure 1 semaphore. This probably covers up not defining one for the GCC C++ Run-Time Libraries.
* 2001-10-25 Jennifer Averett <jennifer@OARcorp.com>Joel Sherrill2001-10-254-264/+355
| | | | | | | * libc/unmount.c: Primarily restructuring and clean up to address procedures which did not do what their name implied. Also addressed problem situation where unmount fails and the filesystem was inconsistent. The mounted filesystem could have been left hanging.
* 2001-10-25 Jennifer Averett <jennifer@OARcorp.com>Joel Sherrill2001-10-259-22/+64
| | | | | | | * libc/libio.c: Initialize more fields to NULL/0 during initialiation. * include/rtems/libio_.h: Fix freenode macro so it works for sockets which do not have the full set of filesystem operations and are initialized via something other than open().
* 2001-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-257-0/+19
| | | | | | | * mpc8260/clock/.cvsignore, mpc8260/console-generic/.cvsignore, mpc8260/cpm/.cvsignore, mpc8260/exceptions/.cvsignore, mpc8260/include/.cvsignore, mpc8260/mmu/.cvsignore, mpc8260/timer/.cvsignore, mpc8260/.cvsignore: New files.
* 2001-10-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-244-11/+18
| | | | | * mpc8260/exceptions/Makefile.am, mpc8260/include/Makefile.am, mpc8xx/exceptions/Makefile.am: Updated to autoconf 2.52.
* 2001-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-242-1/+5
| | | | * mpc8260/include/mpc8260.h: "or" is a keyword in C++.
* 2001-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-248-74/+104
| | | | | | | | * aclocal.m4: Regenerated. * configure.ac, include/Makefile.am, irq/Makefile.am, vectors/Makefile.am: Updated to autoconf 2.52. * include/.cvsignore: Added newly generated files. * include/bsp.h: Added include of bspopts.h.
* 2001-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-242-2/+4
| | | | * vectors/Makefile.am: Remove bogus VPATH.
* 2001-10-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-234-4/+12
| | | | * macros/rtems/rtems/asr.nil: Fixed typo.
* 2001-10-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-234-2/+12
| | | | | * macros/Makefile.am: Replace INLINES w/ MACROS (Fix stupid typo in previous patch).
* 2001-10-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-229-0/+62
| | | | | | | * .cvsignore, configure.ac, configure.in, console/.cvsignore, include/.cvsignore, network/.cvsignore, start/.cvsignore, startup/.cvsignore, wrapup/.cvsignore: Added .cvsignore files and other files missed in previous commit.
* 01-10-22 Andy Dachs <a.dachs@sstl.co.uk>Joel Sherrill2001-10-2238-0/+6919
| | | | | | | | | | | | | | | | | * mpc8260ads added as new BSP. tm27 reported not to run at this time. * ChangeLog, Makefile.am, README, aclocal.m4, bsp_specs, clock/.cvsignore, clock/Makefile.am, clock/p_clock.c, configure.in, console/Makefile.am, console/console.c, include/Makefile.am, include/bsp.h, include/coverhd.h, irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c, network/Makefile.am, network/README, network/if_hdlcsubr.c, network/if_hdlcsubr.h, network/network.c, start/Makefile.am, start/start.S, startup/Makefile.am, startup/bspstart.c, startup/cpuinit.c, startup/linkcmds, startup/setvec.c, times, vectors/.cvsignore, vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h, vectors/vectors_init.c, wrapup/Makefile.am: New files.
* 2001-10-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-222-0/+6
| | | | * acinclude.m4: Added mpc8260ads subdirectory.
* 2001-10-22 Andy Dachs <a.dachs@sstl.co.uk>Joel Sherrill2001-10-222-0/+119
| | | | * custom/mpc8260ads.cfg: New file.
* 2001-10-22 Andy Dachs <a.dachs@sstl.co.uk>Joel Sherrill2001-10-229-6/+50
| | | | | | * Makefile.am, README, configure.ac, new_exception_processing/cpu.h, shared/include/cpu.h, shared/include/cpuIdent.c, shared/src/cache.c: Added mpc8260 support.
* 2001-10-22 Andy Dachs <a.dachs@sstl.co.uk>Joel Sherrill2001-10-225-6/+299
| | | | * shared/ppc.h: Added mpc8260 support.
* 2001-10-22 Andy Dachs <a.dachs@sstl.co.uk>Joel Sherrill2001-10-2226-0/+4409
| | | | | | | | | | | | | | | | * Added mpc8260 directory. * Modified Makefile.am and configure.in to build the contents * mpc8260/Makefile.am, mpc8260/README, mpc8260/clock/Makefile.am, mpc8260/clock/clock.c, mpc8260/console-generic/Makefile.am, mpc8260/console-generic/console-generic.c, mpc8260/cpm/.cvsignore, mpc8260/cpm/Makefile.am, mpc8260/cpm/brg.c, mpc8260/cpm/cp.c, mpc8260/cpm/dpram.c, mpc8260/exceptions/.cvsignore, mpc8260/exceptions/Makefile.am, mpc8260/exceptions/asm_utils.S, mpc8260/exceptions/raw_exception.c, mpc8260/exceptions/raw_exception.h, mpc8260/include/Makefile.am, mpc8260/include/console.h, mpc8260/include/cpm.h, mpc8260/include/mmu.h, mpc8260/include/mpc8260.h, mpc8260/mmu/Makefile.am, mpc8260/mmu/mmu.c, mpc8260/timer/Makefile.am, mpc8260/timer/timer.c: New files.
* 2001-10-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-222-3/+8
| | | | | * bootcard.c: Use __USE_INIT_FINI__ since USE_INIT_FINI pollutes the application namespace.
* 2001-10-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-224-6/+16
| | | | | * src/threadhandler.c: Use __USE_INIT_FINI__ since USE_INIT_FINI pollutes the application namespace.
* 2001-10-18 Till Straumann <strauman@SLAC.Stanford.EDU>Joel Sherrill2001-10-197-6/+8
| | | | | * libc/open.c, libc/close.c: Moved freenode from open to close.
* 2001-10-18 Eric Norum <eric.norum@usask.ca>Joel Sherrill2001-10-186-69/+255
| | | | | * lib/tftpDriver.c: Properly handles ../ components in chdir() and open() operations within the TFTP file system.
* changed version to ss-20011017Joel Sherrill2001-10-171-1/+1
* 2001-10-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-172-0/+40
| | | | * timerstub.c: New stub file for BSPs that don't have timer hardware.
* 2001-10-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-172-6/+7
| | | | | * aclocal/check-rdbg.m4: Fix latent bug exposed by removal of config.cache's which prevented powerpc targets librdbg from building.
* 2001-10-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-172-1/+6
| | | | | * configure.ac: Fix latent bug exposed by removal of config.cache's which prevented powerpc targets librdbg from building.
