* clock/ckinit.c: Removed include of <bsp.h>. Also switch to
macros to get configuration data.
* timer/timer.c: Removed include of <bsp.h>. Fixed comment
that said 4650 (a mips part).
* shmdr/shm_driver.h: Added _AM29K entry. May not be correct.
* include/bsp.h: tty_* renamed to console_*.
* tty/tty.c: Ditto.
* shmsupp/addrconv.c: Typo fixed.
* wrapup/Makefile.am: Merge startup not start directory.
* ChangeLog: Entry added to wrong file and moved.
* bsp_specs: Formatting more like other bsp_specs.
* include/bsp.h: CPU_CLOCK_RATE_MHZ not a real variable to
elimate need for including bsp.h in libcpu.
* startup/bspstart.c: Ditto.
* wrapup/Makefile.am: Did not list shmdr.
* rtems/system.h: Switched a29k and hppa1.1 to using cpuopts.h not
targopts.h to reduce dependency on BSP.
* rtems/score/hppa.h: Switched to using cpuopts.h not
* rtems/score/a29k.h, rtems/score/cpu.h: Switched to using
cpuopts.h not targopts.h to reduce dependency on BSP.
* startup/linkcmds: Use default object format to avoid name
changes in object format due to tool version changes.
* machine/types.h, pppd/pppd.h, rtems/rtems_bsdnet_internal.h,
rtems_webserver/webmain.c: machine/types.h should not have
included rtems.h. It is now including precisely the
least amount of low level, yet portable .h files to get
the basic RTEMS types defined. This rippled into other
files since rtems_bsdnet_internal.h used machine/types.h to include
rtems.h.
* src/xdr/xdr_float.c: Added A29K support.
* clock/clock.S: Commented out non-GNU assembly.
* libc/newlibc.c: Removed _A29K specific ifdef.
* amd.ah, cpu.c, cpu_asm.S, register.ah, sig.S, rtems/score/cpu.h:
Updated and fixed minor things. Commented out offensive assembly
and made applications link.
* start/crt0.S: Renamed to start/start.S.
* start/start.S: Formerly start/crt0.S.
* startup/linkcmds: New file. GNU linker script that is not
correct for the target board but links programs.
* bsp_specs: Use linkcmds.
* include/Makefile.am, start/Makefile.am startup/Makefile.am:
Now work.
* startup/bspstart.c, startup/setvec.c: "#if 0"'ed out references
to reoutines in assembly that are in turn "#if 0"'ed out.
* Makefile.am: Removed definition of ACLOCAL_AMFLAGS.
* Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
* Makefile.am, cpu_asm.S, psmacro.ah, rtems/score/cpu.h:
First attempt to compile with GNU tools. Minor modifications
to compile enough to get to assembler errors.
* src/objectgetbyindex.c: Do not enable dispatching on an
error path it was not disabled on.
* include/mvme16x_hw.h: Include rtems/score/targopts.h so we
can check which BSP this is being used with.
* Makefile.am: Referenceed aclocal/enable-hwapi.m4 that was removed.
* aclocal/enable-hwapi.m4: Now longer used and removed.
* automake/lib.am: Remove leaf.cfg.
* bsp_specs, console/Makefile.am, include/Makefile.am: Clean up.
* Makefile.am, bsp_specs, configure.in, console/Makefile.am,
include/Makefile.am, irq/Makefile.am, irq/irq.c, start/Makefile.am,
startup/Makefile.am, startup/exit.c, wrapup/Makefile.am:
Made to conform to current practice concerning automake and
autoconf. Corrected minor warnings.
* custom/arm_bare_bsp.cfg, custom/armulator.cfg, custom/dmv177.cfg,
custom/mcp750.cfg, custom/vegaplus.cfg: Clean up.
* vegaplus BSP submitted by Emmanuel Raguet <raguet@crf.canon.fr> and
Eric Valette <valette@crf.canon.fr>.
* custom/vegaplus.cfg: New file.
* vegaplus/bsp_specs, configure.in, console/Makefile.am,
include/Makefile.am, include/bsp.h, include/registers.h,
irq/Makefile.am, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c,
irq/irq.h, start/Makefile.am, start/start.S, startup/Makefile.am,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
wrapup/Makefile.am: New files.
* leaf.cfg: Remove Depends inclusion.
* aclocal/rtems-top.m4: Add ENDIF-hack.
* automake/compile.am: Add include $(DEPENDS) + ENDIF-hack.
* custom/erc32.cfg: Add comment on -mno-v8, -mcypress.
* custom/gen68302.cfg: Comment out LIBC_LIB[C|M].
* custom/gen68340.cfg: Comment out LIBC_LIB[C|M].
* custom/gen68360.cfg: Comment out LIBC_LIB[C|M].
* custom/idp.cfg: Comment out LIBC_LIB[C|M].
* custom/mvme162.cfg: Comment out LIBC_LIB[C|M].
* custom/ods68302.cfg: Comment out LIBC_LIB[C|M].
* leaf.cfg: Remove include ${CONFIG.CC}, add MANAGERS, START_FILE,
LINKCMDS handling.
* default.cfg.in: Remove everything but START_BASE.
* configure.in: Add RTEMS_PROG_CC_FOR_TARGET,
RTEMS_CANONICALIZE_TOOLS.
* aclocal/check-cxx.m4: Add AC_SUBST(CPLUS_LD_LIBS)
* aclocal/prog-cc.m4: Cleanup comments, require RTEMS_ENABLE_GCC28,
add automake conditionals RTEMS_USE_GCC, RTEMS_USE_GCC272.
* automake/compile.am: Replaced.
* automake/local.am: Remove building variant handling.
* rtems/score/i386.h: Corrected "#elsif" to be "#elif".
* start/Makefile.am: Remove AM_CPPFLAGS and GAS_CODE16 conditional.
* startup/Makefile.am: Cleanup comments.
* aclocal/enable-rtemsbsp.m4: Add RTEMS_ENABLE_BARE,
AC_SUBST(BARE_CPU_MODEL),AC_SUBST(BARE_CPU_CFLAGS).
* aclocal/i386-gas-code16.m4: AC_DEFINE NEW_GAS.
* aclocal/target.m4: Cleanup comments
* Automake/compile.am: Add DEFS support to keep building happy.
* target.cfg.in: Comment out DEFS.
* Makefile.am: Use += to set up AM_CPPFLAGS.
* custom/gensh2.cfg: Fix comments.
* multigen: Fix BARE_CPU_CFLAGS.
* custom/mvme167.cfg (CPP_CFLAGS): Corrected to only include
compiler arguments that specify CPU model options.
* custom/mbx860_005b.cfg (make-target-options): Add lines to
define PRINTK_MINOR SMC1_MINOR and PRINTK_IO_MODE. The settings
may be incorrect but the BSP now compiles.
* network/network.c (uti596_attach): Adjust cpp directives
and conditional braces so all cases compile.
* wrapup/rtems/Makefile.am: Use PROJECT_TOPdir in path to size_rtems.
* scitab/Makefile.am: PROJECT_TOPdir.
* rtems/score/Makefile.am: Use PROJECT_TOPdir in path to genoffsets.
