* | Id reinserted | Joel Sherrill | 1995-08-17 | 3 | -3/+3 |
* | no limit removed | Joel Sherrill | 1995-08-17 | 5 | -14/+11 |
* | bug fixes to make macro implementations work | Joel Sherrill | 1995-08-16 | 52 | -246/+101 |
* | final 3.2.1 Module file and version updates | Joel Sherrill | 1995-08-15 | 2 | -2/+2 |
* | added alignment attribute for array used as partition memory. | Joel Sherrill | 1995-08-11 | 2 | -2/+2 |
* | cleanup | Joel Sherrill | 1995-08-11 | 2 | -12/+16 |
* | Added functions to access the errno of the native system when using the | Joel Sherrill | 1995-08-11 | 6 | -3/+150 |
| | | | | | | | newlib C library. Fixed bug where length did not take into account amount added for alignment requirements. | ||||
* | Added functions to access the errno of the native system when using the | Joel Sherrill | 1995-08-11 | 4 | -28/+8 |
| | | | | newlib C library. | ||||
* | Added flush of output on exit. On some UNIX's using the native library | Joel Sherrill | 1995-08-11 | 4 | -48/+65 |
| | | | | | | | | | resulted in no output when the output was redirected until this was done. Redirection is important because runtest redirects test output. Added support for numerous environment variables which make it easier to run a multi-node system using a single executable and to tailor the size of the workspace and heap. | ||||
* | Initialization of semaphores was incorrect. It did not force | Joel Sherrill | 1995-08-11 | 4 | -56/+98 |
| | | | | | | | | | | | | the count to "1" to indicate availability. Interrupt support was added. Problem where newlib's errno "overrides" that set by system calls was addressed. Fixed bug which resulted in all nodes using the same semaphore although an array of semaphores was allocated. | ||||
* | clean up -- interrupt support is in place | Joel Sherrill | 1995-08-11 | 1 | -5/+25 |
* | minor clean up -- switched to memset for zero'ing SHM | Joel Sherrill | 1995-08-11 | 9 | -152/+135 |
* | cleaned up include statements | Joel Sherrill | 1995-08-11 | 1 | -1/+1 |
* | clean up of RunWay interrupt support | Joel Sherrill | 1995-08-11 | 2 | -3/+11 |
* | added constant for number of notepads | Joel Sherrill | 1995-08-11 | 3 | -24/+30 |
* | cleanup and optimization from Tony | Joel Sherrill | 1995-08-04 | 3 | -38/+38 |
* | Split out event manager support function | Joel Sherrill | 1995-08-04 | 2 | -40/+0 |
* | split out event support functions in anticipation of making a handler | Joel Sherrill | 1995-08-04 | 2 | -382/+0 |
* | Tony's updates | Joel Sherrill | 1995-08-04 | 1 | -4/+9 |
* | updaetd to remove UNIX simulator bugs | Joel Sherrill | 1995-08-04 | 1 | -11/+0 |
* | Changed order of include files. | Joel Sherrill | 1995-08-02 | 1 | -1/+1 |
* | *** empty log message *** | Joel Sherrill | 1995-08-02 | 3 | -2/+13 |
* | Added test cases: | Joel Sherrill | 1995-08-02 | 2 | -4/+142 |
| | | | | | | + some from Andy Bray (andy@i-cubed.demon.co.uk) which do not include task start up cost. + cases for interrupt disable, enable, and flash | ||||
* | deleted unused code | Joel Sherrill | 1995-08-01 | 2 | -76/+0 |
* | updated mvme162 code from Misha (mms@eiscathq.irf.se) | Joel Sherrill | 1995-08-01 | 8 | -618/+617 |
* | moved ringbuf.h to a shared include directory | Joel Sherrill | 1995-08-01 | 3 | -0/+126 |
* | Switched to events for mp receive server and eliminated the special | Joel Sherrill | 1995-07-31 | 12 | -241/+105 |
| | | | | blocking mechanism for it. | ||||
* | fixed path problem for POSIX | Joel Sherrill | 1995-07-31 | 1 | -2/+2 |
* | Added info for DOS Bourne shell | Joel Sherrill | 1995-07-31 | 1 | -1/+14 |
* | updates for msdos/go32 from Bryce Cogswell | Joel Sherrill | 1995-07-26 | 7 | -26/+1006 |
* | times reported reasonably correctly | Joel Sherrill | 1995-07-24 | 1 | -4/+5 |
* | hopefully works with regular timer and tm27 | Joel Sherrill | 1995-07-24 | 1 | -38/+51 |
* | after testing go32 and cvme961 | Joel Sherrill | 1995-07-21 | 8 | -21/+38 |
* | updating go32 to make timer more accurate | Joel Sherrill | 1995-07-20 | 5 | -51/+56 |
* | removed junk field in context_control | Joel Sherrill | 1995-07-20 | 1 | -1/+0 |
* | committing for rtems-3.2.01 snapshot | Joel Sherrill | 1995-07-18 | 12 | -34/+30 |
* | fixed for Linux | Joel Sherrill | 1995-07-18 | 3 | -0/+20 |
* | fixed for Linux | Joel Sherrill | 1995-07-18 | 1 | -0/+4 |
* | fixed for Linux | Joel Sherrill | 1995-07-18 | 2 | -26/+48 |
* | merged Linux UNIX simulator support (C) | Joel Sherrill | 1995-07-18 | 6 | -7/+76 |
* | all built successfully after merge | Joel Sherrill | 1995-07-13 | 1 | -2/+2 |
* | fix oversites in libbsp/unix/posix | Joel Sherrill | 1995-07-12 | 1 | -0/+71 |
* | Ada95, gnat, go32 | Joel Sherrill | 1995-07-12 | 64 | -764/+4062 |
* | added David Glessner's 68302 work. | Joel Sherrill | 1995-06-14 | 2 | -10/+10 |
* | added David Glessner's 68302 work to ACKNOWLEDGEMENTS. | Joel Sherrill | 1995-06-14 | 2 | -11/+49 |
| | | | | updated PROBLEMS to reflect recently reported things. | ||||
* | corrected pseudo-code for _ISR_Handler | Joel Sherrill | 1995-06-07 | 2 | -10/+34 |
* | added for first time | Joel Sherrill | 1995-06-07 | 1 | -0/+45 |
* | incorporated mc68302 support | Joel Sherrill | 1995-06-07 | 21 | -14/+3532 |
* | added calls to _Thread_Disable_dispatch to match requirements | Joel Sherrill | 1995-06-05 | 2 | -6/+26 |
| | | | | for invocation of _Thread_Handler | ||||
* | conditional added for the hppa gr27 | Joel Sherrill | 1995-06-05 | 2 | -0/+4 |
