* | Updated for beta4b | Joel Sherrill | 1998-10-27 | 1 | -3/+3 |
* | Corrected 2nd invocation of texi2dvi so indices are built. | Joel Sherrill | 1998-10-27 | 2 | -2/+1 |
* | changed version to 4.0.0 | Joel Sherrill | 1998-10-27 | 3 | -3/+3 |
* | Update from David Fiddes. | Joel Sherrill | 1998-10-27 | 4 | -113/+104 |
* | Clarifed description of driver name. | Joel Sherrill | 1998-10-27 | 1 | -1/+4 |
* | Version changed. | Joel Sherrill | 1998-10-27 | 1 | -4/+4 |
* | Version change. | Joel Sherrill | 1998-10-27 | 1 | -1/+1 |
* | Spacing. | Joel Sherrill | 1998-10-27 | 1 | -1/+0 |
* | Merged base line score603e BSP | Joel Sherrill | 1998-10-26 | 1 | -28/+28 |
* | changed version to 4.0.0-beta4b | Joel Sherrill | 1998-10-26 | 0 | -0/+0 |
* | changed version to 4.0.0-beta4b | Joel Sherrill | 1998-10-26 | 3 | -3/+3 |
* | Patches done in conjunction with Juan Zamorano Flores | Joel Sherrill | 1998-10-26 | 7 | -14/+31 |
| | | | | | <jzamora@avellano.datsi.fi.upm.es>. He debugged enough to let me know what was wrong and I supplied the code. :) | ||||
* | Updated for mvme136. | Joel Sherrill | 1998-10-26 | 1 | -1/+1 |
* | Updated the date. | Joel Sherrill | 1998-10-26 | 1 | -2/+1 |
* | Patch from Erik Ivanenko <erik.ivanenko@utoronto.ca>: | Joel Sherrill | 1998-10-22 | 1 | -15/+16 |
| | | | | | | | | | | Please find attached a new i386ex.cfg. It has been altered to change the files that get generated with the .nxe extension to .coff. This change is necessary to align the file names generated by "make-exe" to the those referred to in the GDB.HOWTO found in the i386/shared/comm directory. It has been successfully tested on ticker ( without GDB), and base_sp( with GDB ) . I just set a breakpoint and continue... | ||||
* | Typos spotted by Ian Lance Taylor <ian@airs.com>. | Joel Sherrill | 1998-10-22 | 1 | -2/+2 |
* | Added missing .rodata and *(.gnu.linkonce.r*) section. | Joel Sherrill | 1998-10-22 | 1 | -0/+4 |
* | Patch from Ian Lance Taylor <ian@airs.com>: | Joel Sherrill | 1998-10-22 | 1 | -0/+1 |
| | | | | | | | | | I noticed that in the 4.0.0-beta4a tar file, the file c/src/lib/libbsp/i386/pc386/startup/linkcmds was changed so that it no longer handles the .gnu.linkonce.r* sections. The appended patch was applied to the file. I'm not sure why. I think this patch should probably be backed out, although it's not critical for the release. | ||||
* | Patch from Eric Norum. | Joel Sherrill | 1998-10-22 | 1 | -4/+6 |
* | Changed all of these to stubs. | Joel Sherrill | 1998-10-22 | 21 | -1209/+102 |
* | Corrections from Jennifer and Jeff plus additions to the initialization | Joel Sherrill | 1998-10-21 | 5 | -87/+285 |
| | | | | chapter. | ||||
* | Spell checked. | Joel Sherrill | 1998-10-20 | 3 | -3/+3 |
* | Added much text to the linkcmds chapter. | Joel Sherrill | 1998-10-20 | 3 | -44/+68 |
| | | | | Cleaned up sections in the target dependent info file. | ||||
* | Links between chapters up to Linker Script in place. | Joel Sherrill | 1998-10-20 | 3 | -45/+119 |
| | | | | First draft of chapters up to and include Makefiles written. | ||||
* | Significant additions. | Joel Sherrill | 1998-10-20 | 1 | -45/+156 |
* | Renamed the target dependent code chapter. | Joel Sherrill | 1998-10-20 | 1 | -2/+2 |
* | Added some links between chapters. | Joel Sherrill | 1998-10-20 | 1 | -9/+8 |
* | Spacing changed. | Joel Sherrill | 1998-10-20 | 1 | -3/+2 |
* | Added new chapters. | Joel Sherrill | 1998-10-20 | 1 | -15/+55 |
* | Added multiple chapters and reordered them somewhat. | Joel Sherrill | 1998-10-20 | 1 | -2/+16 |
* | New files. | Joel Sherrill | 1998-10-20 | 7 | -0/+84 |
* | Added numerous comments to the linker script. | Joel Sherrill | 1998-10-20 | 1 | -243/+271 |
| | | | | Now this chapter has no two column stuff in it. | ||||
* | Added initial cut at some of the libc chapters. | Joel Sherrill | 1998-10-20 | 1 | -0/+27 |
* | Removed KA9Q manual. | Joel Sherrill | 1998-10-20 | 1 | -2/+0 |
* | New picture. | Joel Sherrill | 1998-10-20 | 1 | -0/+0 |
* | Updated. | Joel Sherrill | 1998-10-20 | 2 | -27/+30 |
* | Added more disk space to the requirements and included information | Joel Sherrill | 1998-10-20 | 1 | -3/+8 |
| | | | | indicating that it was per target. | ||||
* | Minor cleanup. | Joel Sherrill | 1998-10-20 | 2 | -4/+4 |
* | Added information about the bit_rtems script. | Joel Sherrill | 1998-10-20 | 2 | -5/+79 |
* | Added information about the new build scripts. | Joel Sherrill | 1998-10-20 | 1 | -56/+86 |
| | | | | Added host OS specific notes. | ||||
* | Added sections and had to change build menu commands. | Joel Sherrill | 1998-10-20 | 1 | -1/+1 |
* | Increased required disk space along with information about the required | Joel Sherrill | 1998-10-20 | 1 | -3/+23 |
| | | | | | | disk space. Added information about GNU makeinfo minimum version. | ||||
* | Added information about the bit_gdb script. | Joel Sherrill | 1998-10-20 | 1 | -3/+35 |
* | Added information about the new build scripts. The biggest thing was | Joel Sherrill | 1998-10-20 | 1 | -59/+73 |
| | | | | | | describing the user.cfg file. Added a section on Solaris 2.x. | ||||
* | Added sections so had to change the build menu commands. | Joel Sherrill | 1998-10-20 | 1 | -2/+2 |
* | Enhanced times() with copy from the other chapter. | Joel Sherrill | 1998-10-19 | 1 | -13/+16 |
* | Removed times() since it is duplicated. | Joel Sherrill | 1998-10-19 | 1 | -31/+0 |
* | Updated to reflect the longer list of libraries. | Joel Sherrill | 1998-10-19 | 1 | -3/+3 |
* | Removed node information. | Joel Sherrill | 1998-10-19 | 1 | -28/+1 |
* | Removed node information now that it is automatically generated. | Joel Sherrill | 1998-10-19 | 1 | -42/+0 |
