* | Split ITRON Message Buffer Manager into multiple files. | Joel Sherrill | 1999-11-15 | 23 | -709/+1045 |
* | Split ITRON semaphore manager into multiple files. | Joel Sherrill | 1999-11-15 | 17 | -569/+754 |
* | + Modified calls to use TSK_SLF for calls to self. | Joel Sherrill | 1999-11-12 | 2 | -50/+48 |
| | | | | + Modified calls to use the task id macro for calls to the PREEMPT task. | ||||
* | + Added comments on paths tested. | Joel Sherrill | 1999-11-12 | 4 | -2/+28 |
* | + Added check for priority over 256. | Joel Sherrill | 1999-11-12 | 2 | -2/+8 |
| | | | | + Modified output to correctly state the error. | ||||
* | Added comments for path's tested. | Joel Sherrill | 1999-11-12 | 2 | -0/+6 |
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 8 | -74/+54 |
| | | | | | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead of enabling dispatching and returning E_OK. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 2 | -22/+22 |
| | | | | + Removed error path that should never happen. | ||||
* | + Changed validation of the_thread to validation of location. | Joel Sherrill | 1999-11-12 | 4 | -34/+16 |
* | + Moved error checks to before the disable dispatch where possible. | Joel Sherrill | 1999-11-12 | 2 | -10/+10 |
* | Added comment about the E_CTX error condition (Implementation dependent). | Joel Sherrill | 1999-11-12 | 2 | -0/+14 |
* | + Moved error checks to before the dispatch disable where possible. | Joel Sherrill | 1999-11-12 | 2 | -26/+24 |
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 2 | -30/+20 |
| | | | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. + Set correct error code when dormant state. + Fixed comment. | ||||
* | + Modified correct return path to call _ITRON_return_errorno( E_OK ) instead | Joel Sherrill | 1999-11-12 | 2 | -10/+4 |
| | | | | | of enabling dispatching and returning E_OK. + Changed validation of the_thread to validation of location. | ||||
* | Corrected so now actually indexes into the allocation block. | Joel Sherrill | 1999-11-12 | 2 | -20/+12 |
* | Corrected remaining references to struct rtems_task_variable_t since | Joel Sherrill | 1999-11-12 | 4 | -14/+22 |
| | | | | it is now typedef'ed. | ||||
* | Removed unnecessary 3rd parameter. | Joel Sherrill | 1999-11-12 | 2 | -2/+2 |
* | New file. | Joel Sherrill | 1999-11-12 | 2 | -0/+26 |
* | Used typedef so all "struct rtems_task_variable_t" uses are now | Joel Sherrill | 1999-11-12 | 8 | -38/+38 |
| | | | | just "rtems_task_variable_t". | ||||
* | Added per-task variable data stucture (rtems_task_variable_t), | Joel Sherrill | 1999-11-12 | 2 | -8/+72 |
| | | | | | task_variables field to API extension, and two directives (rtems_task_variable_add and rtems_task_variable_delete). | ||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 12 | -16/+18 |
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 4 | -12/+22 |
| | | | | Changed output to reflect what was actually being tested. | ||||
* | Test name changed to reflect placement after merger. | Joel Sherrill | 1999-11-12 | 8 | -10/+18 |
| | | | | Increased stack space. | ||||
* | Added per task variables based on patch from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-12 | 7 | -7/+446 |
| | | | | | After being submitted, this support was rewritten to be inside the executive rather than layered on top of it using an extension. | ||||
* | Cleaned up style. | Joel Sherrill | 1999-11-12 | 2 | -486/+478 |
* | Removed redundant line. | Joel Sherrill | 1999-11-12 | 2 | -2/+0 |
* | Merged message buffer code from CS595 projects. | Joel Sherrill | 1999-11-12 | 0 | -0/+0 |
* | Enabled after merging message buffer code. | Joel Sherrill | 1999-11-12 | 2 | -12/+4 |
* | Added comment block and removed include of deleted file. | Joel Sherrill | 1999-11-12 | 2 | -2/+8 |
* | Added information about the NTP servier field and included a copy | Joel Sherrill | 1999-11-11 | 2 | -3/+69 |
| | | | | of the C definition of the configuration structure. | ||||
* | Updated. | Joel Sherrill | 1999-11-11 | 1 | -4/+15 |
* | Screen updated. | Joel Sherrill | 1999-11-11 | 2 | -0/+4 |
* | Added new test sp28 to test the task variable directives. | Joel Sherrill | 1999-11-11 | 10 | -2/+278 |
* | General cleanup. Test documentation improved. The message buffer test | Joel Sherrill | 1999-11-10 | 30 | -44/+162 |
| | | | | | prints a message instead of actually testing since the message buffer implementation is not in yet. | ||||
* | Corrected to account for the way memory is divided up in | Joel Sherrill | 1999-11-10 | 2 | -14/+18 |
| | | | | | _Object_Extend_information. This change is a side-effect of the change made to that file to fix an alignment problem. | ||||
* | Added line to make sure HAS_ITRON_API is defined in Makefile. | Joel Sherrill | 1999-11-10 | 1 | -2/+1 |
* | Added call to _Thread_Enable_dispatch() and did some cleanup. | Joel Sherrill | 1999-11-10 | 2 | -4/+18 |
* | rtems_semaphore_flush test from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-10 | 11 | -29/+290 |
* | Patch from Eric Norum <eric@cls.usask.ca> which includes: | Joel Sherrill | 1999-11-10 | 10 | -25/+490 |
| | | | | | Patches against 1105 snapshot to add NTP server support to network configuration/BOOTP. | ||||
* | Combination of committing some new files which had been overlooked | Joel Sherrill | 1999-11-10 | 18 | -2/+558 |
| | | | | and adding code which installed screens for itron tests. | ||||
* | Committed modifications from ITRON Task and Task Dependendent Synchronization | Joel Sherrill | 1999-11-10 | 67 | -419/+1389 |
| | | | | Working Group. Included are tests. | ||||
* | Added support for ITRON tests. | Joel Sherrill | 1999-11-10 | 2 | -0/+4 |
* | Updated to include more documentation from CS595. | Joel Sherrill | 1999-11-10 | 5 | -22/+51 |
* | Better formatting. | Joel Sherrill | 1999-11-10 | 1 | -47/+75 |
* | Added more tasking tests. | Joel Sherrill | 1999-11-09 | 3 | -2/+7 |
* | Merged tests from Task group. | Joel Sherrill | 1999-11-09 | 66 | -76/+3584 |
* | Added nesting count for suspend/resume. | Joel Sherrill | 1999-11-09 | 2 | -2/+2 |
* | Changed B, H, and W variables to BVar, HVar, and WVar to avoid conflicts | Joel Sherrill | 1999-11-09 | 2 | -70/+70 |
| | | | | | with ITRON 3.0 data types regardless of how dumb it is to name types with a simple letter. | ||||
* | Commented out single letter type names since they conflict with | Joel Sherrill | 1999-11-09 | 2 | -0/+12 |
| | | | | numerous other uses of the same variable. | ||||
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 12 | -14/+83 |
| | | | | for RTEMS. |
