description follows:
Description:
config.h.ins)
acpolish
configure scripts
Remarks:
[$(prefix)].
issues.
egcs/contrib/egcs_update).
ATTENTION:
* "make RTEMS_BSP=<bsp> dist"
2 lines of code that did not get included when Joel tried to manually
add a rejected patch.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
and automake.
reorg-bsp_specs.sh script.
significantly.
This is the next step towards automake:
* Two scripts for the toplevel directory:
a) "autogen" (Idea borrowed from libtool and gnome) A helper script to
recursively regenerate autoconf/automake/aclocal generated files
(Still not perfect but sufficient).
b) "missing" (from automake-cvs archive). This file normally is
automatically generated by automake, but we have to manually add
it until we add automake support to the toplevel configure script.
"chmod 755 missing autogen" after applying the patch.
* Changing the toplevel installation directory [ I can hear you
falling off the chair ;-]
Until now rtems installed itself to $(prefix)/rtems. This is in
contradiction to automake and GNU/FSF/Cygnus conventions.
With this patch applied, rtems installs into $(prefix).
To achieve the old behaviour simply configure with
--prefix=<install-dir>/rtems instead of --prefix=<install-dir>
This is a widely visible change and I can understand if you don't
like it at the present point. It enables us to use automake's
default installation paths instead of having to set up installation
paths manually. At the moment this doesn't help much, but in the not
so far future this would enable us to mix cpu-only dependent libraries
into the host's cross-compiler library and header files into
newlib's include directories, tools into the toolchain directories etc.
I would recommend to change the main installation directory, however it's
up to you to draw the final design decision.
OK, I 've made up my mind to cut a big chunk of my automake-patches (:-).
Below you can find a drop-in replacement of the aclocal directory. It
contains a lot of new macro files, most of them are directly cut from rtems
top-level configure script, some are new some are identical to former
versions. The motivation behind these files is to reuse parts from rtems
current top-level configure.in script in up-coming subdirectory configure.in
scripts.
I'd like to ask you to untar the archive ontop of the source tree and to
add/commit these files to CVS. Adding these files should not have any
influence on RTEMS momentary configuration (except of you are required to
run aclocal -I aclocal && autoconf afterwards), because most of them
currently are not used at all.
BTW: Please upgrade to autoconf-2.13 and automake-2.4, if you havn't done
this already (egcs/CVS require them, too). My upcoming automake files
require automake-2.4 which requires autoconf-2.13 or later.
fcntl support and an external fcntl handler for sockets.
Moves some configure.in fragments to new macro files below aclocal/
(Motivation: Prepare splitting the toplevel configure.in script)
Erik Ivanenko pointed out a problem in the ne2000.c driver I
submitted: it did not work correctly with bootp. Here is a patch,
based on a patch he sent me.
about the enable rdbg configure option.
are:
<ccj@acm.org>.
are build issues with it.
problems that prevented the 19990302 snapshot from running on
the efi332.
I'm happy to report that rtems-19990302 is running on the efi332
board. I have enclosed a few minor patches below to the efi332 bsp. All
patches are within that library but one. make/custom/efi332.cfg has a
patch to select the right CPU_CFLAGS (at one time -m68332 was a
problem... -mcpu32 or -m68332 work fine now).
by Jiri Gaisler <jgais@ws.estec.esa.nl> when using this
driver on a SPARC.
calculated.
patch.
would work. At the same time, the initial implementation of F_SETFL
was added. A support routine was added to convert internal libio
flags back to the POSIX style. Eventually the internal representation
should be eliminated in the interest of simplicity and code reduction.
This problem was reported by Jake Janovetz <janovetz@tempest.ece.uiuc.edu>.
that shows up if the BSP uses memory near address 0.
in the eth_comm BSP documentation.
Comments follow:
Please find attached, the updated network driver. I have verified
that it is working as expected, by timestamping the error messages
generated from the ISR.
If you've taken a look inside, the network driver has a reset thread
in addition to the RX and TX threads. It is possible to avoid the
additional reset thread by allowing the TX driver to time out and then
checking status bits set by the ISR. However, this approach demands
that a transmission is necessary for the NIC to be reset.
Due to Eric V's ISR handling, I suppose that the reset routine could
be called from the "ISR" itself, due to the 8259 interrupt mode, and
that the interrupt is acknowledged prior to running the "ISR".
(Providing that no NIC interrupts are generated during reset -- I
worry about re-entrancy. )
This would be a minor improvement, but you know, I don't want to make
this driver my lifes work.
--enable-tests switch.
--enable-tests flag.
rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory
too fast. Perhaps in the future, the places in IMFS that put a maximum
length name string on the stack and the jnode structure does not include
a maximu length name string can be fixed so this is not a problem.
FP issues on this target:
The default variants of libc, libm and libgcc assume that a 68881
coprocessor is present. Without the FPSP, any floating point operation,
including printf() with a "%f" format specifier, is likely to cause an
unimplemented instruction exception.
The FPSP works with the default variants of libc, libm and libgcc. It does not
work in conjunction with the msoft-float variants. The paranoia test goes into
an infinite loop at milestone 40. I am guessing that floor() is returning an
incorrect value.
The msoft-float variants of libc, libm and libgcc appear to do floating point
I/O properly. They only failed in paranoia. Offhand, I can't think of why they
would conflict with the FPSP, so I think that there is something wrong with the
msoft-float code. It might be my installation.
Given my experiences, I decided to install the FPSP in bsp_start(), and to link
against the default variants of libc, libm and libgcc. This causes the
executables to increase in size by about 60 KB. The README file and the
mvme167.cfg specify how to remove the FPSP, and how to link against the
msoft-float variants of the libraries. This is not what Eric Norum had done: on
my host, his gen68360_040 port links RTEMS code with the msoft-float variants
of libc and libm, and the default variant of libgcc. In this configuration, the
output of printf() with "%f" is garbage on my target.
incorrect value.
