* | 2005-05-12 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-12 | 1 | -0/+7 | |
| | | | | | | | PR 784/networking * libnetworking/net/if_arp.h, libnetworking/netinet/if_ether.h, libnetworking/netinet/ip_icmp.h, libnetworking/netinet/ip_var.h, libnetworking/netinet/tcp.h: Define BYTE_PACK. | |||||
* | Define BYTE_PACK. | Ralf Corsepius | 2005-05-12 | 5 | -1/+17 | |
* | 2005-05-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-11 | 6 | -3/+15 | |
| | | | | * startup/linkcmds: Add .rodata.* sections. | |||||
* | 2005-05-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-11 | 2 | -1/+6 | |
| | | | | * startup/linkcmds: Add .data.* sections. | |||||
* | Followup fix to Joel's earlier _VBR changes. | Eric Norum | 2005-05-11 | 2 | -0/+9 | |
* | 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-11 | 1 | -0/+5 | |
| | | | | | * libchip/Makefile.am: Include preinstall.am. * libchip/preinstall.am: New. | |||||
* | Include preinstall.am. | Ralf Corsepius | 2005-05-11 | 1 | -123/+4 | |
* | New. | Ralf Corsepius | 2005-05-11 | 1 | -0/+123 | |
* | 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-11 | 2 | -3/+7 | |
| | | | | * include/tm27.h: Elininate unsigned32. | |||||
* | 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-11 | 2 | -1/+5 | |
| | | | | * vme/vmeconfig.c: Eliminate unsigned32. | |||||
* | Remove. | Ralf Corsepius | 2005-05-11 | 14 | -184/+0 | |
* | 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-11 | 1 | -0/+7 | |
| | | | | | | | * Makefile.am: Merge-in mcf5282/Makefile.am. * preinstall.am: Regenerate. * mcf5282/Makefile.am: Remove. * configure.ac: Remove mcf5282/Makefile. | |||||
* | Remove mcf5282/Makefile. | Ralf Corsepius | 2005-05-11 | 1 | -1/+0 | |
* | Merge-in mcf5282/Makefile.am. | Ralf Corsepius | 2005-05-11 | 1 | -3/+6 | |
* | Regenerate. | Ralf Corsepius | 2005-05-11 | 1 | -0/+10 | |
| | | | | | | | * Makefile.am: Merge-in mcf5272/Makefile.am. * preinstall.am: Regenerate. * mcf5272/Makefile.am: Remove. * configure.ac: Remove mcf5272/Makefile. | |||||
* | mcf5272/Makefile.am. | Ralf Corsepius | 2005-05-11 | 1 | -1/+19 | |
* | Regenerate. | Ralf Corsepius | 2005-05-11 | 1 | -0/+28 | |
* | Remove mcf5272/Makefile. | Ralf Corsepius | 2005-05-11 | 1 | -1/+0 | |
| | | | | | | | * Makefile.am: Merge-in mcf5206/Makefile.am. * preinstall.am: Regenerate. * mcf5206/Makefile.am: Remove. * configure.ac: Remove mcf5206/Makefile. | |||||
* | Remove mcf5206/Makefile. | Ralf Corsepius | 2005-05-11 | 1 | -1/+0 | |
* | Merge-in mcf5206/Makefile.am. | Ralf Corsepius | 2005-05-11 | 1 | -1/+33 | |
* | Remove. | Ralf Corsepius | 2005-05-11 | 2 | -70/+0 | |
* | 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-11 | 1 | -0/+6 | |
| | | | | | | * Makefile.am: Merge-in m68040/Makefile.am. * m68040/Makefile.am: Remove. * configure.ac: Remove m68040/Makefile. | |||||
* | Remove. | Ralf Corsepius | 2005-05-11 | 2 | -30/+0 | |
* | Remove m68040/Makefile. | Ralf Corsepius | 2005-05-11 | 1 | -1/+0 | |
* | Merge-in m68040/Makefile.am. | Ralf Corsepius | 2005-05-11 | 1 | -1/+25 | |
* | Fix typo in previous patch. | Ralf Corsepius | 2005-05-11 | 1 | -1/+1 | |
* | 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-11 | 1 | -0/+8 | |
| | | | | | | | | * Makefile.am: Merge-in shared/Makefile.am. * preinstall.am: New. * shared/Makefile.am: Remove. * configure.ac: Remove shared/Makefile. Add AMPOLISH3. | |||||
* | Remove shared/Makefile. | Ralf Corsepius | 2005-05-11 | 1 | -1/+4 | |
* | Merge-in shared/Makefile.am. | Ralf Corsepius | 2005-05-11 | 1 | -0/+37 | |
* | New. | Ralf Corsepius | 2005-05-11 | 1 | -0/+24 | |
* | Remove. | Ralf Corsepius | 2005-05-11 | 2 | -61/+0 | |
* | 2005-05-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-11 | 1 | -0/+4 | |
| | | | | * mcf5282/include/Makefile.am: Remove (unused). | |||||
* | Remove (unused). | Ralf Corsepius | 2005-05-11 | 1 | -23/+0 | |
| | | | | | | | * Makefile.am: Merge-in sh7750/Makefile.am. * preinstall.am: Regenerate. * sh7750/Makefile.am: Remove. * configure.ac: Remove sh7750/Makefile. | |||||
* | Merge-in sh7750/Makefile.am. | Ralf Corsepius | 2005-05-11 | 1 | -4/+37 | |
* | Remove sh7750/Makefile. | Ralf Corsepius | 2005-05-11 | 1 | -1/+0 | |
* | Regenerate. | Ralf Corsepius | 2005-05-11 | 1 | -0/+35 | |
* | Remove. | Ralf Corsepius | 2005-05-11 | 2 | -94/+0 | |
| | | | | | | | * Makefile.am: Merge-in sh7045/Makefile.am. * preinstall.am: Regenerate. * sh7045/Makefile.am: Remove. * configure.ac: Remove sh7045/Makefile. | |||||
* | Merge-in sh7045/Makefile.am. | Ralf Corsepius | 2005-05-11 | 1 | -6/+43 | |
* | Remove sh7045/Makefile. | Ralf Corsepius | 2005-05-11 | 1 | -1/+0 | |
* | Regenerate. | Ralf Corsepius | 2005-05-11 | 1 | -0/+39 | |
* | Remove. | Ralf Corsepius | 2005-05-11 | 2 | -95/+0 | |
| | | | | | | | | * Makefile.am: Merge-in sh7032/Makefile.am. * preinstall.am: New. * sh7032/Makefile.am: Remove. * configure.ac: Remove sh7032/Makefile. Add AMPOLISH3. | |||||
* | Merge-in sh7032/Makefile.am. | Ralf Corsepius | 2005-05-11 | 1 | -1/+47 | |
* | Remove sh7032/Makefile. | Ralf Corsepius | 2005-05-11 | 1 | -1/+4 | |
* | New. | Ralf Corsepius | 2005-05-11 | 1 | -0/+44 | |
* | Remove. | Ralf Corsepius | 2005-05-11 | 2 | -92/+0 | |
