* setup.def: Updated version numbers and patches for binutils
and gdb. binutils was to get correct patch in field. gdb
was to add mipstx39-rtems configurery support.
* sys/utsname.h: Added C++ wrapper.
* include/.cvsignore: Remove danlgling file.
* gdb/Makefile.am, mkgdbspec.in: Added mipstx39-rtems
configuration to gdb since this includes the JMR3904 simulator.
* serial/Makefile.am, serial/mc68681.c, serial/ns16550.c,
serial/serprobe.c, serial/z85c30.c: Now install sersupp.h
to <libchip/sersupp.h> so libchip style serial drivers can
be written in libcpu or libbsp.
* console/console.c: Added printk() support.
* custom/genmongossev.cfg: New file.
* clock/clockdrv.c, console/conscfg.c, include/bsp.h, start/start.S,
startup/bspstart.c, timer/timer.c: Comments corrected.
* The Generic Mongoose-V BSP uses only the peripherals found on
the Synova Mongoose-V CPU. This is a radiation hardened CPU
based on the LSI Logic 33K.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in,
clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/conscfg.c,
start/.cvsignore, start/Makefile.am, start/regs.S, start/start.S,
startup/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/linkcmds, timer/.cvsignore, timer/Makefile.am, timer/timer.c,
wrapup/.cvsignore, wrapup/Makefile.am: New files.
* cpu.c, rtems/score/cpu.h, rtems/score/mipstypes.h:
Removed unused variable _CPU_Thread_dispatch_pointer
and cleaned numerous comments.
* Added mongoose-v, mongoose-v/include, and mongoose-v/vectorisrs
directories.
* mongoosev/.cvsignore, mongoosev/Makefile.am, mongoosev/README,
mongoosev/duart/.cvsignore, mongoosev/duart/Makefile.am,
mongoosev/duart/README.mguart, mongoosev/duart/mg5uart.c,
mongoosev/duart/mg5uart.h, mongoosev/duart/mg5uart_reg.c,
mongoosev/include/.cvsignore, mongoosev/include/Makefile.am,
mongoosev/include/mongoose-v.h, mongoosev/vectorisrs/.cvsignore,
mongoosev/vectorisrs/Makefile.am, mongoosev/vectorisrs/vectorisrs.c:
New files.
* Makefile.am, configure.in, shared/interrupts/Makefile.am,
shared/interrupts/maxvectors.c: Added support for mongoosev.
* tx39/vectorisrs/vectorisrs.c: Corrected warning.
* configure.in: Use ${MAKE} in message at the end of the
configure.in.
* cpu.c, cpu_asm.S, iregdef.h, rtems/score/cpu.h, rtems/score/mips.h:
Merged MIPS1 and MIPS3 code reducing the number of lines of assembly.
Also reimplemented some assembly routines in C further reducing
the amount of assembly and increasing maintainability.
* rtems_servers/ftp.d: Following changes:
- Hacks with current dir and root dir removed in favor of new libio
support for task-local current and root directories.
- Bug in `close_data_socket()' introduced by previous change fixed.
- `command_pasv()' changed to set timeout on socket we are listening
on and code fixed to don't close socket twice on error.
- `serr()' changed to clear `errno'.
- `data_socket()' changed to clear `errno' before `bind()'.
- `session()' changed to clear `errno' before processing session.
- `close_data_socket()' fixed to close both active and passive sockets
- Initialize info->data_socket to -1 in `daemon()'
- Initialize `fname' to empty string in `exec_command()'
* include/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* mpc505/ictrl/Makefile.am, mpc6xx/clock/Makefile.am,
mpc6xx/exceptions/Makefile.am, mpc6xx/mmu/Makefile.am,
mpc8xx/include/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am, pc403/ictrl/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am:
Apply *_HEADERS instead of *H_FILES.
* shared/src/.cvsignore: Add cache.h.
* clock/Makefile.am: Apply *_HEADERS instead of *H_FILES.
* shared/cache/Makefile.am, tx39/include/Makefile.am:
* m68040/fpsp/Makefile.am, shared/cache/Makefile.am:
* i960ca/Makefile.am, i960ka/Makefile.am, i960rp/Makefile.am:
Remove H_FILES.
* network/cs8900.c, network/cs8900.h, network/sonic.c, network/sonic.h,
rtc/icm7170_reg.c, rtc/icm7170_reg2.c, rtc/icm7170_reg4.c,
rtc/icm7170_reg8.c, rtc/m48t08_reg.c, rtc/m48t08_reg2.c,
rtc/m48t08_reg4.c, rtc/m48t08_reg8.c, serial/mc68681_reg.c,
serial/mc68681_reg2.c, serial/mc68681_reg4.c, serial/mc68681_reg8.c,
serial/z85c30.c, serial/z85c30.h, serial/z85c30_p.h,
serial/z85c30_reg.c: Corrected header.
* include/Makefile.am, syscall/Makefile.am, cache/Makefile.am:
* cache/.cvsignore: Add cache.h.
* Makefile.am: Apply include_*HEADERS instead of H_FILES.
* .cvsignore: Add cache.h.
* configure.in: Reworked for Canadian Cross support.
* config.guess, config.sub: Update from subversions.gnu.org.
* README.cdn-X: New file.
* tools/Makefile.am: Remove build, tools from SUBDIRS.
* aclocal/config-subdirs.m4: Let CC default to $host_alias-gcc in
TARGET_CONFIG_SUBDIRS.
* aclocal/enable-bsp.m4: fix quoting.
* aclocal/check-bsps.m4, aclocal/bsp-alias.m4: Add pc386dx.
* custom/pc386dx.cfg: New bsp.
* configure.in: AC_DEFINE RTEMS_UNIX if RTEMS_CPU=unix.
* custom/Cygwin-posix.cfg, custom/HPUX9-posix.cfg,
custom/Solaris-posix.cfg, custom/FreeBSD-posix.cfg,
custom/Linux-posix.cfg: Remove RTEMS_UNIX from make-target-options.
* monitor/mon-command.c: Use #if defined(RTEMS_UNIX).
* spsize/size.c: Use #if !defined(RTEMS_UNIX).
* include/rdbg/Makefile.am, include/rdbg/i386/Makefile.am,
include/rdbg/m68k/Makefile.am, include/rdbg/powerpc/Makefile.am:
Cleanup including more proper style on include files.
* Makefile.am: Switch from prefix to exec_prefix.
* target.cfg.in: Remove prefix and commented out lines.
* aclocal/config-subdirs.m4: New file.
* aclocal/target.m4: Use macros from config-subdirs.m4.
* Makefile.am: Use exec_prefix not prefix.
* include/ioccom.h: Unreferenced and thus removed.
* configure.in: Apply _RTEMS_ADJUST_SRCDIR.
* include/rpc/Makefile.am: Apply include_*HEADERS instead of
H_FILES.
* Makefile.am, arpa/Makefile.am, machine/Makefile.am, net/Makefile.am,
netinet/Makefile.am, nfs/Makefile.am, rtems/Makefile.am,
rtems_servers/Makefile.am, rtems_webserver/Makefile.am,
sys/Makefile.am, vm/Makefile.am:
* Makefile.am: Add handling of *.h files.
* configure.in: Remove include/Makefile.
* include/rtems/Makefile.am, include/rtems/score/Makefile.am,
inline/rtems/score/Makefile.am, macros/rtems/score/Makefile.am
* include/Makefile.am, include/rtems/Makefile.am,
inline/rtems/Makefile.am, macros/rtems/Makefile.am:
* include/Makefile.am, include/rtems/rtems/Makefile.am,
inline/rtems/rtems/Makefile.am, macros/rtems/rtems/Makefile.am,
rtems/optman/Makefile.am:
* include/Makefile.am, include/rtems/posix/Makefile.am,
include/sys/Makefile.am, inline/rtems/posix/Makefile.am,
macros/rtems/posix/Makefile.am:
* include/Makefile.am, include/itronsys/Makefile.am,
include/rtems/itron/Makefile.am, inline/rtems/itron/Makefile.am,
macros/rtems/itron/Makefile.am:
* untar/Makefile.am, monitor/Makefile.am, dummy/Makefile.am,
devnull/Makefile.am, dumpbuf/Makefile.am, mw-fb/Makefile.am,
stackchk/Makefile.am, rtmonuse/Makefile.am, cpuuse/Makefile.am:
* include/zilog/Makefile.am, include/Makefile.am,
include/motorola/Makefile.am, include/sys/Makefile.am
include/rtems/Makefile.am: Apply include_*HEADERS instead of
H_FILES.
* network/Makefile.am, rtc/Makefile.am, serial/Makefile.am:
Apply include_*HEADERS instead of H_FILES, replace ${..} with $(..).
