* | Added chapter. | Joel Sherrill | 1998-10-19 | 3 | -3/+40 |
* | Added chapter. | Joel Sherrill | 1998-10-19 | 4 | -5/+246 |
* | Added chapter. | Joel Sherrill | 1998-10-19 | 2 | -6/+263 |
* | Added. | Joel Sherrill | 1998-10-19 | 3 | -3/+100 |
* | Added 2 chapters | Joel Sherrill | 1998-10-19 | 4 | -0/+338 |
* | Changed reference to KA9Q driver. | Joel Sherrill | 1998-10-15 | 1 | -51/+27 |
| | | | | Cleaned up description of the make/custom file. | ||||
* | Cleaned up where Geoffroy had this in 2-column format. | Joel Sherrill | 1998-10-15 | 1 | -14/+33 |
* | Added more to the list of chapters. | Joel Sherrill | 1998-10-15 | 1 | -9/+30 |
* | Redid sections to have right depth. | Joel Sherrill | 1998-10-15 | 3 | -41/+40 |
* | Removed bsp structure as chapter and renamed some other chapters. | Joel Sherrill | 1998-10-15 | 1 | -4/+2 |
* | Removed bspstruct.t. | Joel Sherrill | 1998-10-15 | 1 | -11/+7 |
| | | | | Commented lines which installed files. | ||||
* | Cleaned up bad line wrap which was only a long sequence of ??? | Joel Sherrill | 1998-10-15 | 1 | -1/+1 |
* | Merged bsp structure into target dependent files chapter. | Joel Sherrill | 1998-10-15 | 2 | -48/+64 |
* | changed version to 4.0.0-beta4a | Joel Sherrill | 1998-10-15 | 3 | -3/+3 |
* | Removed unnecessary settings. | Joel Sherrill | 1998-10-15 | 1 | -6/+0 |
* | Updated for the i386ex and deprecated BSPs. | Joel Sherrill | 1998-10-15 | 1 | -5/+8 |
* | Added bare bsp, mini-glue layer for POSIX port, and bare bsp information. | Joel Sherrill | 1998-10-15 | 1 | -0/+14 |
* | Added pre_install_src as a dependency to debug and profile per Ralf Corsepius' | Joel Sherrill | 1998-10-15 | 1 | -2/+2 |
| | | | | recommendation. | ||||
* | Regenerated. | Joel Sherrill | 1998-10-15 | 0 | -0/+0 |
* | Patch from Thomas Doerfler <td@imd.m.isar.de> to include the | Joel Sherrill | 1998-10-15 | 1 | -1/+2 |
| | | | | ppc403 interrupt control libcpu component. | ||||
* | Uncommented the conditional stuff for "good gas 16 bit code". | Joel Sherrill | 1998-10-15 | 1 | -2/+2 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1998-10-14 | 40 | -216/+2921 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 1. Rtems contains some perl scripts that use hard-coded paths to /usr/bin/perl or /usr/local/bin/perl I have already fixed these problems by adding some checks to configure.in. While doing this, I also cleaned up some more autoconf related problems for generating shell scripts. This patch might seem a bit scary to you, but I am quite confident it won't break something (I've been testing it for almost a week now, however it might introduce typos for a limited number configurations I don't have access to - But it shouldn't be a problem for you to test them :-). I expect to get this finished tonight, hence you will very likely have the patch when you get up tomorrow. Changes: * Check for PERL and disable all PERL scripts if perl wasn't found. * Generate all KSHELL-scripts with autoconf instead of make-script * Automatic dependency handling for autoconf generated KSHELL or PERL scripts (make/rtems.cfg) Notes: * this patch contains new files and deletes some other files. * The patch is relative to rtems-4.0.0-beta4 with my previous rtems-rc-981014-1.diff patch applied. Testing: I tested it with sh-rtems and posix under linux. Now all targets which are touched by this patch and which are not used while building for sh-rtems and posix still need to be tested. AFAIS, only the sparc/erc32 BSP should be affected by this criterion. And if you like to, you should also consider testing it on a Cygwin32 and a Solaris host for one arbitrary BSP. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1998-10-14 | 3 | -48/+67 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | 2. "make profile" doesn't work. It aborts when building host-tools for embedded targets. I didn't yet have enough time to fix this problem. AFAIS this problem is related to handling of LDFLAGS_PROFILE[|_V] in gcc.cfg.in. For host applications, we use gcc for linking host applications, too. With profiling enabled CFLAGS_PROFILE_V contains -pg and is used to compile, but LDFLAGS_PROFILE_V is empty, hence -pg will not be passed to the linker causing gcc to fail to link, because it can't resolve some symbols introduced by compiling with -pg. I am not sure if I can provide a patch for this - Ether it is trivial to fix or requires basic work on host configuration ;- Fixing this one was trivial - But hard to trace. LDFLAGS_PROFILE_V needs to contain the same flags as CFLAGS_PROFILE_V, if gcc is used for linking (What else should have been expected ?, :-). The same problem was present for *_DEBUG_V, but apparently wasn't noticed by anybody, because things didn't break, but were silently ignored. I fixed these problems by setting these flags in configure.in whenever gcc is reported to be the host-compiler. For non-gcc host compilers "make debug" and "make profile" now becomes the same as an ordinary "make". This is a hack and addressing this problen could be more sophisticated, but I don't think it gives much sense to support compile variants for any host program (Who will ever try to profile/debug host tools?). Therefore I don't think it's useful to invest more effort into this problem. | ||||
* | Updated. | Joel Sherrill | 1998-10-14 | 1 | -3/+3 |
* | Added rest of opendir family and made it compile. | Joel Sherrill | 1998-10-13 | 4 | -5/+51 |
* | New files. | Joel Sherrill | 1998-10-13 | 15 | -0/+984 |
* | Added missing BSPs. | Joel Sherrill | 1998-10-13 | 1 | -4/+5 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to correct minor | Joel Sherrill | 1998-10-13 | 4 | -10/+6 |
| | | | | cosmetic things. | ||||
* | Modified to avoid building certain files under UNIX. | Joel Sherrill | 1998-10-13 | 1 | -3/+11 |
* | New file | Joel Sherrill | 1998-10-12 | 1 | -0/+85 |
* | Added idle_task_stack_size field to CPU Table. | Joel Sherrill | 1998-10-12 | 11 | -0/+66 |
* | Added message to "return -1 and set errno". | Joel Sherrill | 1998-10-12 | 1 | -5/+11 |
* | Fixed typo. | Joel Sherrill | 1998-10-12 | 1 | -1/+1 |
* | Updated to reflect MG-10 IMFS effort. | Joel Sherrill | 1998-10-12 | 2 | -51/+51 |
* | Added some fields and changed last KA9Q reference to FreeBSD. | Joel Sherrill | 1998-10-12 | 1 | -1/+12 |
* | Changed section numbers. | Joel Sherrill | 1998-10-12 | 11 | -93/+86 |
* | Changed commands for installing numerous files to include $(SRCDIR). | Joel Sherrill | 1998-10-12 | 1 | -4/+4 |
* | Changed command for installing the footer. | Joel Sherrill | 1998-10-12 | 1 | -1/+1 |
* | Typo which prevented baud rate changes from Thomas Doerfler <td@imd.m.isar.de>. | Joel Sherrill | 1998-10-12 | 1 | -1/+1 |
* | changed version to 4.0.0-beta4 | Joel Sherrill | 1998-10-12 | 3 | -3/+3 |
* | New files. | Joel Sherrill | 1998-10-12 | 6 | -0/+492 |
* | Regenerated. | Joel Sherrill | 1998-10-12 | 0 | -0/+0 |
* | Removed fork(), execv(), and wait() since they are now stubbed in the | Joel Sherrill | 1998-10-12 | 1 | -21/+0 |
| | | | | POSIX API. | ||||
* | Added opendir and readdir. | Joel Sherrill | 1998-10-12 | 1 | -1/+1 |
* | Added helas403 and changed column spacing. | Joel Sherrill | 1998-10-12 | 1 | -36/+40 |
* | Added header files per request from Chris Johns to avoid problems | Joel Sherrill | 1998-10-12 | 4 | -0/+16 |
| | | | | in include file order. | ||||
* | Fixed typo spotted by Jeff Mayes. | Joel Sherrill | 1998-10-09 | 1 | -1/+1 |
* | NEXT_GAS should have been NEW_GAS. Spotted by Emmanuel Raguet ↵ | Joel Sherrill | 1998-10-07 | 3 | -4/+4 |
| | | | | <raguet@crf.canon.fr>. | ||||
* | Corrected typo pointed out by Pollak Leon <leonp@plris.com>. | Joel Sherrill | 1998-10-07 | 2 | -2/+2 |
* | changed version to 981006 | Joel Sherrill | 1998-10-06 | 3 | -3/+3 |
