* | 2009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-24 | 3 | -0/+31 |
| | | | | | * Makefile.am: Add qemuppc.cfg. * custom/qemuppc.cfg: New file. | ||||
* | 2009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-24 | 2 | -1/+6 |
| | | | | | * libmisc/shell/hexdump-odsyntax.c: Fix failure on SH2e where there is only single precision float. | ||||
* | 2009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-24 | 2 | -0/+77 |
| | | | | * irq/irq.h: New file. | ||||
* | 2009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-24 | 14 | -0/+594 |
| | | | | | | | * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, preinstall.am, console/console-io.c, include/.cvsignore, include/bsp.h, start/start.S, startup/bsppanic.c, startup/cmain.c, startup/linkcmds: New files. | ||||
* | 2009-09-24 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-09-24 | 2 | -0/+26 |
| | | | | * stackchk01/stackchk01.doc: Add content. | ||||
* | 2009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-24 | 4 | -27/+9 |
| | | | | | | * libcsupport/src/getpagesize.c, posix/Makefile.am: Eliminate one copy of getpagesize() and make it return an int. * posix/src/getpagesize.c: Removed. | ||||
* | Regenerate. | Ralf Corsepius | 2009-09-23 | 14 | -42/+42 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-09-23 | 14 | -14/+14 |
* | Fix bug in with_system_readline logic. | Ralf Corsepius | 2009-09-23 | 1 | -2/+2 |
* | Add *.tar.xz. | Ralf Corsepius | 2009-09-23 | 1 | -0/+1 |
* | Add xz-compressed tarball | Ralf Corsepius | 2009-09-23 | 1 | -1/+1 |
* | Bump version. | Ralf Corsepius | 2009-09-23 | 1 | -1/+1 |
* | Minor fixes. | Ralf Corsepius | 2009-09-23 | 1 | -7/+3 |
* | 2009-09-22 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-23 | 3 | -0/+11 |
| | | | | | * Makefile.am, configure.ac: Disable network interface when networking is disabled. | ||||
* | Update. | Ralf Corsepius | 2009-09-22 | 39 | -115/+115 |
* | New. | Ralf Corsepius | 2009-09-22 | 1 | -0/+1261 |
* | 2009-09-21 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-09-21 | 8 | -1/+85 |
| | | | | | | | * Makefile.am, configure.ac: Add initial test for rtems_stack_checker_is_blown. * stackchk01/.cvsignore, stackchk01/Makefile.am, stackchk01/init.c, stackchk01/stackchk01.doc, stackchk01/stackchk01.scn: New files. | ||||
* | 2009-09-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-21 | 3 | -3/+17 |
| | | | | | * psxclock/init.c, psxclock/psxclock.scn: Add test case for negative nanoseconds. | ||||
* | Add missing files. | Thomas Doerfler | 2009-09-21 | 4 | -0/+664 |
* | 2009-09-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-20 | 3 | -1/+28 |
| | | | | | * posix/Makefile.am: Add getpagesize(). Now required by GNU Ada. * posix/src/getpagesize.c: New file. | ||||
* | 2009-09-20 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-20 | 3 | -0/+11 |
| | | | | | * psxsysconf/init.c, psxsysconf/psxsysconf.scn: Add test for getpagesize(). | ||||
* | Housekeeping. | Ralf Corsepius | 2009-09-18 | 5 | -45993/+0 |
* | Regenerate. | Ralf Corsepius | 2009-09-18 | 14 | -137/+179 |
* | gdb-6.8.91-rtems4.10-20090918.diff. | Ralf Corsepius | 2009-09-18 | 13 | -13/+13 |
* | Bump GDB_RPMREL. | Ralf Corsepius | 2009-09-18 | 13 | -13/+13 |
* | New. | Ralf Corsepius | 2009-09-18 | 1 | -0/+555 |
* | Rework --with-system-readline handling. | Ralf Corsepius | 2009-09-18 | 3 | -7/+10 |
* | * rtems/score/cpu.h: Fix for inline asm in _CPU_Fatal_halt(). | Thomas Doerfler | 2009-09-18 | 5 | -43/+23 |
| | | | | | * rtems/asm.h: Added macro to define ARM functions. * cpu_asm.S, arm_exc_handler_low.S: Use macro from above. | ||||
* | Removed symbols and renamed sections. | Thomas Doerfler | 2009-09-18 | 5 | -105/+166 |
| | | | | Added bsp_start_memcpy(). Documentation. Changes for external ROM start. | ||||
* | Changes throughout. | Thomas Doerfler | 2009-09-18 | 19 | -946/+762 |
* | preinstall.am: Regenerate. | Thomas Doerfler | 2009-09-18 | 2 | -0/+6 |
* | 2009-09-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-18 | 2 | -0/+9 |
| | | | | * pxa255/ffuart/ffuart.c: Add BSP_poll_char. | ||||
* | Update Source0-URL. | Ralf Corsepius | 2009-09-17 | 13 | -13/+13 |
* | Rebase against gdb-6.8.91. | Ralf Corsepius | 2009-09-17 | 1 | -0/+544 |
* | Regenerate. | Ralf Corsepius | 2009-09-17 | 13 | -48/+48 |
* | gdb-6.8.91. | Ralf Corsepius | 2009-09-17 | 13 | -22/+22 |
* | gdb-%{gdb_version}-rtems4.10-20090917.diff | Ralf Corsepius | 2009-09-17 | 13 | -13/+13 |
* | 2009-09-16 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-09-16 | 2 | -4/+13 |
| | | | | | * score/src/userextaddapiset.c: Disable code that is only used when ITRON or POSIX is enabled. | ||||
* | *** empty log message *** | Joel Sherrill | 2009-09-16 | 1 | -60/+51 |
* | 2009-09-16 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-09-16 | 2 | -1/+4 |
| | | | | * configure.ac: Resolve confusion with Ralf's patch. | ||||
* | 2009-09-16 Roxana Leontie <roxana.leontie@gmail.com> | Joel Sherrill | 2009-09-16 | 4 | -21/+89 |
| | | | | | * configure.ac, fb/fb.c, include/bsp.h: updates made for porting to Nano-X and make testing easyer | ||||
* | Regenerate. | Ralf Corsepius | 2009-09-16 | 13 | -89/+89 |
* | Bump GCC_RPMREL. | Ralf Corsepius | 2009-09-16 | 13 | -13/+13 |
* | newlib-1.17.0-rtems4.10-20090916.diff. | Ralf Corsepius | 2009-09-16 | 13 | -13/+13 |
* | New. | Ralf Corsepius | 2009-09-16 | 1 | -0/+1127 |
* | 2009-09-15 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-09-16 | 2 | -3/+18 |
| | | | | | | | PR 1344/bsps: * clock/ckinit.c: Fix more bugs (applied PR1344/attachment 702): TSC handler was used when 8254 was requested and vice versa. Also, nanosecond handler was never installed to RTEMS clock. | ||||
* | 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-15 | 2 | -0/+6 |
| | | | | * aclocal/bsp-configure.m4: Add RTEMS_BSP_BOOTCARD_OPTIONS. | ||||
* | 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-15 | 144 | -144/+360 |
| | | | | * configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS. | ||||
* | 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-15 | 1 | -0/+5 |
| | | | | | * libmisc/shell/utils-cp.c: Include <utime.h> instead of <sys/utime.h> for better POSIX compilance. | ||||
* | Include <utime.h> instead of <sys/utime.h> for better POSIX compilance. | Ralf Corsepius | 2009-09-15 | 1 | -1/+1 |
