* aclocal/check-bsps.m4: Use ls instead of globs to pickup
bsp_specs.
PR 717/bsps
* bootloader/Makefile.am: Set up BOOTLOADER_CPU_CFLAGS.
* aclocal/check-bsps.m4: Add MVME2100 BSP as alias of
motorola_shared.
* include/rtems/pci.h: BSPs use the name BSP_pci_configuration not pci.
Also need to address that this largely duplicates
libbsp/powerpc/pci/pci.h but that file is not used when both are
included due to the same double inclusion protection.
* libchip/network/dec21140.c: Cleanup a bit and remove message about
not supported on PowerPC since it works on the MVME2100 BSP.
* configure.ac, mpc6xx/exceptions/raw_exception.c,
mpc6xx/exceptions/raw_exception.h, mpc6xx/mmu/bat.c,
mpc6xx/mmu/bat.h, mpc6xx/mmu/mmuAsm.S, shared/include/cpuIdent.c,
shared/include/cpuIdent.h: Add MPC8240 and MPC8245 support. There was
also a significant amount of spelling and whitespace cleanup.
* Makefile.am, bootloader/misc.c, bootloader/pci.c, bootloader/pci.h,
console/console.c, console/inch.c, console/reboot.c, console/uart.c,
console/uart.h, irq/irq.c, irq/irq.h, irq/irq_init.c,
motorola/motorola.c, motorola/motorola.h, openpic/openpic.c,
openpic/openpic.h, pci/detect_raven_bridge.c, pci/pci.c,
start/start.S, startup/bspstart.c, vectors/vectors_init.c,
vme/vmeconfig.c: Add MVME2100 BSP and MPC8240 support. There was also
* tod/todcfg.c: New file.
* Makefile.am, configure.ac, bootloader/Makefile.am, include/bsp.h,
wrapup/Makefile.am: Add MVME2100 BSP and MPC8240 support. There was
* README.MVME2100: New file.
* Makefile.am: Add MVME2100 BSP.
* custom/mvme2100.cfg: New file.
* aclocal/bsp-alias.m4: Add MVME2100 BSP as alias of motorola_shared.
* libcsupport/include/stdint.h: Fixed name in @file.
* libcsupport/include/sys/_stdint.h: Remove.
* libcsupport/include/sys/_inttypes.h: Remove.
* libcsupport/include/stdint.h: Replace with former sys/_stdint.h.
Add INT<N>_C, various additions.
* libcsupport/include/inttypes.h: Replace with former
sys/_inttypes.h.
* libcsupport/Makefile.am: Reflect changes above.
sys/_inttypes.h.
sys/_inttypes.h.
* backward/asm.h: Add doxygen preamble.
* backward/chain.h: Add doxygen preamble.
* backward/clockdrv.h: Add doxygen preamble.
* backward/confdefs.h: Add doxygen preamble.
* backward/console.h: Add doxygen preamble.
* backward/dosfs.h: Add doxygen preamble.
* backward/imfs.h: Add doxygen preamble.
* backward/iosupp.h: Add doxygen preamble.
* backward/itron.h: Add doxygen preamble.
* backward/ringbuf.h: Add doxygen preamble.
* backward/rtc.h: Add doxygen preamble.
* backward/spurious.h: Add doxygen preamble.
* backward/timerdrv.h: Add doxygen preamble.
* backward/vmeintr.h: Add doxygen preamble.
* backward/motorola/mc68230.h: Add doxygen preamble.
* backward/motorola/mc68681.h: Add doxygen preamble.
* backward/zilog/z8030.h: Add doxygen preamble.
* backward/zilog/z8036.h: Add doxygen preamble.
* backward/zilog/z8536.h: Add doxygen preamble.
* libcsupport/include/sys/_stdint.h: Special-case int64_t (GCC has
__LONG_LONG_MAX__, while POSIX mandates LLONG_MAX. This break
__EXP(LONG_LONG_MAX)).
* i686-pc-cygwin-binutils.spec.in, i686-pc-cygwin-gcc.spec.in,
i686-pc-cygwin-libs.spec.in, i686-pc-cygwin-mingw.spec.in,
i686-pc-cygwin-w32api.spec.in: New.
* i386-cygwin-binutils.spec.in, i386-cygwin-gcc.spec.in,
i386-cygwin-libs.spec.in, i386-cygwin-mingw.spec.in,
i386-cygwin-w32api.spec.in: Remove.
* setup.def: Update to current cygwin.
* Makefile.am, configure.ac: Reflect changes above.
* libnetworking/machine/endian.h: Protect BYTE_ORDER from double
definition.
* startup/linkcmds: Add .gnu.linkonce.b section.
* custom/csb336.cfg, custom/csb337.cfg: RTEMS_CPU must match an
architecture name for RTEMS. Since this was used as the -mcpu
argument to GCC, that also had to be changed.
* startup/linkcmds: Add .gnu.linkonce.b and .gnu.linkonce.bs sections.
* startup/linkcmds: Add .gnu.linkonce.b section and account for memory
area being named sdram NOT RAM.
PR 706/doc
* user/task.t: Remove not that changes explanation.
* configure.ac: Remove RTEMS_USES_INTTYPES_H. Require inttypes.h.
* include/rtems/stdint.h: Remove "wild guesses", require inttypes.h.
* libcsupport/include/inttypes.h: Cleanup.
* libcsupport/include/stdint.h: Cleanup.
* configure.ac: Remove check for libbsp/${RTEMS_CPU}.
Add dependency tracking for *.cfgs.
* Makefile.am: Add dependency tracking for *.cfg.
* include/sys/_stdint.h: Various changes.
Add *leastN_t types. Add INTN_{MIN|MAX} macros.
* include/sys/_inttypes.h: Add doxygen preamble.
* libcsupport/include/stdint.h: Add doxygen preamble.
* libcsupport/include/inttypes.h: Add doxygen preamble.
* configure.ac: Add doxygen preamble to cpuopts.h.
* libchip/rtc/mc146818a.c: Don't include <bsp.h>
(Thanks to Lars Munch <lars@segv.dk> for catching this).
* posix/src/mqueueunlink.c, posix/src/semunlink.c,
score/inline/rtems/score/object.inl,
score/macros/rtems/score/object.inl: _Objects_Is_local_id() should be
avoided in single CPU configurations but always available in the
Objects Handlers API.
* setup.def: Include PowerPC patch to make C++ global constructors work
-- gcc 3.3.5/newlib-1.12.0 revision 2.
* rtems/include/rtems.h,
rtems/inline/rtems/rtems/asr.inl,
rtems/inline/rtems/rtems/attr.inl,
rtems/inline/rtems/rtems/dpmem.inl,
rtems/inline/rtems/rtems/event.inl,
rtems/inline/rtems/rtems/eventset.inl,
rtems/inline/rtems/rtems/message.inl,
rtems/inline/rtems/rtems/modes.inl,
rtems/inline/rtems/rtems/options.inl,
rtems/inline/rtems/rtems/part.inl,
rtems/inline/rtems/rtems/ratemon.inl,
rtems/inline/rtems/rtems/region.inl,
rtems/inline/rtems/rtems/sem.inl,
rtems/inline/rtems/rtems/status.inl,
rtems/inline/rtems/rtems/support.inl,
rtems/inline/rtems/rtems/tasks.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/macros/rtems/rtems/asr.inl,
rtems/macros/rtems/rtems/attr.inl,
rtems/macros/rtems/rtems/dpmem.inl,
rtems/macros/rtems/rtems/event.inl,
rtems/macros/rtems/rtems/eventset.inl,
rtems/macros/rtems/rtems/message.inl,
rtems/macros/rtems/rtems/modes.inl,
rtems/macros/rtems/rtems/options.inl,
rtems/macros/rtems/rtems/part.inl,
rtems/macros/rtems/rtems/ratemon.inl,
rtems/macros/rtems/rtems/region.inl,
rtems/macros/rtems/rtems/sem.inl,
rtems/macros/rtems/rtems/status.inl,
rtems/macros/rtems/rtems/support.inl,
rtems/macros/rtems/rtems/tasks.inl,
rtems/macros/rtems/rtems/timer.inl: Add doxygen preamble.
rtems/include/rtems/rtems/asr.h,
rtems/include/rtems/rtems/attr.h,
rtems/include/rtems/rtems/cache.h,
rtems/include/rtems/rtems/clock.h,
rtems/include/rtems/rtems/config.h,
rtems/include/rtems/rtems/dpmem.h,
rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/eventmp.h,
rtems/include/rtems/rtems/eventset.h,
rtems/include/rtems/rtems/intr.h,
rtems/include/rtems/rtems/message.h,
rtems/include/rtems/rtems/modes.h,
rtems/include/rtems/rtems/mp.h,
rtems/include/rtems/rtems/msgmp.h,
rtems/include/rtems/rtems/options.h,
rtems/include/rtems/rtems/part.h,
rtems/include/rtems/rtems/partmp.h,
rtems/include/rtems/rtems/region.h,
rtems/include/rtems/rtems/regionmp.h,
rtems/include/rtems/rtems/rtemsapi.h,
rtems/include/rtems/rtems/sem.h,
rtems/include/rtems/rtems/semmp.h,
rtems/include/rtems/rtems/signal.h,
rtems/include/rtems/rtems/signalmp.h,
rtems/include/rtems/rtems/status.h,
rtems/include/rtems/rtems/support.h,
rtems/include/rtems/rtems/taskmp.h,
rtems/include/rtems/rtems/tasks.h,
rtems/include/rtems/rtems/timer.h,
rtems/include/rtems/rtems/types.h: Add doxygen preamble.
* rtems/score/cpu.h: Add doxygen preamble.
* rtems/score/types.h: Add doxygen preamble.
* rtems/score/unix.h: Add doxygen preamble.
* rtems/score/sparc.h: Add doxygen preamble.
* rtems/score/sh.h: Add doxygen preamble.
* rtems/score/sh_io.h: Add doxygen preamble.
* rtems/score/powerpc.h: Add doxygen preamble.
* rtems/score/ppc.h: Add doxygen preamble.
* rtems/score/cpu_asm.h: Add doxygen preamble.
* rtems/score/or32.h: Add doxygen preamble.
* rtems/score/mips.h: Add doxygen preamble.
* rtems/score/m68k.h: Add doxygen preamble.
* rtems/score/i386.h: Add doxygen preamble.
* rtems/score/idtr.h: Add doxygen preamble.
* rtems/score/interrupts.h: Add doxygen preamble.
* rtems/score/registers.h: Add doxygen preamble.
* rtems/score/h8300.h: Add doxygen preamble.
* rtems/score/c4x.h: Add doxygen preamble.
* rtems/score/avr.h: Add doxygen preamble.
* rtems/score/arm.h: Add doxygen preamble.
